Question about Sharp Office Equipment & Supplies
I have a Sharp Ux B700 that does not print. I have had it a couple of years. I odn't use it often. I have changed the ink cartridge but still no print (either in copying or report printing...
  • 2 more comments
  • blsouthern Sep 11, 2009
    i have tried two cartridges...doubt if both are bad. yes carraige moves from side to side and yes I have removed teh tape.
    any other ideas?
    no ink after print...no loose connection
    yes the second ink (replacement for the first) was fresh out of the package and fresh out of Office Depot. I have no way to determine if the contact points were damaged.
    i can return the last ink purchased in to the store, but it was teh last one they had (and office max didn't have any at all) which means i have to buy yet ANOTHER ink online (at almost $50 per) to test it out.
    any other theories?
    it appears to print...carriage moves back and forth and it sounds normal. No error message. but NOTHING appears on teh sheet, neither in copy mode or report printing.
  • 6,487 Answers
You need to do a depp clean on this printer since its acting like its priting and there's no error at all so the printer is still working and hopefully this is not yet a printhead problem . because after doing a deep clean and still not printing this is already a printhead problem...
Posted on Sep 11, 2009
    Guru:
  • 1,326 Answers
What is it doing when your trying to print??? Error, messages faults, noises?? Need more info to help solve your problem.
    Sergeant:
    Champion:
  • 208 Answers
Does the carriage move side to side when you print? If it does, you have a bad cartridge. If it does not, did the display show any error messages? Does it fax out correctly?
Just in case you have not checked, please make sure the protective tape on the new cartridge print head section is removed.
Good luck and please let me know how it goes.
  • Ancestor_22 Sep 11, 2009
    Are both ink fresh out of the sealed pack? They do dry up very fast if they are not sealed. Try removing the cartridge after it prints and see if there are any wet ink on the print head. You should see some wet ink if the cartridge works.
    There is a slight chance that the ribbon cable connecting the print head housing to the controller has a bad connection. Do you see any thing lose or damaged?
    Were the inks fresh out of the sealed package? The ink will dry inside of the head if the ink site unsealed for too long.
    One more thing to check is the golden connector inside of the print head housing and make sure it is not damaged.
My fax machine states 'fax RX in memory' and does not receive any faxes?
There is a Fax in memory. Either, the machine has a paper jam, is out of paper, or needs the ink cartridge replaced. Fix the above and the fax will print and the machine should work in Fax mode again.
For a unit with paper and no paper jam, try adjusting the paper stack and check if the unit picks up the paper properly. If you have ink in the cartridge, try cleaning the print nozzles and contacts. If a nozzle cleaning from the unit doesn't work, do it manually. Use a damp cloth (lint-free) and wipe in one direction only. Dampen the cloth with bottled or distilled water for best results. See your manual for pictures.
If you need the manual, try the Sharp site or http://www.retrevo.com/support/Sharp-UX-B700-Fax-Machines-manual/id/310bh149/t/2/ .
I hope this helps.
Jan 14, 2011 | Sharp UX B700 Plain Paper Inkjet Fax
No ink cartridge, need to replace how do I order the cartridge
The cartridge for that printer is the Sharp UX-C70B. Go online to any big box store and search using the cartridge number. It should cost you around $37 for a new cartridge.
Dec 14, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Printer error on sharp ux-b700 new cartridge?
Try to reinstall the cartridge and press NEW, then go through alignment process.
Dec 08, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
New cartridge; now won't print any document, fax or copy
It is not impossible to get a brand new bad ink cartridge. I've seen lots of bad ones.
Oct 04, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp ux b700 will not print
it sounds like either you didn't peel off the plastic cover the ink cartridge or it is a defective cartridge.
Thank You,
Mikey
Mar 18, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Check Cartridge Error - Sharp UX-B700 Plain Paper Inkjet Fax
I replaced my new $40 cartridge with another new cartridge and it worked.
Feb 23, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
UX B700
wipe off the contacts on back ink cartridge with a microfiber towel moistened with alcohol also wipe of the printhead (area where ink cartridge contacts the paper) then reinstall and try printing.
Jan 22, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
White "Stripes" across page
REPLACE PAPER AND THE INK CARTRIDGE
May 14, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
115 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
