Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Water leaking out of the bottom of my ge refrigerator.is there a tray that I need to empty? cannot locate one.
    President:
  • 744 Answers
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Posted on Sep 11, 2009
Excessive water in rear defrost tray on kenmore Elite bottom freezer refrigerator. Not leaking from ice maker?
You should never have to empty the defrost condensate it's supposed to drain through a drain hole and into a pain below the refrigerator where the fan blows over the water with warm air and re-evaporates it back into the air.
Leaking Refrigerators
Jul 19, 2016 | Kenmore Refrigerators
Subzero 650 Drip tray full of water and factory grease....
Grease or oil,,,,,its common for some oil but if its excessive it could have a leak "refrigerant leak"...Does it cool?
Jul 25, 2015 | Sub-Zero 650 / O Bottom Freezer...
My profile ge fridge leaks water and the water pools at the bottom of the fridge. What is the cause please. Thankyou!
There could be overflow at the deffrosting tray and the excess water is flowing out of the collection tank.
You can get access to the tank which is at the rear bottom . Open the sliding cabin to take the drain tank to be emptied.
Sometimes heavy frosting in the coil can result in this build up and cause the over flow.
You must take a look at the source of flow to finalise.
Please comment.
Aug 31, 2010 | GE Refrigerators
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Water leaks under veg bins.. Cannot tell where it is coming from. Accumulates slowly
This refrigerator look like mine (Picture).
Mine did the same thing. If it is the same then this is what I did.
Look under the there is a collection tray.
This tray collect the water.
At the bottom of the refrigerator (Inside where the water collect) is a cap.
The cap has cap would have holes or a slot that allow the little water to fall to the collection tray.
Mine has slots and was block up.
clean it out and that should do it.
The water should be able to fall to the tray at the bottom.
I do hope this help you.
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is leaking from under freezer side.
It should be next to compressor or on top of it. Water that comes from defrost is piped down to tray to evaporate back into the air. Sometimes the tray leaks or the drain line is missing the tray. If you could get the complete model number for your refrigerator I could help you a little better.Sea Breeze
Mar 21, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Water leaking from under refrigerators
if it is frost free then there may be a tray under the fridge that holds water from the defrosting ...maby it is full and needs to be emptied....it usually will just evaporate with out any problems but maby your isn't .....most times it can be seen from the back but a few will have it in front if you take the cover off ..
Hope this helps
Jan 12, 2009 | GE GBS20HBSWW 30" 19.5 Cu. Ft....
Moffat fridge leaks, every couple days water on floor at front of fridgee
The reason why it leaks is because the pipe that discards the water underneath the refrigerator is clogged and must be cleaned. The water normally drains through this pipe into the bottom tray of the refrigerator where this water deposit is supposed to evaporate during normal conditions. When the pipe is clogged then the water does not fall into this tray. Therefore, turn off the refrigerator (power off/ previous taking-out of all food of course!) than go behind the fridge and locate this pipe (plastic hose / if you have difficulty locate at least the tray on the bottom and than locate this pipe / to locate it you can see the little hole on the back bottom of the freezer this is where the water is supposed to get out. Put water into the hole and you can see where it falls). Clean the pipe and the problem should be solved.
Jul 09, 2008 | Refrigerators
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
The ice maker usually is an easily removable assembly, lift and pull or something like that. It may be the little water line has cracked, plastic don't like being cold.
Jan 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
152 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
