My LG TV flatscreen built in DVD player does not accept a DVD.. It says on the screen ''No signal.''
SOURCE: LG t.v is saying no signal on the screen for the cable box and a dvd player.
if the sky box is not registered with your viewing card, it will not show. if you want to check that the monitor is working plug in a dvd to make sure its not the monitor that is at fault.
Posted on Oct 17, 2007
  • 142 Answers
SOURCE: dvd player
SOME dvd players have a small hole in the front... just large enough for an opened up paper clip to fit into. If yours has this, unplug your machine and insert an unfolded paper clip into this hole and gently press the mechanical eject switch. If you don't have this feature, your only hope is to disassemble the bottom of your set and spin the eject motor by hand to remove your disk.
Posted on Mar 10, 2008
  • 13433 Answers
SOURCE: no signal
can you double check the signal cable that its going to the right place?
I beleave its hooked up wrong.
Posted on Jun 09, 2008
  • 111 Answers
SOURCE: There is a DVD stuck in the built in DVD player in
try unpluging set while tv is on and plug it back in it should come out
Posted on Feb 03, 2010
Testimonial: "Thanks a lot! It worked. Now I'm afraid to use the DVD player. Maybe I'll put in an old kid movie that we don't watch anymore and see if it works. "
  • 112 Answers
SOURCE: My LG tv (had since Nov) says no signal for the tv...
Try unplugging all inputs and the power cord from the TV for 5 minutes. This will allow the main board to reset.
Next, just plug in the power plug to the TV, power up the TV, and even though there is not a source connected to the TV, check at least three inputs and see what the TV will report on the screen for each input.
Next, turn off the TV, plug in all known working devices (Cable/Antenna, DVD, Blu-Ray, Cable/Satellite box, Game, ….) with a known working cables to the TV, make sure all the devices connected to the TV are powered up and on, and now power on the TV.
Now check to see if the TV is seeing valid signal for all the inputs connected to the TV.
If your TV cannot see any signal at any of its inputs (HDMI1, HMDI2, HDMI3, AVI1, AVI2, Component1, ……), then the main board has failed and need to be replaced.
Good Luck.
Posted on May 23, 2010
My lg 3d blu ray player will not sense when a disc is being inserted so I cannot play any dvd or blu ray disc.
Did you call LG? They told us to check with Samsung, the 3D-TV manufacturer. Samsung told us to upgrade the software on the flatscreen TV. We are about to do so. Will see if that helps. Am skeptical.
Dec 13, 2015 | LG Televison & Video
Logik L19dvdb11 tv/dvd problem.when selecting dvd screen display says no signal. Have tried switching on/off and reselecting input to dvd
Is the DVD player turned on when you select DVD for the TV ?
If not, there will not be a signal to detect.
Jun 07, 2014 | LG 32LD550 32 in. LCD HDTV
Trying to hook DVD player to tv
CONNECTION THRUE USB WORKS.
May 22, 2013 | Televison & Video
Phillips 47" flatscreen sounds still
If the TV menu displays your problem is most likely not the Tv , but is caused by the signal source:
Cable box or connections. Reboot everything test using other sources like a DVD player to isolate the problem.
Aug 20, 2011 | Televison & Video
I have a 32" flatscreen
Different video signals use different connections ...and we are speaking ONLY the video(NOT including the audio connections)
  • Composite Video (typically colored Yellow) uses 1 RCA connection on your TV
  • Svideo (uses 1 svideo connector on your TV) a circular connector with 4 pins in it
  • Component Video (typically colored Red/Green/Blue) uses 3 RCA connections on your TV
These are the common analog video signals....You cannot mix and match these and plug a composite (Sometimes called AV in menus) into component etc
If both your sources (wii/DVD) you want to use a component signal to your TV (which BTW is the best quality of the 3 I listed) you will need 2 component inputs on your TV
OR
run it through a high end receiver (that will act as your switcher)
OR
buy a small stand alone switcher, something like: http://www.amazon.com/4X1-HD-Component-Av-Selector/dp/B000BVIBGI/ref=pd_sim_sbs_e_4
settle for a lower quality DVD signal and use the Composite video out (yellow jack) into the Composite Video In on the TV and use the component for wii
I hope this helps,
Magoo
Mar 10, 2011 | LG 32LG30 32 in. LCD HDTV
Unable to get digital channels through dvd player
The built in tuner in this model LG is a standard not a digital tuner.
Apr 05, 2009 | Televison & Video
I have a LG tv/dvd combo. When I press dvd
The DVD unit is defective and must be replaced as an assembly. Not cheap.
Mar 29, 2009 | LG 32LG30 32 in. LCD HDTV
DVD input channel reads "no signal" when I try to play a DVD
First I would run a dvd cleaner in unit! Second you could take tv apart and look to see if signal cable is loose. the power wire seem fine as it powers up, and accepts an eject dvd.
Feb 28, 2009 | Proscan 32LB30QD 32 in. LCD TV
Televison & Video Logo
217 people viewed this question
Top Televison & Video Experts
Electro Med Services...
