Question about Hamilton Beach Steam Storm 14560 Iron
Our HB iron (steam storm) base plate does not heat up. It worked fine until today. Is there a reset sequence?
  • Hamilton Beach Master
  • 43,501 Answers
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
I am having issues with my steam generator iron. I used it today and after heating up steam was pouring out from the screw on cap. Put on new green rubber ring and I can iron with steam until I sit on base...
I think lime and calcification are the culprit. Use some "CLR" at Home depot, can decalcify the build up on your irons pressure cap.
I have the Rowenta Steam Station. Love it!
Cheers,
Embroidery Services
San Diego, CA
Oct 25, 2017 | Rowenta DG5030 Iron
Steam generator wetting clothes
Heating plate has come detached from the tank. You have to remove the base and tighten the bolts on the heat plate. This ensures that the necessary temperature can be reached and thus steam rather than water comes out. Unfortunately the base is secured with security screws (6 point star with centre hole) so you will need to get one of these to fix it. They are same as used to secure number plates and can be purchased on ebay or at car parts shop
Sep 01, 2012 | Tefal Pro Express GV 8120 Iron
TEFAL STEAM GENERATOR GV8460 NO STEAM IRON HEATS UP
The water is heated by a metal plate that is bolted to the metal water tank, operating in pretty much the same way as a domestic kettle, the plate being the element. The plate is fixed in place by 8 or so nuts onto studs that form part of the water tank and heated by passing electrical current into this plate. Over time the nuts come loose and consequently the plate is not in full contact with the water tank. This results in insufficient heat transfer and a failure to consistently reach the required temperature to create steam. Ultimately you will need to remove the plastic base of the unit to access the plate and re-tighten the nuts. You will need a small 6 star bit with the centre punched out to remove the base as it is secured with security screws. These are readily available on ebay as they are the same as those used to secure number plates.
Apr 27, 2012 | Tefal Pro Express GV 8120 Iron
The boiler part is working fine but i have no
heatman101
Oct 25, 2009 | DeLonghi Stiromeglio Compact PRO 300 Iron
Tefal steam iron not heating up properly
That is probably because the contacts to the element at the base of the iron are broken.
To disassemble you have to remove the casing, then remove the steam pump at front top of iron and then undo the safety screw mounted on the front of the base plate.
Apr 22, 2009 | Tefal UltraGlide plus 1656 Iron
Sunbeam steam iron 4239 adjustable steam iron won't heat up
POSSIBLE CAUSES:
1. Blown fuse
2. Broken thermostat
3. Broken power cords
4. Broken heating elements
first of all check FUSE.
good luck...
Apr 06, 2009 | Sunbeam Irons
Morphy richards steam generator model 42271
is there a noise when u press the trigger? if not there is sometimes a reset button on the front of the base. failing that the problem may well be the solenoid which opens to let the water into the steaming tank which is repairable but can be awkward.
Feb 01, 2009 | Irons
Cleaning Ironing Steam Press
If it is not teflon coated sand it of with 400 grit sand paper. sand from front to back and it will create a nice grain and
this paper is so fine it will not scratch the surface. Sand it gently until the substance is completely gone. Do not do
this if it is teflon coated. Hope this helps you.
George
Jul 11, 2008 | Yamata PSP-990A Iron
Repair of Steam Iron
I just removed the two screws on the bottom of the cord winder and made the screws tight again, works like a charm.
Feb 17, 2008 | Irons
Hamilton Beach Steam Storm 14560 Iron Logo
515 people viewed this question
Top Hamilton Beach Irons Experts
Jim Thurston
Andrew Taylor
Andrew Taylor
richie46
Are you a Hamilton Beach Iron Expert? Answer questions, earn points and help others
