Question about Canon PIXMA MP160 All-In-One InkJet Printer
It flashes 2 and E and says error 300: The printer does not respond. Make sure that the printer is plugged in, powered-on, and properly connected to your computer.
2 Suggested Answers
  • 154 Answers
SOURCE: PixmaiP6700D:error#300. "The printer does
Error Code300--
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Mar 07, 2009
I have a Canon Pixma iP4000 with a baffling problem. When I turn it on, the lights flash in this pattern: 4 green, 5 yellow, 1 green, 5 yellow, the yellow light stays on for a moment, then the printer goes...
Follow these steps to reset the printer:
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
4.
Jan 27, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
I have the same Error Number 300 with my Canon MX850 - it is connected by ethernet cable to my wireless router. I can scan documents OK, but when I go to print it says that the printer does not...
Hi Daniel, I just had a quick look and other people here have posted problems regarding error code 300 on the MX850. Take a look here when you get a minute to see if any of the solutions posted help you out at all. It's a long shot as this link is for Apple users but it might point you in a direction you hadn't yet tried. All the best.
Sep 30, 2010 | Canon PIXMA MX850 Multifunction Printer
What is error code 300 for Canon MX310
Error Code 300 is displayed.
1) Cause : The machine not ready.
Action : Confirm that the power lamp is green.
If the power lamp is off, turn the machine on.
While the power lamp is flashing green, the machine is initializing. Wait until the power lamp stops flashing and remains green.
If the Alarm lamp is orange, an error may have occured on the machine.
2) Cause : Machine is not connected properly.
Action : Make sure that the USB cable is securely plugged into the machine and the computer.
* if you are using a relay device such as USB hub, disconnect it, connect the machine directly to the computer, and try printing again. If printing start normally, there is a problem with the relay device.
Consult the reseller of the relay device for details.
* There could be a problem with the USB cable. Replace the USB cable and try printing again.
3) Cause : Your machine is not selected in Printer on the Print dialog box.
Action : Select your machine's name in the printer on the Print dialog box.
If your machine name doesnot appear in Printer, follow the procedurebelow to check that the driver for your machine is installed on your computer.
a) Select Print & Fax Preferences in Printer.
In Mac OS X. v.10.2.8 or 190.3.x, select Edit Printer List in Printer.
b) Check that your machine's name is displayed in the list of printers and that the check is selected.
In Mac OS.X v.10.2.8, check that your machine;s name is displayed in printer list.
c) If your machine's name is not displayed, click Add(+) to add the machine. If you cannot add the machine, follow the procedure described in youe setup sheet to reinstall the MP drivers.
Nov 24, 2009 | Canon PIXMA MX310 All-In-One Printer
My canon MP610 printer is not responding after replacing ink
Try switch of computer and printer if not in printer list of printers. Unplug usb cable and start computer without computer connected. Them switch off computer again and plug in usb cable and then restart and after started switch on printer and Windows should find printer as a new connection and then you may need your driver disc to reset up.
Mar 17, 2009 | Canon PIXMA MP610 InkJet Printer
Canon mx850 series Error Number : 300 The printer does not respond. Make sure that the printer is plugged in, powered-on, and properly connected to your computer.
I had the same problem. I had moved my printer and when I hooked it all back up, there was an annoying clicking sound, the "in use/memory" light was flashing and there was no communication with my pc.
This is a tad embarassing, but if it helps someone, so be it lol. I had plugged everything in without looking.... my usb cable was plugged into the phone jack >.<.
Check all your connections.... then check them again ;)
Nov 08, 2008 | Office Equipment & Supplies
PixmaiP6700D:error#300. "The printer does not respond. Make sure that the printer is plugged in, powered on, and properly connected to your computer." I've checked all of the connections and...
Error Code300--
1. Turn off printer
Sep 05, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
I had this problem with a Canon IP5200R connecting to a Mac Book Pro running Leopard. I had setup the printer as per instructions using the setup utility, could print a test page using the utils but could not print from an app.
My solution was to delete the printer (System Prefs > Print & Fax) listed in the system preferences and then re-add by clicking the '+' in the pref panel, then selecting 'More Printers' from the popup window. If you have the printer connected to the network correctly it should show up and you can simply re-add it. My printing now works correctly.
Aug 28, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
CANON PRINTER PIXMA iP 8500 ERROR 300
Thanks for your posting in FixYa.
  1. Turn off printer
Dont forget to vote me.
Regards
Ellin
Nov 08, 2007 | Canon PIXMA iP8500 InkJet Photo Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
42 people viewed this question
old marine
old marine
