Question about X2Gen Computers & Internet
My monitor keeps autoadjusting no matter what i do. really getting annoying. how do i turn this off?
  • awood_3379 Sep 11, 2009
    pressed it a bunch of times to try to free it up, didnt seem to change anything.
    Scholar:
  • 53 Answers
Maybe 'Auto' button simply stuck? Did you check that?
Posted on Sep 11, 2009
I bought a replacement monitor Acer model G206HQL. What do I need to get it on besides plugging everything in
Hello Norma
Well, there is not special things to have to turn on, your new monitor, it is just about the power cord, DVI cable or HDM and plug in the back of your PC, and thats it! turn in on!
Carl
* adjutst or autoadjust feature, is on, and colors
May 11, 2016 | Acer Computers & Internet
How to unlock the autoadjustment lock in my samsung lcd monitor?
Hi
If you use any kind of LCD monitors for example Samsung or LG or BenQ, you'll see each and every monitor has their auto adjustment of the monitor's resolution. Many people really find it difficult to adjust when it gets locked.
First find you auto button of your monitor
(It should be beside the power button)
Press and hold the button until the box disappears..
Now just press the auto button. It should have unlocked by now.
THANKS....
With Regards......
Vaishu
Sep 26, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
After reseting Asus vw192s I can´t have the normal color, It tries to autoadjust, for a second it is all fine and then turns into a darker colour, more blue. Don´t know what to do.
I have the same problem and you can fix it by entering in factory service mode:
1. Turn the monitor ON
2. Turn it Off
3. Press and hold MENU button and turn the monitor ON, led should glow orange
4. Press MENU again and service pop up will show up
5. Choice AUTO
Blue color on my screen vanished.
I have found this solution on polish forum.
http://www.elektroda.pl/rtvforum/topic1949561.html
Dec 30, 2009 | ASUS VW192S Monitor
Monitor auto adjust problem
It sounds as though the autoadjust button (switch) has stuck. Try tapping it a few times (the button, that is!)
Sep 24, 2009 | Dell E173FP 17" LCD Monitor
Samsung SyncMaster 720N ...
OK, I've figured it out! There's something wrong with the control chip, so if you don't have it under warranty, here's what you can do:
1. Turn off the monitor
2. Unscrew the face of the monitor
3. Remove the bottom part of the face from the backside, so you can see the chip
(the control chip is located on the face of the monitor, under the buttons)
4. You will see a small white connector about 5mm wide, UNPLUGG it
5. Put the small cable that you've unconnected under the front, so you can close the monitor back
6. Close the monitor and plug it back in
That's it. You won't be able to change your settings (they autoadjust anyway), but you won't have to throw the monitor away!
Peace.
Aug 01, 2009 | Samsung SyncMaster 720N Monitor
My dell desktop screen says AutoAdjust and then
install graphic drivers from following link
then cherck ,.
If you still face problem then when you power up the computer pressF8 key then enter in enable vga mode. then change screen resolution to 1024*768
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8300&os=WW1&osl=en&catid=&impid=
Jun 25, 2009 | Dell Dimension 8300 PC Desktop
UltraSharp 19' Screen will not autoadjust.
Start in SAFE mode (press F8 wile booting) and choose Last Known Good to see if it works in Windows DEFAULT setting.
My guess is that MSoft pushed a patch or SP to your box and IT replaced the dll your monitor was using.
Goto www.support.dell.com and DL the correct drivers again
Good Luck!
Let me know what you discover ;-)
Let me know if this fixes it
Mar 26, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Can't manually adjust color
I happen to have an Acer Monitor although a later model. It has 4 buttons....one of these is the auto adjust and one other is the window that has manual controls (so to speak). If you look at it carefully...(and it should stay on the screen for at least a minute - they believe you will do something in that timeframe)...you will find a set of icons at the top. These are suppose to be visually intuitive (and they are after you have used them once or twice)....anyway, if you really want to set your colors manually and or make other adjustments....alignment et al...you use the other buttons when the manual control screen is there. Experiment a bit and you will discover what does what. FYI...all "modern" monitors have this ability....the icons differ....but autoadjust does the best job in general....personal preferences and eyesight withstanding. Good luck....a small glass of wine sometimes helps the process and reduces the frustration level the first time around.
Jan 24, 2008 | Acer AL1916W 19" LCD Monitor
Monitor keeps going off.
try while it''s on to press the menu button and in the top right is the model number.
Jan 20, 2008 | Dell E173FP 17" LCD Monitor
Dark screen
Looks like we got disconnected during our chat session. I still think it may be those bulbs. If there was any kind of surge, it could have taken them out. I'm looking for specifics on the lamp though. If I find anything, I'll post it here.
Aug 31, 2007 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Computers & Internet Logo
32 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
