Question about Ricoh Aficio GX5050 GelSprinter InkJet
Having problems with horizontal lines through transfer prints. Using ricoh gx5050 printer. Tried to adjust settings.
Have a Ricoh GX5050 s and have a Err990. The printer has leass than 500 copies on it and has been idle for a few months. Any suggesstions Please ?
That is a network or connection problem Has anything changed set up wise ckeck that you have the right driver installed.and check that the physicsl connection is correct
Jan 28, 2011 | Ricoh Aficio GX5050 GelSprinter InkJet
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Mar 25, 2010 | Ricoh Aficio CL2000N Laser Printer
Do you have the code to fix the registration on a ricoh 3260c'' I can not get it to register
if your talking about the yellow part of your image shifting, which would indeed be registration, you can do an automatic line position adjustment using the maintenance tab under user tools. if you keep having problems with this you may need a service technician to take a look. the machine calibrates itself by printing test patterns on the transfer belt, if its failing you may have a problem on the belt itself or the sensors reading the patterns.
Dec 12, 2009 | Ricoh Office Equipment & Supplies
My Ricoh 7300 is printing but all the color are not lining up
Try running auto color registration adj from user tools/menu(try it a couple times)
If this doesnt clear it up you will need to have a transfer belt and or transfer belt assy replaced
--Drew
Dec 11, 2009 | Ricoh Aficio AP3800C Laser Printer
Having problems printing legal size
Need more detail of the problem…when selecting print select print property and advance and select legal and not normal …let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 20, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
Ricoh Aficio MPC5000 -- need to find setting to reverse-combine a page (pages 1 and 2 were combined to make page A -- need to know how to make Page A (8.5X11) into page 1 (8.5x11) and page 2 (8.5X11)
user tools system settings copy setting is where you find all the relevant settings unless you are using a fiery then you will have to go into fiery settings for adjustments to be made
Jul 23, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
How to print envelopes aficio ricio mp c4500
On an MP-C4500, envelopes must be printed using the bypass tray (the fold-out tray on the right hand side). Put the envelope in face-down and tighten the two fences so the envelope is snug.
When printing the envelope, make sure the print driver is set for the correct envelope size. If envelopes tend to jam in the printer, try setting the bypass paper type for thick paper.
Nov 19, 2008 | Ricoh Aficio GX5050 GelSprinter InkJet
How do I put a password on Ricoh Aficio 2051 printer?
go in to user tools, system setting, key operator tools or admin. tools. there you can set up password.
Oct 01, 2008 | Ricoh Aficio GX5050 GelSprinter InkJet
Color adjust error
problematic machine. transfer belt damaged(white spots ) for temp fix try manual registration from menu
May 09, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio GX5050 GelSprinter InkJet Logo
158 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
