Question about KitchenAid KAWS850LE Top Load Washer
Replace lid switch
How do you remove the top of a Kitchenaid washer to get at the lid switch? The top is not hinged. Do I have to remove the control panel or the front panel or both?
  • Anonymous Mar 29, 2014
    I think lid switch is bad so I have to remove control panel and cabinet
  • 5,911 Answers
You will need to not only remove the control panel, but you will also need to remove the washer casing from the frame in order to acces the switch. It sounds intimidating, but really isn't that difficult to do. The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
Your washer is manufactured by Whirpool, so these instructions will apply. Most commonly, the lid switch is located under the washer casing along the right hand side of the lid. If the model number you have this listed under is correct, your switch is under the washer casing near the right lid hinge. The mounting screw(s) and ground connector are under the operator console. For clarification, you can refer to pcappliancerepair.com for some excellent exploded view diagrams to assist you. The lid switch is located under the "Top and Cabinet Parts" heading.
If you have any questions about this repair, or need additional assistance, please let me know.
Posted on Sep 11, 2009
KITCHENAID KAW750JQ4: WASHES FINE, WILL NOT DRAIN AND SPIN. IS THIS THE LID SWITCH OR SOMETHING ELSE?
If this a Whirlpool manufactured top loader, the most common cause of the problem you just described is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
If the model number is correct, the lid switch part number is 8054980 and costs about $20. The switch is located under the top panel adjacent to the right lid hinge. The hinge will have a rod that acts as the actuator.
If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Aug 12, 2010 | KitchenAid KAWS750L Top Load Washer
How do I get to the lid safety switch to replace it? model # 24722300
The controls have hinges. You flip up the controls and then pop the S-clips so that you can remove the case. Their are several variations of the design2000 washer console. This video shows how to access that switch from various machines:
This video shows a typical lid switch replacement:
Jun 12, 2010 | Kenmore 24032\24036 Top Load Washer
How do I remove the lid to a Roper RAX4232JQ top load washer? I need to replace the lid switch. Thanks
To replace the lid switch you need to unplug the washer first. Then remove 2 screws on either side of the control console. These 2 screws are on the back side of the control console and are on the far left and far right. They go in at an angle and are phillips head. They won't come out all the way, but loosen them enough so that the control console will flip up and backwards, it should not come off because it is hinged. Then you will see 2 brass spring clips, one on the left and one on the right that hold the entire case of the washer (top, front, sides, all wrap around) on. Remove those then the whole washer cabinet should remove. Be sure you unplug the lid switch located near the middle under the control console. Replace the switch and reassemble.
May 24, 2010 | Roper Washing Machines
Whirlpool top load washer won't wash after filling
The hinge on the left side activates the lid switch. The hinge will have to be repaired or replaced.
Use a putty knife or a old CD to slide under the control panel on the right and left sides,where the control panel front meets the washer top.
This will release the clips that hold the control panel to the top cabinet.
Fold the cabinet to the rear.
Unplug the lid switch in the top of the cabinet on the left side.
Remove the brass clips holding the cabinet to the rear panel.
The cabinet will come off so that you can access the underside for the hinge and lid switch.
Jan 07, 2010 | Whirlpool Washing Machines
Replace lid switch assembly kaws850
On the particular model you have listed, the lid switch should be located under the console near the right rear lid hinge.
You will need to use the steps in the link provided to remove the exterior case to access the switch to see how the actuator and lid hinge interface. You washer is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
This is a very simple repair, but if you have any questions along the way, please let me know. I hope this is helpful to you.
NOTE: If you have not pruchased a new lid switch yet, the part number is 8054980. It can be purchased at appliancepartspros.com for about $18.
Oct 30, 2009 | KitchenAid KAWS850L Top Load Washer
I need to replace the pump on Kitchenaid clothes dryer
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
I hope this helps. Please let me knwo if I can assist you further.
Vic
Jun 19, 2009 | KitchenAid KAWS850L Top Load Washer
Kitchenaid topload washer about 3 yrs old, started leaking from bottom, front. Checked hoses at faucet and washer, all tight no leaks there. Seem to be coming from under the front lower lip of washer.
it's the pump. release the control panel and flip back on hinges. pop the retainer clips and unplug the lid switch harness on top. pull entire white part of cabinet back and up..pump is front center.
Jun 14, 2009 | KitchenAid KAWS750L Top Load Washer
How do I replace the lid switch on kenmore top loading washer 23902? I can't seem to remove the back panel of the washer.
REMOVE THE 2 SCREWS ON TOP DOWN AT THE BASE OF THE CONTROL PANEL, SLIDE IT FORWARD A BIT AND LIFT IT UP IT IS HINGED IN THE REAR. NOW REMOVE THE TWO BRASS LOOKING CLIPS FROM THE TOP AND REMEMBER HOW THEY GO BACK UNDO THE LID SWITCH CONNECTOR(IT LOOKS LIKE IT GOES THROUGH THE TOP DOWN INSIDE). NOW GRASP THE CABINET AND PULL TOWARD YOU TILL THE BOTTOM DISENGAGES FROM THE WASHER BASE.NOW YOU CAN CHANGE THE LID SWITCH
Apr 17, 2009 | Kenmore 24032\24036 Top Load Washer
I need to replace lid switch on Kenmore washer.
remove trims from edges of control panel
remove screws from under trims
rais and flip control panel over backwards(hinged at top) do not dislodge air hose to level sensor
remmove brass clips from washer body top, not position for reinstall
disconnect lid switch connector cable
lift and remove entire body
turn upsidie down
change switch
reassemble in reverse order
~20minutes
Oct 02, 2008 | Washing Machines
Washer repair
on rear of console remove the 2 screws 1 on each corner..console lifts and rolls backif switch on right under lid remove clips on each side cabinet then lifts from back to front and lifts off if switch ic under left side of lid at rear make sure hinge scres are tight on left hinge and lid hinge is striking switch solid if not push hinge at curved section toward back of washer
Jun 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
KitchenAid KAWS850LE Top Load Washer Logo
299 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
