Question about Remington Sport & Outdoor - Others
A couple of my shotgun barrels "have pressed beads, which can easily be tapped by a gunsmith." If it's so easy, can someone just explain it to me so I don't have to chop off a finger for the gunsmithing fee?
  • wls009 Sep 13, 2009
    I want the pressed bead out and a threaded bead in.
    Sergeant:
  • 302 Answers
Pressed beads are not threaded, they are pressed in so please give more info on what you want to do to the guns...
Posted on Sep 12, 2009
Barrel for 410 shotgun
See if this site has what you need. If they don't, it's probably not available. Not saying it can't be fixed by a gunsmith, just it won't be easy or cheap if a ready made replacement is not available.
Firearm Parts Accessories Military Surplus Numrich Gun Parts
Sep 22, 2017 | Optics
I need a forend for a stevens double barrrel model 225
Stevens Shotgun Parts ' eBay
www.ebay.com > ... > Hunting > Gun Parts > Shotgun Parts > Stevens Shotgun Parts
Rating: 4 - ‎7 reviews
Results in Stevens Shotgun Parts ... Double Barrel 30" Side By Side Shotgun Barrel ... Stevens Savage Arms Model 77B 12-ga shotgun parts, trigger assembly.
Savage/Stevens/Springfield/Fox - Numrich Gun Parts
https://www.gunpartscorp.com > Manufacturers Need gun parts and accessories for SAV/STEV/SPGFLD? Look no further, Numrich has everything you need right here for SAV/STEV/SPGFLD.
225 DBL BARREL Accessories ' Numrich Gun Parts
www.gunpartscorp.com > Categories > Savage/Stevens/Springfield/Fox ManufacturerSTEVENS, Model225 DOUBLE BARREL, 325 DOUBLE BARREL, Product #995740, DescriptionFiring Pin, Price$24.85, Add To CartSold Out.
Savage Shotgun Parts, Stevens Shotgun Parts,Springfield Shotgun ...
www.gun-parts.com/savageshotgun/ ... Barrel Shoptgun Parts, Stevens Shotgun Barrels, Stevens Double Barrel Shotgun ... many Contract Gun Models. ..... #14 Bolt 340/840 30-30 or 225 5 Rd..
Shotgunworld.com - Find your shotgun parts here.
www.shotgunworld.com/parts.html Poppert's, Remington, Browning, Mossberg,Stevens,Winchester and L.C. Smith firing ... Remington, Mossberg, etc, Gun-Parts.com, Gun Parts for over 350 Models .... DOUBLE-BARRELED - A gun consisting of two barrels joined either side by ...
stevens double barrrel model 225 Google Search
Mar 06, 2017 | Optics
I have a Remington double barrel shotgun with trigger hammer and I need a stock made for serial # 216158 thank you
then you need to take it to a gunsmith that has a stock maker also . we can not assist .
Sep 30, 2015 | Remington Cycling
Sorry front sight broke loose can this be fixed Remington 1100 ribed barrel
I assume this is a bead front sight.
The broken stub needs to come out (a few are pressed in, but most are screwed in).
Then a new one can be installed.
Brownells has replacement beads and the tool to install them:
http://www.brownells.com/shotgun-parts/sights/front-sights/index.htm?psize=96
http://www.brownells.com/gunsmith-tools-supplies/shotgun-tools/shotgun-sight-tools/shotgun-sight-installers-prod879.aspx
May 10, 2014 | Optics
I bought a Remington 870 at Christmas time. The first time i shot it the shells are jamming in the gun. I took it home cleaned it and oiled it real good. Went and shot it again same problem. Either...
If the 870 is a Magnum model it should accept 3" shells. After making absolutely sure you have an unloaded shotgun, both chamber and magazine are empty, empty, empty, proceed with these few checks.
Assuming it may be a 2 3/4' model, have you double checked on the left side of the barrel near the receiver? There will be gauge and shell length stampings on the barrel. If you are jamming 3" shells in to a 2 3/4" shotgun you will get jams as you describe. Look at the empty shell casings if you have any and see if the shell appears to be damaged from the chambered and firing process. This could also indicate you have a improper shell length issue.
If you are shooting reloaded ammo make sure it has been properly re-sized, crimped and reloaded.
sloppy reloading of shotgun shells can cause jams as you describe. Improperly re-loaded shells can also cause leaks of bb's, (shot) in to the receiver and bore area.
Check for a loose bb. or bb's, (shot) in the receiver and chamber area. A lodged bb. in these areas will cause problems you have described.
Run your fingers along the barrel and visually check it for any slight bulge. If you detect or suspect a bulge do not shoot or load the shotgun until a gunsmith or the factory check the barrel thoroughly. If someone had loaded a 20, 16 or similar smaller guage shell in the chamber by accident and the gun was fired it will usually cause at minimum a stressed and bulged barrel. Many times a slight bulge in the barrel may not be visually obvious.
Most of the time if a 12 gauge shell gets loaded behind that one and fired you will have catastrophic failures, i.e. the gun can blow up and cause serious harm, blindness or even death in rare cases to the shooter. Shooters call this a "20/12" catastrophic failure. This type of accident is not to be taken lightly! this is why shotgun shells of different gauges are different in color normally.
Never ever, mix shotgun gauge shells in a pouch or box.
If you pump the shotgun too easily, (i.e. wimpy) it can jam up. Always pump, "rack" a shotgun with vigor. I'm not suggesting abusive action, just don't be slow or overly gentle with the pump action that ejects a shell and reloads the next one. Something related to this is if your action/slide bar is out of alignment or has become torqued out of it's proper alignment this will cause problems as you have mentioned. The action/slide bar is a long single piece of flat metal that is in alignment with the barrel and is attached to the front forearm of the shotgun. This is the flat piece of metal that actually makes the action open and close as you pump the shotgun. There is one on the left underside of the bore and forearm of the shotgun. When you pump the action you will easily observe it moving with your pumping action.
Check how the empty action feels to you. While dry-firing, (using an unloaded shotgun), does the action feel smooth or perhaps, gritty, sluggish, overly tight? If any of the later the you need to double check for debris, shot, excessive old lubrication, gumming of the action, a bent action/slide bar, etc. A normal 870 has a very smooth action.
Also, check the bore for any obvious nicks or obstructions that don't belong there. A good quality shotgun such as your 870 should operate best with very little lubrication. Excessive lubrication over time can cause gumming up of the receiver area. Also, improper lubrication products. Improper lubrication can cause problems you have described.
I am not a gun smith. I am simply an avid gun enthusiast. If you have any doubts as to anything that you observe while performing these basic checks on your shotgun, I strongly advise you to call the factory or take it to a local gun smith. Many gun shops will give your shotgun a courtesy check over and if you don't find a solution, many times they will within a few minutes. Do not be embarrassed to take the gun in to a gunsmith! Trust me, they will most likely treat you and you gun with respect and courtesy. Otherwise they won't be in business much longer.
If the gun shop fixes your problem make sure and purchase some shells and perhaps something else from them. We must support our small business firearms dealers and gun smiths
Hope this helps you!
Feb 02, 2011 | Remington Shotgun Mount 12Ga Lh, B Square...
I need a owner,s Manual for a SpringField 67eries D
Those shotguns haven't been made in decades, I doubt you'll find one easily. The best places to check would be gunbroker.com and auctionarms.com. you could also check local gun shows... but it's a long shot, I've never seen one in 25+ years of being a gunsmith.
Hope this helps, Mark the Gunsmith
Please leave feedback, Thanks!
Jan 09, 2010 | Springfield Optics
I cant open my lever action model 88 what can i do
Give it to me ! ...just kidding. I assume you have a cartridge in it and the cartridge is jammed in the cahmber. This can be a dangerous situation and I recommend you take it to a good gunsmith. If you are SURE that it is empty you can put a 1/4 " wooden dowel rod down the barrel and tap it on the boltface while having someone try to move the lever at the same time. Hope this is of some help.
Oct 03, 2009 | Remington Sport & Outdoor - Others
My model 88 Harrington and Richardson 12 gauge shotgun serial number AX505342 will not fire. How do i take it apart? Would i need a new firing pin?
You first need to **** the gun then remove the fore end and barrel and look at the breech face when pulling trigger , you will see if firing pin is there. If not u need a new pin as it is probably broken. Take it to gunsmith if u are not familiar with the workings and get a new pin .
Sep 27, 2009 | Sport & Outdoor - Others
Slide arm does not go completely forward
My Friend,
It seems you really have outdone yourself! The only thing I can recommend is to go to your local gunsmith ( a gun store could help in the location of one hint, hint) and have them disassemble the old gal. they will assess the damages done by your rookie mistake, and hopefully it's not too bad eh (she's a beauty she is). next time I STRONGLY recommend you take every precaution necessary to not damage you the guns or others. I STRONGLY recommend cleanings after every use, and please be sure to slide the slide arm all the way forward next time. You are lucky you were not hurt.
In my opinion though you may have broken a crucial spring, lock the slide gate shut, and/or dislocated the base of the spring. the shell not fitting I would say is a barrel issue with unburnt black powder, or a small dent in the barrel form the slide mechanism. BUT I HIGHLY recommend you do not try to repair this in your home or take my diagnosis as I have not seen the gun, nor am I a professional gunsmith.
Best Wishes,
KidKRYLON
Mar 22, 2009 | Winchester (026196062448) (20 - 60x70 mm)
Sport & Outdoor - Others Logo
41 people viewed this question
Top Remington Sport & Outdoor - Others Experts
Tom Chichester
 steve
steve
Are you a Remington Sport and Outdoor - Other Expert? Answer questions, earn points and help others
