CD player on PC keeps popping out. When I shut down the PC I have to hold the door closed to keep it from popping back out. And when I start it up in the AM it pops out and stays out. Sometimes it just pops in and out on its own during the day. What can I do?
  • 558 Answers
I had the same problem once turns out the techs told me i needed to update the device firmware.I did,,,,, it worked.... then it started to do the same thing again.So i replaced the drive.
Good luck
Posted on Sep 11, 2009
Door won t stay closed
The door catch is down or has lost a spring inside the hook
No simple fix but too replace door latch inside
In order to drive car with door that way no back seat passengers till fixed but use tie down ratchet straps from door to door inside handles
This will keep door shut then can drive vehicle normal till door catch is fixed its simple hour job to replace just buy parts have mechanic shop install
Sep 08, 2014 | 2000 Toyota Camry
Cd draw opens on power up and won't play a cd keeps opening after closing
This unit needs replaced it has seen better days sorry. The only thing you can try is shut off all power to the PC then unplug the PC and that cd drive from the rear of it. let the PC boot all the way up so you see your desk top. Shut it all the way down un plug PC hook back up the wires on the back of the CD player let it boot back up see if this stops it.Remember to rate my solution this is how i earn my achievements also testimonial Thanks much in advance.
Apr 22, 2012 | Dell Dimension 3000® Pentium® 4...
1996 Rav: Driver side door will not shut in cold weather, requiring me to hold the door closed while I am driving. Once vehicle warms up, door will shut. Very Very frustrating, when driving a short...
You have water in the latch mechanism. To solve the problem apply heat to the latch area of the door. I use a propane torch but a hair dryer or heat gun will also work. They will take longer though. Be careful with the torch so you don't burn the paint. hold it fairly close but keep it moving constantly. You will see the paint change appearance when you start to apply heat, keep heating until it changes back. At that point the latch will work. Close and open the door a few times and it should keep working for a while. The best thing to do is spray it with some WD-40 or RustCheck as soon as you get it working. Put the nozzle on the can and bend it right into the latch and spray around heavily. This should keep it from freezing up again. Hope this helps.
Feb 22, 2011 | Toyota RAV4 Cars & Trucks
The latch that holds the door closed is loose and keeps moving up when I try to close the door. I was pushing it down with my finger before pulling the door shut, but today it won't stay down, it keeps...
What are you working on? Ford made a number of different types of door latches over the years. Include some info on you specific vehicle in your post.
Jan 21, 2011 | Mercury Mystique Cars & Trucks
Dvd door keeps opening. Won't load dvd. Won't stay closed.Compaq laptop. Bought at Wal Mart this summer. Problem started a few weeks ago. Aaaaargh.
Check and make sure a disk is not stuck in the disk drive. If a disk is not stuck try closing the door and hold the door close, shut down the computer. Start the computer and hold the the door while the computer reboots. Hope this fixes it. djmax1966@yahoo.com..
Nov 08, 2009 | HP Compaq Presario R4000 Notebook
Cd door wont shut
this is possible but can lead to more frustration. The cd door usually has a plastic tab that depresses on a button or blocks the opto sensor to indicate it is closed. I presume that your cd door is missing this tab or the circuit that activates when the door is closed is faulty. Block the opto sensor manually using paper or keep the button depressed that the door tabe closes on. You will not need anything to keep door closed unless it is reqiured to play the cd then just use a brick
Aug 15, 2009 | GPX Karaoke Party Machine CD+G Portable...
Dorr will not shut down all the way
LOOK FOR THE TWO ADJUSTING SCREWA WITH A LITTLE PICUTE OF A DOOR OR THE WORDS UP DOWN.
TURN THE DOWN ADJUSTMENT ABOUT 1/4 TURN AND TEST - DON'T OVER ADJUST YOU WANT THE DOOR TO CLOSE SOLID ON THE FLOOR
HOPE THIS HELPS
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Cd door will not stay shut
There might be some problem in ur CD rom motor that control the tray eject,,so u have to take it to nearest service center..
Dec 09, 2008 | IBM ThinkPad R40 2722 Notebook
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Freezer Door Popping Open
Look at the bottom of the freezer door, there is a little plastic stopper there. It may be worn out or broken. When you close the door this is what holds it there. Start there first.
Sgt 48
Jun 17, 2008 | LG LRSC-26922 Side by Side Refrigerator
Computers & Internet Logo
196 people viewed this question
David Payne
David Payne
