Question about Montgomery Ward Refrigerators
Model number HMG219247B.....an old fridge and still keeping cool....the problem is the water collecting pan is filling very fast and it has never done that before....in the past month and a half the pan has over flowed twice!!!HELP...is this a problem that will lead to a bigger problem? im strapped for cash so i cant buy another one...can this problem be fixed?
hotuna
  • 288 Answers
SOURCE: Drain Pan overflowing
Refrigerators use different methods to eliminate the water, but they all use evaporation of some sort.This works,as most of the water in the drain pan comes from melted ice on the evaporator coil during the defrost cycle, and this is not very much. It sounds like you have excessive water in the pan. You stated the freezer/fredge is working properly. The condenser fan is running, I assume. Cleaning the dust off the coil will help the air flow. Most residential units do not have heating element in the drain pan. Your problem sounds like you are getting too much water in the pan. Have you noticed excessive ice in the freezer? Are the door gaskets in good shape. Does the unit have water and ice in the door? If so, where does the drain to, and has there been high usage of this?
Posted on Nov 11, 2007
  • 37 Answers
SOURCE: fridge does not cool
lo1972
Sounds like ice built up on the evaporator coils inside the freezer. thus hindering air flow to the refridgerator section. Is there ice build up in the freezer? This is assuming the temperature control didn't get changed inadverttily.
Hope this helps
handiman518
Posted on Jan 17, 2008
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
SolutionGuy
  • 331 Answers
SOURCE: condensate pan fills w/ water
Hi Packer,
Q: "OK. So, if the icemaker supply line has a leak @ the fitting, how is that water going from the freezer to underneath the fridge into the pan."
A: Only in the weirdest circumstance can this happen. There would have to be a crack in the valve body perfectly positioned so as to spray water directly into the drain pan and not any where else (like, the floor for instance). You'd also be able to see such a leak with your eyes and since you haven't mentioned it, I assume a bad valve or loose fitting is most definitely NOT the problem.
Q: "Problem seems to be worse in the spring and summer months when warmer."
A:
This kinda leads me to think that you may live toward the south eastern part or extreme north west of the US where spring and summer humidity is notorious. As temp's outside rise in this part of the country, the air is able to absorb much more moisture than cold or cooler air can. Each time you open the freezer door, cold air "dumps" out (stand in front of the fridge with bare feet and open the freezer door... you'll feel the cold air dumping). When this happens, warm (moisture laden) air rushes IN to fill the void left by the escaped cold air. When you close the freezer door the warm air is trapped inside and the freezer does its' job by promptly removing the heat from it. When the heat is removed (at the evaporator coil), the moisture in the warm air condenses out and forms as frost on the coils.
Every 8-12 hours, your fridge will go into its' defrost cycle to remove/melt the frost from the coils. The defrost cycle lasts for ~20 minutes or until the evaporator compartment reaches 55 degrees, whichever comes first. The melt-water flows through the drain, down a drain tube and dumps into the condensate pan where it is left to once again evaporate right back into the air from where it came. (Kinda like the whole "cycle-of-life" thing, right?) The drain pan is in the bottom of the fridge for a reason. It utilizes the heat in this area to more rapidly evaporate the water in the pan.
Now to tackle your situation. I have to be completely honest... I really don't know why your water isn't evaporating quickly enough. These drain pans are DESIGNED for "worst case scenario" amount of evaporator frost run off and should be able to keep up with it.
Q: "So, do you think it's just a matter of making sure the coils are clean for proper airflow to evaporate the water. If not, junk it?"
A: Yes to the coil and airflow question and No to the "junk it" part. I'm going to recommend as a solution to your problem an after-market part installation that is designed to fix just this situation. It's called a "Condensate Pan Heater". These are used frequently on high-end residential and commercial refrigeration units that generate A LOT of evaporator frost run off. The part I'm going to direct you to is a 15 Watt heater designed to be submerged in water (like an aquarium heater is).
OK, please follow this link to see what I'm talking about. First look at #1 and #2... you'll notice that they look like heating elements in an oven. You'll also note that they are a MUCH higher wattage than #3. The first two heaters are used in large, commercial equipment, whereas #3 is used as an after market residential "add-on" pan heater. It works by simply heating the water in the pan to facilitate a faster evaporation process thereby eliminating the overflow problem... simple, huh?
All you'll need to do to install it is to wire it in parallel with the condenser fan motor and place the heater loop in the pan. That's it!
If you require additional info on the exact steps for wiring this heater in, just let me know.
OH!!! I almost forgot 2 very important things. The first one is that when you install the heater, make sure that you HAVE THE REFRIGERATOR UNPLUGGED!!! The second thing was where you can order the heater... Follow this link to a vendor.
There ya go, Packer. If this solution was satisfactory, please don't forget to rate it as "FixYa".
SG
Posted on May 07, 2009
  • 212 Answers
SOURCE: Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Posted on Jun 24, 2009
Admiral model ltf2112ar
Leaking Refrigerators
3caed0f4-b74f-42aa-9c98-c6b216270899.jpgCan you send me a photo of this problem? I think there should be a bowl that should collect the water from defrost and drain the water down to a pan next to the compressor. If you are unable too place the picture here then contact me HERE I am here to help so please respond, Thanks Sea Breeze
Jul 31, 2013 | Refrigerators
Why is there water sitting in my fridge: water
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 05, 2010 | Frigidaire Refrigerators
Water collection in fridge
.you need to check the drain to make sure it is not clogged or blocked that would stop the water defrosted from you evaporator coil from draining into the drain pan.rare occasions the unit will stay in a defrost mode while trying to cool causing alot more water to be draining.good luck with your fridge.let me know how things go for you.
Jan 22, 2010 | Refrigerators
Water is leaking under fridge. The pan keeps filling up and overflowing
On some models, when the water dispenser is clogged the water will bypass to the drain pan. The water from the defrosted freezer also drips to the pan but it shouldn't fill it under normal conditions. Try to see where the water is coming from.
Sep 20, 2009 | GE Refrigerators
Overflow of condensation water
If you have a water filter the water will leak past the filter to the pan if it's clogged up and needs changing.
The defrost water drains to the pan, so if you are having a lot of frost it could fill it up. Excess frost can be caused by leaky door gaskets and frequent door openings.
The condenser fan near the pan should be running when the compressor runs to help evaporate the water in the pan.
Sep 09, 2009 | Haier HTE21WAAWW Top Freezer Refrigerator
Whirlpook ET21NK--Water collecting in crispers
Self-defrosting refrigerators turn themselves off to defrost once in each 24-hour cycle. There is a 'drip pan' under the refrigerator that catches water from this automatic defrost cycle. The pan is not very deep, so if the unit is leaning very much, water will run over the top of the pan. For this and other reasons, you should try to keep the unit as level as possible.
Aug 21, 2009 | Refrigerators
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
Smell and where is the drain pan
Find the Drain pan, it collects water and smell like sh**. I located the pan on my fridge, and proble solved it was undet the motor,
good luck
Nov 09, 2008 | Kenmore 64702 Top Freezer Refrigerator
Drain pan fills daily
does drain pan have copper lines it
Feb 12, 2008 | Viking VCSB483 Side by Side Refrigerator
Refrigerators Logo
37 people viewed this question
Top Montgomery Ward Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Montgomery Ward Refrigerator Expert? Answer questions, earn points and help others
