Question about Toshiba Sattelite A105-S2051 Notebook
I've got a lot of things running in my Task Manager. Do I need all of them? Which ones are necessary and which ones can be deleted?
  • 11,896 Answers
Copy and paste this link in your address bar to find out what all of them are for. You don't need all but there are some that are a need.
http://www.processlibrary.com/directory/files/ehmsas/
Posted on Sep 11, 2009
Testimonial: "Thanks"
I want to uninstall webroot and start over. I'm unable to remove aei.exe and other files. How can I accomplish this?
You may need to reinstall it to fully uninstall it. The uninstall may not have worked.
Have you turned off your computer since uninstalling Webroot? (Fully turned off, not hibernation mode) That may get rid of the running file.
To finish the job after uninstalling, simply delete the directory from the C: drive. (You may have to turn off and restart the computer before it will allow you to delete the folder.) A lot of programs that download updates on a regular basis will leave the updates on your hard drive even after an uninstall.
May 31, 2012 | Webroot Software Spy Sweeper with...
My task manager is not opening up. i am continuously trying ctrl alt delete. mys os is XP.
download Unhook.ini from norton site. Run it as administartor. It should get fixed.
Cheers!
Sep 06, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Task manager is disabled by administrator
So your task mananger isn't working, this may be a Virus, or simply some programs error? Anyway, If you have Windows XP Pro, there's a nifty user interface to directly edit the setting you want to repair. Click Start, then click Run and type in gpedit.msc: And press OK. This runs the Group Policy Editor. Once in the Group Policy Editor, expand in turn: User Configuration Administrative Templates System Ctrl+Alt+Del Options You should see the Group Policy Window, Double click on Remove Task Manager to change its setting: It should be enough to click on Not Configured and then OK and Task Manager is available once again. If you don't have Windows XP Pro, then you'll need to edit the registry manually. Click Start, then click Run, type in regedit, and click on OK. Expand these registry keys in turn:
HKEY_CURRENT_USER \Software \Microsoft \Windows \CurrentVersion \Policies \System You should see the key DisableTaskMgr in the right hand pane. Right Click on the DisableTaskMgr item: Click on Delete, confirm that you want to delete, and Task Manager should be available once again. One thing to note is that it's quite possible that if you're in an environment managed by a centralized policy, these settings may have no effect. Your IT administrator may set things up so as to disable Task Manager, and other things as well at the domain level. You'll need to ask them if this is the case.
Feb 17, 2010 | Microsoft Windows XP Professional
Windows did not pass genuine windows validation
friend this problem arises if u ve downloaded "windows genuine advantage notification" from windows updates .... for dis OS u ll have to reinstall it and den turnoff the automatic updates....
Feb 08, 2010 | Microsoft Windows XP Professional
I have the htc hero and i have downloaded the atk app but do not know how to use it
It is now generally well known in the Android community that task killers do not provide any advantages over the built-in task managing of the phone. A lot of people will start killer tasks that are vital to the phone's operation and may cause other parts to force close. So in my honest opinion, you don't need it.
But if you want to play with it, here are some pointers.
First off, if you downloaded the .apk file, you will need to copy it to your SD card. Go to the Market, and install the app AppInstaller. This will search you SD card for .apk files and give you the prompted to install onto your phone.
When you run the task killer, you will be presented with a list of running tasks (just like in Windows Task Manager). You can kill any task that is running, but like I said previously, killing something vital can cause problems. Kill one thing at a time, and see how it affects your system. Some tasks are necessary and will start back up on it own.
Good luck.
Feb 05, 2010 | HTC Hero Smartphone
Login screen comes up can see it fine, after login, screen goes blank
Do one thing. press ALT+CTRL+DELETE and go to task manager and go to file and select new Task(RUN) and explorer.exe and press ok.. it will come
Jan 26, 2010 | Computers & Internet
After running a search and clicking on one result the computer freezes. Can't exit IE or close tab. Can open tab but problem still exists. must reboot? help Running OS Vista with IE8
open the task manager by pressing CTRL,ALT and DELETE at the same time and selecting task manager, click the applications tab and select IE8, then click on end process. This will stop the need to reboot.
I have had the exact same problem and now use firefox instead, faster and simpler to use. Plus there are so many addons that you can use for downloading and speeding things up.
Nov 11, 2009 | Microsoft Internet Explorer 8
My CPU usage is constantly a hundred percent.
When system boots click start button > run > type in box "msconfig" without quotation marks. Click on "selective startup" Go up to the startup tab > click on disable all. Click on apply and ok, reboot. When computer reboots, see if the processor is still running at a hundred %, if not then one of your start up processes is the culprit. You can go back into msconfig and check just those processes that you absolutely need to start up, like a third party wireless controller, anti-virus, malware/spyware, etc., but most of those startup processes you dont need to boot up.
Sep 18, 2009 | Compaq Presario Notebook
Regedit,TM,Cpanel disabled
Dear sir,
It seems to be u r computer is attacked by spyware.
You can enable Your Task Manage By Downloading Task manger Fix and Registory Editor Fix
Download Task manager Fix
Download Registry Editor Fix
other wise Follow the Manual Instruction but is slightly difficult to user.
Method 1 - Using the Group Policy Editor in Windows XP Professional
Click Start, Run, type gpedit.msc and click OK.
Under User Configuration, Click on the plus (+) next to Administrative Templates Click on the plus (+) next tSystem,
then click on Ctrl+Alt+Delete Options Find Remove Task Manager in the right-hand pane and double click on it Choose the option "Not Configured" and click Ok. Close the Group Policy
Window Method 2: Change the Task Manager Option through the Run line
Click on Start, Run and type the following command exactly and press Enter
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableTaskMgr /t REG_DWORD /d 0 /f
Jul 10, 2009 | Microsoft Windows XP Professional SP2
Pantech Duo Camera
go to the applications and task manager and close some of the programs that are running and it will work
Jan 24, 2009 | Pantech Duo Smartphone
Toshiba Sattelite A105-S2051 Notebook Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
