Question about Kitchen Ranges
I am looking for some advise or a schematic for my Kenmore glass top drop-in oven/stovetop. The oven does not heat up at all and it has a digital control panel. The heater element is good. Thanks, Khan Powell
  • Khan Powell Sep 11, 2009
    Can you help me find the number you are looking for? I thought 629.4677569 was the exact model number.
    Thanks again,
    Khan
    I pulled the top off and total meltdown of the board is what I found. Before replacing I will ensure that wires to the element are not shorted together or to ground. Element does look new.
    Thanks a bunch,
    Khan Powell
  • 15,935 Answers
Please reply with an exact model # so we can assist you in finding the problem.
Likely a thermal overload fuse - but we'll need that model #.
Thanks!!
Posted on Sep 11, 2009
  • blueextc3221
    blueextc3221 Sep 11, 2009
    That is the number - it didnt appear in the title or thread for some reason.
    629.46775690
    Are you certain the elements are good?
    I have seen shorted elemnts damage the controller board in the ERC (Clock).
    Have you checked them with a multimeter?
    HERE is the replacement part - you will likely find strong visual evidence of failure when you remove the board.
    It will most likely have black soot near a certain component.
    The ERC is not hard to replace.
    Thanks for using FixYA!!
My Kenmore Elite Range Model C970 oven is not working, the stovetop is working great.
Model no. c970 xxxxxxx
there should be a 7 digit number after the 970 this is needed.
Now if it has a rotary knob to run the oven chances are it has shorted and needs replaced. if you are going to do this your self be sure to unplug the range because 220 volts will kill you no question.
Good luck.
Feb 13, 2015 | Kenmore Kitchen Ranges
Moved Kenmore electric oven (2 yrs old) and now neither the oven or stovetop heat up. The clock is set.
This may sound silly, but go check your circuit breaker and flip it completely off and then back on. Sometimes it does not completely trip and your clock only needs 120 volts to work which you have, but the heating coils need 240 volts. If you have an older house that has a fuse panel instead of circuit breakers you could have a blown fuse.
Feb 12, 2014 | Kenmore Ovens
Elite range
This pertains to model 790 Kenmore ranges, comprised of an oven door handle that is mounted on the door's glass.
Be careful when tightening the oven's door handle. Even slightly over tightening would likely result in the glass shuttering, because tightening the screws pulls in and thus presses the handle against the glass. This is a problematic design in my opinion. I'd rather give up on a couple inches in the width of the glass, than be unable to adequately tighten the screws fastening the handle and risk shattering the glass.
Aug 24, 2013 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
THE STOVETOP ON MY KENMORE ELITE IS SO HARD TO CLEAN. BOUGHT THE STOVETOP CLEANER AND I STILL CAN'T CLEAN IT UP.
Try using some oven cleaner on the stove top. It will break up the cooked on gunk.
Dec 22, 2012 | Kitchen Ranges
Oven doesn't heat up
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 06, 2010 | Kenmore 30169 Electric Single Oven
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Oven not working
you would have to check the element for continuity. Also the oven sensor could be suspect and should ohm out at 1180 at room temp. if both those are ok then main control is probable. without schematic it would be hard to say for sure..there may even be a safety fuse blown.
Jun 13, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Stovetop locked
look closely at the control panel there will be abutton marked, control lock, yuoll need to hold it down for 3 -5 secs, its achild lock feature, youre manual will explain if you still have it
Dec 07, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
