Question about Kenmore Dryers
Dryer won't heat
Dryer won't ignite just replaced therm bar what else could be the problem
  • 110 Answers
OKAY,please always state exactly what kind of appliance you have.
you need to replace the coils which is located on burner, there are 2 black gas coil.
there is also a flame sensor on the left side of burner, get a meter and check for continuity.
on kenmores there is a white fuse on the back of dryer that goes bad.
Posted on Sep 11, 2009
Mod 417.94052500 won't heat
Have you tried to watch or listen to see if you hear it ignite and then it goes out or does it not try to ignite at all?
If it doesn't try to ignite at all, replace the igniter with this part.
If it ignites and goes out after a few seconds, replace the flame sensor with this part.
Oct 19, 2012 | Kenmore 77632 Gas Dryer
Dlg2522w gas dryer not heating, cleaned vent, reset, unplugged, still won't heat, motor replaced last year
I tired the reset on the over temp. Did not work. How do I check the igniter/ gas valve and thermostat?
Apr 26, 2012 | LG DLG5932W Gas Dryer
Gas dryer kenmore elite runs but won't heat
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I really hope this solves your problem. If it does, please come back to Fixya and rate my advice!
Jul 16, 2011 | Dryers
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
What to do when dryer runs but does not heat up
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse , coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Problem -
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go.
Answer ( most common ) -
Replace the coils on the Gas Valve.
Problem -
No flame, no igniter glowing at all,
Inspect igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter when dryer should be calling for heat.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Whirlpool LGR5636L Gas Dryer
Stopped drying replaced High limit switch on heating element and fuse/replaced therm on blower housing
Check 220v at wall and back of dryer. Must be across the line
220
It will run but not heat on 110. Check breaker
Check element for continuity
Jul 18, 2010 | Whirlpool LEQ9858P Electric Dryer
No heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 21, 2010 | Roper RGX4634KQ Gas Dryer
I replced ingnitor in my kemore gas dryer but not flame
Hello Friend, If the igniter is glowing continally and not clicking off, then your therm-disc is definately bad. It's attached to the burner shroud right across from the igniter. It reads the heat off the igniter through a little rectangular hole in the shroud. Replace and problem should be solved.
If igniter is glowing and then cools down and then begins to glow again in a repeating manner then I would say that the thermo-disc is good and you need to replace the gas valve coils. coils are easy to change, they are located on top of gas valve, two screws hold them in place. An easy fix.
Happy to help, Tim.
Jun 30, 2009 | Kenmore 75944 Gas Dryer
No heat
You may have a weak igniter. Just because the igniter glows, does not mean it is working properly. The glow bar type igniters are supposed to draw a certain amount of current in order for the gas valve to open. If the current potential is never met, the gas valve will not open. This is a safety feature used to prevent gas flow without ignition. The current readings for the igniters are as follows: Round style glow bar: 2.7 to 3.2 amps Square style glow bar: 3.2 to 3.7 amps If it is reading less than the required amperage, replace it. This may just solve your problem. Let me know if this helps you.
Sep 08, 2007 | Frigidaire FGQ332ES Gas Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
