Question about Dell 924 All-in-One InkJet Printer
All in one printer scanner wont work in the usb ports on back....
Of pc although i have bin using it in the front usb ports why should it throw a wobbler oh i have tried reinstaling i was hopin to free up my front usb ports for other things darn it please help
How to scan to computer via USB?
If the scanner has a USB connection cord connect it directly to the PC and reboot the PC. It may then recognize the scanner and have a driver for it. If it is not recognized then you should download a driver for it from the manufacter's web site. Good Luck.
Mar 31, 2015 | Xerox Documate 3920 - Document Scanner
When i try to use scan mode it wont scan
Try a different USB port. If you have it plugged into the back of the pc, move it to the front, or vice versa.
Reinstalled drivers from Canon website still no go but you can go to Control Panel, select "Scanners and Cameras" and you should see your Canon scanner there. You can scan from there and use the scanning wizard.
You can try using ACDSee Pro to import image from scanner. It works ! or you can try other softwares too !
Feb 18, 2012 | Canon PIXMA MX310 All-In-One Printer
Can I connect a laptop to the printer using the USB port on the front of the printer
Yes you can Connect your Printer to your laptop using a USB cable and you need to Install the printer drivers software in your laptop so that your printer works If you have lost the Printer Drivers You can Download using this link http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp
Aug 20, 2010 | Epson Stylus Multifunction Inkjet Printer/...
My Acer Aspire L5100 computer has some problems with the graphic, or something similar. I have tried to use serval Web Cameras, but none of them works. I have also tried to hook my computer to a...
Sounds like you may have installed Driver Detective and it has taken over. Try removing any usb devices you no longer use or own first, then be sure you have the latest USB 2.0 drivers installed for your motherboard. Next try using ONLY the rear mounted USB ports for your Camera since some PC's have USB 1.0 ports located on the front panel. Good luck!
Mar 07, 2010 | Acer Aspire L5100 Refurbished Desktop PC -...
Installed the scanner program for bjc-80 onto a Netbook with only USB ports...wont recognize printer/scanner,,,help
Netbooks usually doesn't have PCMCIA capability. what you sould do is to disable the bidirectional function of the printer. To disable the bidirectional support You have to open the printers properties. In the "printers and faxes" map, right click on the printer and choose properties. then on the "Ports" tab, down below there is a tick mark choice with some text like: "Enable bi-directional support " you have to clear the tick mark!
Apr 25, 2009 | Canon BJC 80 InkJet Printer
Computer no longer recognizes my scanner
If you are using a multi port USB adapter that allows you to plug many devices into one USB port it may interfere with the scanner. Try uninstalling your Epson driver then download the newest one from the Epson website. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=All&x=27&y=14
Install the newest driver first then plug your scanner into a single USB port on the computer instead of the multi port.
Mar 31, 2009 | Epson Perfection V500 Flatbed Scanner
USB port problems with hp printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
Datalogic Dragon D101
You could use a ps2 splitter cable to connect both the barcode scanner and the keyboard to the pc. You would also have to use the correct scanner codes to ensure that the scanner is configured properly. Alternatively, you could try connecting the scanner with only the ps2 to usb and miss out the extension cable to determine if that is the problem. If the scanner is a ps2 wedge scanner, it will need reprogrammed with the correct scanner codes for usb.
Aug 28, 2007 | Datalogic Dragon D101 (902151240) Portable...
IBM Powerd USB not working
Are you using a USB 2.0 port?
Try a different USB cable.
PSC QS6000 Plus FAQ
Nov 28, 2006 | PSC QS6000
My XP Media Center PC does not recognise the scanner
Your USB ports on your computer may be bad. Do other devices work if you plus them into the same USB port? You can try plugging the scanner into another PC with USB ports. If it works in the other PC, then that points to the original PC's USB ports. You can try buying an add-on USB port or using other USB ports on the PC. If it still does not work, then there may be a problem with the USB port on the scanner, and the scanner itself may need to be serviced.
Oct 16, 2006 | Symbol CS1504 Handheld Barcode Scanner
Dell 924 All-in-One InkJet Printer Logo
26 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
