Question about RCA D52W19 52" Rear Projection Television
Tv will not power uppulled off back and found a part fried. part info top of part: S 5 17 1 side of part: orega 40351A-1 tv info model# D52W19 serial# E315C3OB1J tube: HV 29.9/33.0 kv type: P16LXLOORFA /HHA/BMB
  • 11 Answers
It might have 2 do with the internal outlet??
Posted on Sep 11, 2009
Where can I get a Orega 10799630 40351A-1 flyback for a GE d52w12 52in rear projection tv?
www.tvrepairworld.com has the replacement 265409 flyback kit listed under the RCA repair kits category. The 265409 is the flyback your model uses it comes with detailed installation instructions also.
Oct 11, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 52 in. Rear Projection HDTV-Ready
hi
i agree with you about the fire hazard and i had many feedbacks about this tv, mostly conscious about fire hazard too.
i would suggest that in light of owning a high-def tv, it would be significantly appropriate to place this in a room with airconditioning as to diminish the heat this hdtv produces.
about the issue of the hdtv turning off, if you suspect the transformer and other parts to be the reason for the tv to malfunction, why not bring it to a certified service center which handles GE hdtv. i would say that it may be a pain but as to think of the outcome, it may be worth it.
hope this helps.
Jan 21, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
RCA D52W19 52 doesn't power up and have a picture
press and hold the power button for a few seconds. it should blink some codes. does your tv try and power itself on a few times. does it not show power at all. need more info to determine cause.
Jun 13, 2010 | RCA D52W19 52" Rear Projection Television
Tv turns of and on 3 times but does'nt start up
The number 1 cause of that is failed capacitors CP150, CP120 and CP114. You can get that repair kit from www.tvrepairworld.com which also contains instructions.
Mar 03, 2010 | RCA D52W19 52" Rear Projection Television
How to Open a case
Acer Aspire RC900?
1) Computer off, unplug the power cable from the surge protector. Now unplug it from the computer (Power Supply)
(Unplugging the power cord from the back of the computer, while still plugged into the surge protector, may cause a voltage spike.
This could result in frying out the Power Supply, and may also fry out the Motherboard, Processor, Ram Memory, and Graphics)
2) Viewing the Acer Aspire RC900 from the Front, the Left side panel, is the panel that removes.
3) Viewing the Acer Aspire RC900 from the rear, look at the right side. (Left side actually, but now the computer is turned around)
There is a Cover Release Latch that is close to the outside edge, and towards the top.
It is whitish in color, and approximately 1-1/2 finger digits long, and half a finger digit wide.
(Universal measurement I figure. Using the Inch system it is approximately 1-1/2 inches long, and 1/2 inch wide)
Pull this Cover Release Latch to the right. (Towards the bottom of the computer if it were standing up)
You will see that this side cover, has a formed shape that you can put your fingers in, to pull the side cover towards the rear of the computer.
Pull the side cover back towards the rear of the computer to remove it.
Advise:
Your body carries Static electricity,
Static can fry out (Short Circuit) the hardware components inside a computer.
Touch the metal frame of the open computer case BEFORE you reach inside, to relieve your body of Static.
(Not shouting)
If you get up, walk away, then return, Touch the metal frame again.
Computer unplugged from power, you are safe.
Touch the metal frame of the open computer case, your computer is safe.
Have any more questions concerning this, I'm right here. Please post in a Comment.
Regards, joecoolvette.
Feb 07, 2010 | Acer Aspire RC900 (91.PJB6P.UE7) PC...
Tv not turning on
replace the flyback you need flyback # 259296 you can get the flyback at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Feb 27, 2009 | RCA D52W19 52" Rear Projection Television
Rca 52'' projection tv model p52937
Go to menu ,now to setup when in set up do you see convergence? If convergence is missing in menu it is a open fuse,only it does not look like fuse ,They look more like small square capaitors brown, they will be right next to flyback transfomer FL231 (3) of them in a roll it will be the middle one,you can take needle nose plyers and pull top up on fuses.
Dec 17, 2008 | RCA D52W19 52" Rear Projection Television
My rca d52w19 52 inch shoots a 2 inch flame from the back,WTF
You are talking about the screen/focus block it is bad sometimes they just split open call UED for replacement part 1-800-836-4920 or go to www.ued.com
Dec 05, 2008 | RCA D52W19 52" Rear Projection Television
REPLACE
does not sound like a rca part number .describe the part
Dec 20, 2007 | RCA D52W19 52" Rear Projection Television
Power transformer
How do I know if the transformer went on my tv I saw a rd light & then it smelled like wire burning & the tv shut off & won't go back on. Haier 40 inch hd
Oct 22, 2007 | Haier HL37 37 in. LCD Television
RCA D52W19 52" Rear Projection Television Logo
177 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
