Question about Toshiba Televison & Video
I have the model number: TZ43V61. The red light is flashing off & on when I plug it in. The movers bumped it up the stairs. They must have broke something.
  • teamleader2 Sep 11, 2009
    My Toshiba Proj TV year 2000. Model TZ43V61 has a flashing light. I have already tried leaving the TV unplugged for days anbd it still does the same thing. I have read notes about a mother board problem. If I am looking at my TV from the back where would the mother board be located and what am I looking for as an indication of a problem with it. I feel like I am looking at the inside of a space ship!
  • 854 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Sep 11, 2009
  • 11,896 Answers
This is actually a very common problem with the power supply failing. Cheaper parts now days, capacitors overheat and swell and burn out. You can test power with voltmeter to see if it is working. Check any fuses to see that they are good.
Wont start where is the solnoid located
First off are there any lights lit on the dash ? Check engine , security ? Does yours have a red light flashing in the center top of the dash panel when you try to start the vehicle ? If so this is for PATS - anti theft system ! Do you hear any clicks when trying to start the vehicle ? This vehicle has a relay controlled by the PCM -engine computer !
Jul 07, 2015 | 2008 Mercury Mariner
HITACHI MODEL # 53UDX10B has a flashing red light and a buzzing sound
If it was transported likely the set was damaged--one of the three picture tubes used could have been damaged--the flashing light is the set trying to come on and the buzzing is related to whatever is bad.
It needs to be opened and inspected.
May 18, 2012 | Hitachi 53UDX10B 53" Rear Projection...
I have a Frigidaire Professional Series Stove. My red lock light will not go off. When I came down stairs it was on. I locked it & unlocked it and it's still on and my stove will not come on.
I looked up your model number and I would suspect a faulty door lock latch motor switch, part # 316464301.
It can be located my removing the back panel of the stove.
Aug 02, 2011 | Frigidaire PLEF398AC Electric Kitchen...
Will not power up. Red power light only blinks.
If you have sound and no picture, it's time for a new lamp.
In the manual check under LED indication, It explains the blinking lights, unless your outside at night looking up!
May 03, 2010 | Toshiba TZ43V61 43" Rear Projection...
My blank screen, red flashing light projection tv
Most likely the lamp has failed. The red light will blink with a pattern (number of flashes then a pause) You can refer to the users manual for information as to the nature of the problem by the aforementioned pattern.
Cheers
Jan 15, 2010 | Toshiba TZ43V61 43" Rear Projection...
Toshiba tz43v61 TV just died. No red light.
does it have a power strip on the tv stand? if so plug the tv into a wall socket.my power strip went bad and the reset button did not work
Jul 17, 2009 | Toshiba TZ43V61 43" Rear Projection...
Toshiba TZ43V61 43 in. Rear Projection... Problem
Try unplugging unit for 5 minutes, then plug in and turn on. If this works, your power supply may be going. However it is more likely that the bulb is gone, you can replace it yourself, but make sure you get the right bulb for that unit and take care in the installation of it.Go to the manufacturers website and look up your model and find out how to inspect and remove the bulb.
Bulbs can run for 140 to $300 and can be found on EBAY
Sep 28, 2008 | Toshiba TZ43V61 43" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
