Question about HP Photosmart C7280 Printer
My 3 macs that are connected wirelessly can no longer find the printer--my kids each have iMacs that have worked fine, but suddenly none of them can find the printer on the network.
Suddenly, my 500GB Seagate external hard drive couldn't mount on my iMac. It was working fine till yesterday. I connected them to the Mac USD port, and the light in the seagate is blinking... Any
I can only comment generically:
I would try to uninstall the drive on the OS. Then re-start the computer. After the re-start, connect the drive and see if the drive re-installs itself.
If the error persists, then the drive is indicating failure. To absolutely verify if it has failed, take the drive to a store where there are MAC computers and try the drive on one of their computers to see if it works.
A continuous flashing LED on most devices where the LED does not normally continuously flash is an indication of a failure of the device. Some devices will flash an error code when designed to do so, and if possible.
Jerry G.
Aug 14, 2012 | Apple iMac 17" Desktop
I installed printer and was able to print wirelessly just fine from my iMac running 10.6 until today. Today the printer is offline wirelessly. If I plug in the USB cable it pops right up. How do I...
Restart the printer and have it reconnect to the wireless access point. Then, restart your Mac - cold boot. Then, have the Mac look for the printer again.
Jun 18, 2011 | Office Equipment & Supplies
New imac will not go through set up assistant why?
To fix: Go to the router admin page and in “Basic Setup” change the MTU .... Linskys does not support Mac products. None of their techs know Macs. ..... My new iMac suddenly will no longer connect to our wireless network. .... For mac users the network assistant is very helpful in helping u to set the networks up. ...
garrickvanburen.com/.../how-to-set-up-a-linksys-router-with-mac-os-x
Dec 03, 2009 | HP Deskjet F4100 All-In-One InkJet Printer
Just purchased an iMac computer for my HP DeskJet 880C
You can log on to the hp site and get the current driver/printer software for your printer. Get the mac os version and install via usb. Download and install then restart your imac... then attempt a print...
Should work fine with an iMac.
K
Sep 01, 2009 | HP DeskJet 880c InkJet Printer
I'm connected to the printer ok [HP Officejet 7410 All-in-One], but when I try to scan, I get an error message saying that it is not configured. I'm using an Imac Intel Duo/wireless connection. I've...
I uninstalled/put into trash everything on my system related to the original application. Emptied the trash. Downloaded newest drivers, etc. from HP site and installed on my Mac. Yahoo!!! Scanner works fine!
Jul 17, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Epson CX4700 printer/scanner won't connect to my apple network
maybe the twin setting chick to twin settings
go to start and you can find the twin setting try it
Jul 06, 2009 | Epson Stylus CX4700 All-In-One InkJet...
Mac router compatability Zoom ADSL X6
Remember it takes two to tango, so the issue may just as well be in the iMac as in the Zoom X6... Regardless of that, I had the same problem (PC works fine, iMac and PC both get flaky when the iMac is powered up). Zoom tech support suggested trying RF channels 1, 6, or 11. The router was using channel 10, changing to channel 11 calmed things down. Zoom said there wasn't anything magic in those numbers, but their testing showed those channels worked best with the Apple products.
Dec 26, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
Can't print from iMac to Photosmart 7350 printer
So all it really needed was a new cable? Glad you got this one worked out on your own, since none of us had gotten to it yet.
-John
Nov 12, 2007 | HP PhotoSmart 7350 InkJet Printer
HP Photosmart C7280 Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
