Question about Acer TravelMate 2300 Notebook
My acer laptop travelmate 2400, stops at the acer dispaly screen?
Whenever i on the laptop it goes on then it stops at the ACER display screen........i'm not sure what is wrong, cause the harddrive is ok.....
so could you please help me out..........not sure what to do? should i get a new laptop or is it something to do with the RAM?
LET ME KNOW SOON..........
THANK YOU.........
    President:
  • 2,600 Answers
When asking questions, please let us know what operating system you have, that goes a long way into us helping out....thanks you. You can try to boot into safe mode first, just to see if the laptop will boot into windows period. When the acer screen first appears, tap the F8 key repeatedly until you see a multiboot minu appear, if you di, that is a good first start...now scroll to the "Safe Boot with Networking" and select it. If the laptop boots into safe mode, I suspect something must have been downloaded like a windows update that may not have installed correctly and corrupted the Startup. If you booted into safe mode, send me a message and I'll explain how to restore the system back before you had the problems. If it doesn't boot into safe mode I might be able to help with that too, but I need to know the operating system.
Posted on Sep 11, 2009
I NEED ACER TRAVELMATE 3230 DRIVER FOR WINDOWS7
You need to post what kind of driver (video - sound - LAN...) for someone to help you. Or just go to ACER support and choose. gl
Jan 10, 2013 | Acer TravelMate 2200, TravelMate 3230,...
How do I adjust the screen brightness on my acer travelmate 2400
  1. Hold down the Fn key located at bottom left of your keyboard next to the Ctrl key.
  2. Adjust the screen brightness using the up and down arrow keys located near the bottom right corner of the keyboard.
Nov 14, 2012 | Acer TravelMate 2400 Series Laptop Charger...
I am having a ACER TravelMate 5730 laptop. For the past three or four months whenever I boot my laptop it gives a blank white screen. If I reboot one or two times it will be ok and works fine. Sometimes...
2 Solutions Possible.
The connection between the LCD Screen to the motherboard is not connected well and is causing the issues you are having.
OR.
The screen itself needs to be replaced because it defective.
Mar 16, 2011 | Acer TRAVELMATE 5730-6984 LAPTOP LCD...
Where is the wireless switch
On the front edge of the laptop by the right speaker, there is a switch just left of the speaker. That is the wireless switch, to the left of that switch is another and that is the bluetooth radio switch. Below is a link to the service manual that goes over every aspect of your laptop.
http://tim.id.au/laptops/acer/travelmate%204220%202480%20aspire%205600.pdf
Jun 24, 2010 | Acer TravelMate 2480 Notebook
ACER Travelmart 2400 makes loud beep sound
Here is the link to your service manual Make sure that you save yourself a copy to keep as a reference. Look on page 60, that is in the troubleshooting section and goes over the meaning of the beep codes. This will help narrow down the problem or even give you the answer you need.
http://tim.id.au/laptops/acer/travelmate%202400%203210%203220%203230.pdf
Oct 02, 2009 | Acer TravelMate 2300 Notebook
Acer travelmate 5520, when you start is white screen after 20 seconds and stops
Test the laptop with a external monitor see if you get any picture on the external if the external screen remains white then most likely the mainboard or the video adapter (in most cases build into the mainboard) is failing or has failed. One Possible reason could be overheating damage (the unit may not be overheating right now during the 20 seconds, it may have suffered earlier).
It could also be a poor connection between the display and the mainboard. but if the screen works for 20 seconds and then goes white its probably not the issue.
If the external screen works without any problems the issue is most likely your lcd screen or one of the boards inside.
If you are in warranty get in touch with your dealer or acer.
If you are outside of warranty get in touch with acer or a local repairer / acer cervice center.
Thanks,
Ekse
Aug 14, 2009 | Acer TravelMate 5520-5678 Notebook
Drivers
You need to install the display driver. Go to the Acer WEB site to download the drivers you need, make sure it is Windows XP or Vista version for your particular MODEL laptop. Use this link :- http://global.acer.com/support/download.htm
Jun 14, 2009 | Acer TravelMate 240 Notebook
Acer Travelmate 2400
Have you tried a dongle? Also, do you have the software installed correctly (check in the control panel/system/device manager). It maybe either or both of these. You may have a damaged bluetooth connection so if you have all the drivers correctly installed then a dongle would be the only other option as far as i'm aware
Mar 05, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
302 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
