Question about Bosch Kitchen Ranges
Oven door won't close all the way. about 3/4 inch
Oven door won't close all the way. about 3/4 inch gap at top. Bosch oven
ngfam1
  • 639 Answers
SOURCE: door to bosch oven does
I'm Neil
No problem
This is a fire hazard!
You will have to call service this time!
Thank You for asking!
Neil
Please rate my solution
Posted on Aug 24, 2008
jumptrout51
  • 3361 Answers
SOURCE: Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
Posted on May 05, 2009
hiltonjug
  • 612 Answers
SOURCE: oven door will not close
I run into this sometimes. Try this. Look at the timer on the panel. Cancle any time bake or clean comand thats set. When you do this, you should be able to unlock the door.
Please rate this solution
Posted on Aug 27, 2009
SOURCE: lofra five burner gas cooker, oven door not closing properly,
I had the same problem and took the door apart. The hinge has a spring inside which is held in place by a long rivet. The metal of the rivet is too soft and it bends and snaps. You cannot get a replacement hinge anywhere. I even tried Italy and France. Lofra won't speak to you by e-mail or phone. The next thing that happened was the element disintegrated in the ovan. These are the worst cookers on the market.
Posted on Dec 12, 2009
Need to reattach glass panel on oven door
You may have to contact Bosch directly to obtain a diagram and/or instructions.
Aug 27, 2017 | Bosch Ovens
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
How do I adjust the oven door so that it closes all the way? it closes all the way up but there is a 1/2 inch gap at the top.
You may have to replace the hinges. Especially if this is a whirlpool or kitchenaid model.
Oct 08, 2014 | Ovens
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
Euro maid sc1531 oven door dose not close at the top
Did you solve your problem???? Cause I am having the same problem :( I would really appreciate it if you could let me know Thanks
Jul 04, 2010 | Ovens
Bosch oven door does not close tightly, takes FOREVER to heat
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to:
www.bosch-spareparts.co.uk
or
www.espares.co.uk/bosch
Plz rate my solution.
Thankyou.
Jan 05, 2009 | Bosch HBL 745 Stainless Steel Electric...
Bosch hbn41 ..43
BOSCH COOKER HBN41/43 GLASS ON INSIDE OF OVEN DOOR SLIPPED AND SMASHED
Nov 21, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Oven door not closing correctly
I had the same type of problem. I unhinged the door then disassembled the door (it's really quite easy)
after you take all the TORX screws out the everything comes apart! Don't worry about the screws putting them back is a snap! Now that you have the door apart take the door hinges out of the inner door plate.
If you look at then closely they will have a slight bend in them. Pay attention to how they would have been positioned on the door! Simply bend them slightly I used the edge of a step! My door now shuts completely! I hope this info helps many of you having the same problem! If you take the time it really is amazing how easy it is to solve the door issue! Thanks to my buddy RON.
Aug 06, 2008 | Bosch HBL 435 Stainless Steel Electric...
Oven Door will not close properly
Don't buy Bosh. This is a common problem with them and they are not interested in a fix (ie a thinner door seal would help or adjustment to springs...
Feb 11, 2008 | Ovens
Kitchen Ranges Logo
96 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
