Question about Dryers
I have a maytag dryer model MD-31(Atlantis) that had a 4 prong plug when I purchased it. Without realizing, I moved into an apartment with a 3 pronged outlet. I picked up an adapter that I thought would change 4-prong to 3-prong, but when I opened the back there are 4 colored wires, red with post, green AND white with one post and yellow with post. Since the adapter has no front or back & no colors I'm not sure how to fit the 3 pronged adapter on.
  • 304 Answers
Return it...and get a 3 prong dryer cord.
Place the middle conductor on the middle of the terminal block and the two outside conductors on the two outside terminals of the block. It makes no difference which way just so they are not on the middle terminal. Make sure they are tight but don't over-tighten to break the terminal block. The cord will probably cost less than the "adapter" did.
Good Luck
Posted on Sep 11, 2009
Why doesn't the timer count down? The dryer runs & heats but the Timer doesn't move. I replaced the Timer block but nothing changed. Is this related to a bad sensor?
go bak to 4 prong. why did u change it out? souns lik this isa 220 unit and not a 110? chk the book that came with the unit. lol.
Jul 22, 2014 | Maytag Dryers
Need to know the correct 3 prong power supply cord to use for a Maytag Atlantis dryer.
Hi fredmcmur227...
There are many different pattern plugs and recepticals.
It is impossible to tell you which power cord to buy.
What you will need to do is find out what the receptical for the dryer looks like and match the receptical with the power plug your going to purchase.
I will also include a link to show you how to hook up a 3 prong wire power plug.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Jul 11, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
I have a maytag atlantis dryer and im trying to hook it up to a 4 prong hookup and there is only 3 wiring connections on this dryer
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Dec 18, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I HAVE A MAYTAG GAS DRYER MODEL MD-31 BURNER GOES ON AND OFF INTERMITTENLY ANY IDEAS. THANKS JIM
The burner is designed to turn on and off intermittantly. It is controlled by a t-stat and a hi and lo temp sensor
Jul 14, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Moved dryer, hooked up wrong, not working now after re-hooked up
have you check outlet with a voltmeter or even checked breaker? Is your new rect' a 3 or 4 prong outlet? If you hooked up red's to black and black to reds it still should have worked. The 220 volt heating element is between the red's and blacks the 110 circuits would be between a red or black to white wire.
May 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I need to convert Maytag dryer from a 3 prong plug to a 4....
The instructions tell you how to do it.. Watch you tube video about it like all tech guys and girls do...
Feb 06, 2018 | Maytag Dryers
MAYTAG DRYER ELECTRICAL CONNECTION
how do you change a 3 prong plug to a 4 prong plug when the colors dont match on the wires to the dryer?colors on the wires are red white black and green. colors on the terminal of the dryer are a black and yellow tied together a white in the middle and 2 blues tied together. this is a maytag atlantis dryer. thankyou chad....
Jul 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
133 people viewed this question
Top Dryers Experts
