Question about American Standard Scala Bathtub Only AME-2664.202
Tub drain stopper won't close
I have the type of stopper in my tub that you twist and pull up at the same time to close. And then do the reverse to open. Someone was cleaning my tub and unscrewed the stopper all the way off. I screwed it back in, but now it won't close at all.
4 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: drain stopper won't engage to keep water in tub
Hi, looking at this straight on, you will see 2 screws going through the lever plug section. What it looks like on the inside, is a long brass rod connected to another brass rod with a adjustable section on it and a brass looking piston at the end. If you remove the 2 screws, grab hold of the lever and chrome plate and pull straight out and up to remove the assembly.No worry, nothing will fall in as it is all one piece. You can try cleaning the lever section up and add some wd-40 to it and this may help some. It sounds to me like the lever ball joint is worn out, so it is best replaced. Home Depot has them for under $20.00. Take the old one with you and if need be you can adjust the new one to the same length as the old one. It will keep hanging up on you believe me. Good Luck,
Shastalaker7
Posted on Nov 17, 2009
  • 105 Answers
SOURCE: removing a lift and twist type of drain plug to get at trap (scal
yes it can be changed without removing the tub, but you must open up wall, floor whatever it takes to be able to see all this drainage, as you can see, you can't change the parts from in the tub,.....good luck, cracklin joe
Posted on Jan 08, 2010
  • 2558 Answers
SOURCE: tub drain will not stay in up position
Hi it may well do clogged up in drain hole or it may have come loose inside try tighenting up
Posted on Feb 10, 2010
How to remove bath tub pop-up stoppers
Put the lever in the open position so that you can grab the stopper. After you get a grip on it, put the lever in the closed position and the drain plug and rocker assembly will pull out in a horizontal direction.
Sep 25, 2014 | American Standard 1583.470.020 Universal...
Water is draining from hot tub after its filled & dont know why
Hi Mary,sounds like your drain stopper may not be closing tight.Try removing the stopper by turning it counter clockwise,then jam a small rag in the drain as tight as you can to stop the water and fill the tub.If it still leaks then the drain plug where the stopper goes may have to be re-sealed or one of the jets may have a leak.If the tub is over a ceiling do not keep re-filling the tub you will cause major water damage to the rooms below.
Jan 05, 2014 | Leisure Time Filter Clean 1 Quart - 12...
I can not close my bath tub drain. the plunger is all internal and wont come out either. I tried a coat hanger to push it down. no go.
on most tubs the stopper is made to come out! does the stopper have 2 screws at the stopper lever. if it does just remove these screws and pull the stopper out slowly. when putting in a new one. have the same length as the old one, then slide it back in the drain fairly slow until it goes all the way in. replace screws and try it! good-day!
Aug 05, 2011 | Kohler Bath Drain KOH-K-7104
I stopper on a garden tub with a delta faucet. The stopper pushes down and locks to stop water. It takes a few tries pushing it down to get it to stop and hold water. What is the best way to fix it or...
In my part of the country, the type of drain you refer to is commonly called a tip-toe drain because you can use your toes to open and close the drain. Their locking ability diminishes over time and use, and eventually won't lock at all. They cannot be repaired, and must be replaced. You must remove the one you have to get the correct replacement because there are variations in the thread diameter at the bottom of the stopper.
You will need to use pliers large enough to grab around the white plastic underneath the top of the stopper that appears to disappear into the drain. Once you have the white plastic shaft secured with pliers, grab the very top (the chrome part) and twist it counterclockwise to remove it. Once that is off you will see a round piece of brass that looks like the top of a very large screw. IT IS! Using a stantard screw driver, again turn counterclockwise to finish removing the rest of the stopper.
A good hardware store should have a replacement for you. Be sure to match up the thread diameter at the bottom of the stopper.
To reinstall, you can reverse the steps or simply thread the complete assembly into place.
Aug 07, 2010 | Home
Removing bath drain
There are two types of tub drain stoppers for the delta brand - lift & turn and toe tap.
Lift and Turn:
The lift & turn stopper for the bathtub unscrews counterclockwise while in the full up position.
Toe Tap:
The toe tap stopper does also but if the cap may unscrew from it before the entire stopper comes out. In that case, there is a nut that is now exposed and can be accessed to unscrew the assembly.
If either of these is "spinning" without unscrewing, the threads are stripped and you would need to exert upward pressure while unscrewing in hopes of uncoupling this from the bath waste. If that doesn't work you would have to unscrew the bath waste flange from the drain pipe.
This will require access under the tub. I hope this answer the question for you. Thank you for using FIXYA. Jeff
Apr 09, 2010 | Delta Home
I can't get the drain plug off from it's base. It's supposed to be able to unscrew, it just spins. It's a Kohler tub. Does anyone have a clue?
Is it a lever handle drain or lift and twist lift and twist there is a small set screw on the popup you need to look for it on the stopper post only loosen it until you can pull off stopper or screw will fall in the drain
Nov 09, 2009 | Kohler 1257-GLA-0 Mariposa 6'...
How to replace kohler bathtub stopper?
If it is not a cable operated drain stopper, most have a knurled push pull knob on the top of the stopper. This knob should twist off to the left exposing a screw slot in the middle of the stopper. Using a flat blade screwdriver turning left until the stopper is free. If it is a cable opperated stopper, it is best to get a pro to replace it. If the cable is damaged and needs to be replaced, the tub will have to be pulled to do this job.
Sep 12, 2009 | Home
Slow water drain from Royal whirlpool tub. How to
under the decorative knob there is a screw,this is what holds the stopper in place.if not it should just unscrew.
Jul 29, 2009 | Home
DRAIN
I take it that you removed the drain trip linkage and stopper through the vent hole .
You must now run a small hand or small power snake the less than eight feet to open the drain.
You can also plug up the vent,tightly and  try a flat plunger on the tub drain .
Apr 20, 2009 | American Standard 1583.470 Universal...
Bathroom tub drain clogged
If you have a popup/ plunger type drain stopper controlled by a lever at the overflow, then, yes, it would be a great idea to remove that. They commonly add to drain problems.
Remove the two screws at the overflow plate (the one with the lever for stopping the water). Be careful that the gasket between the tub and overfow does not fall out when you fully remove the screws. Pull out the stopper assembly. You may have to jiggle it somewhat. Clear your drain some more and run a little water in it. Then replace the stopper assembly, making sure to keep the overflow drain lined up as you screw the plate back in.
You may consider replacing a lever stopper with a "twist and twirl" type.
If you do not have a lever assembly then you may have to use a small hand held snake to clear out the drain
Mar 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
American Standard Scala Bathtub Only  AME-2664.202 Logo
1,159 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
