Moving all over the place
Washer is moving all over the place
  • 11,896 Answers
Tub is out of balance. Make sure clothes are not piled to one side. If that doesn't work, you may want to have tub bearings and coupler checked for broken gasket.
Posted on Sep 11, 2009
How to keep an elongated toilet seat in place
If you mean that it moves about a bit ..... if you go on ebay you can obtain toilet seat retaining plastic nuts , they are quite wide and do offer a bit of grip. I have put rubber washers on the seat screw first, then some wide metal washers to compress the rubber washers and produce some friction ....then I have used the wide replacement nuts to tighten the assemlage of bits so they are applying some force and keepin the seat in place
worked for me and my daughtert so may work for you
You just need to produce sufficient friction to stop it moving
Jul 05, 2015 | Home
Samsung HE Top Load washer always going off balance. Only 4 months old and Ive had trouble since day 1.
Open this link and chat with Samsung technician .
('http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=N0000651&model_name=WA45H7000AW/A2&model_cd=WA45H7000AW/A2','',800,600)
Jan 04, 2015 | Samsung WA422PRHDWR Top Load Washer...
Windshield washer won't work when tank is in place, lift and move it 1 inch and works like a champ. doesn't matter how much I wiggle wires and connections still won't work when tank is seated in place,...
i do believe that this model has a pump thats built into the tank sounds like you need to remove this pump and clean it of an obstruction I think a spring washer retains it into tank housing carefully pry this spring washer out and pump should slip right out completley clean pump and tank with soap and water carefull to not get electric parts wet
Oct 25, 2013 | 1991 Ford F150
Lg washer wm2277hb detergent drawer wont open?
I one time had this problem and it kicked my ****. there is no easy way to get in there to adjust the insert. iI just kept moving it in and out. even jostled the washer to move it in place it took a wile. good luck!
Jan 18, 2010 | LG WM-2277HW Front Load Washer
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
We moved the washer to a different room. When we
Was the place where it was the original laundry room. If so outlet was probably a dedicated line not hook to any other outlets. Now you moved and plugged into outlet that is not dedicated other items are probably being used on same circuit or breaker is to small, should be 20amp.
Jul 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer unbalanced on final spin, cannot stop the unbalance
Hi Sparky,
The reason it's out of balance is because the skate plate shoes are worn out and need to be replaced. You'll have to access the washer in order to do this. There's a video available that shows how to do it.
After you have opened up the washer you'll see that the tub is sitting on a three legged pedestal. The shoes are in between the skate plate and the top of the pedestal. Here's a picture (and part number) to illustrate...
Do one shoe at a time by lifting the skate plate off of the pedestal about an inch or so and wedging it there (I use a hammer handle as a wedge). The shoes simply snap into place, so the old ones will have to be snapped out of place first. Use another hammer and tap the shoes out of their sockets from underneath.
NOTE! ---> When you place the new shoe into its' place DO NOT try to snap it in!!! (if you do, you'll break it) Just let it rest in it's place for now. Remove your wedge and allow the full weight of the tub to sit on it. Then move on to the next shoe and repeat.
After all 3 shoes have been replaced it's time to snap them in completely. Do this from the top of the tub. Using your body weight, press down on the tub from above on all three corners (where the shoes are located). This will apply even pressure to the top of the shoe and keep it from breaking. You should have all 3 snapped in now. Use a flashlight and look underneath to verify (you should see the tabs of the shoes poking all the way through the pedestal).
Now all that's left is to rebuild the washer cabinet and start some laundry!
SG
p.s. I know it sounds like a lot of work, but this job can be done easily within an hour and the parts only cost ~$12.00!
Apr 01, 2009 | Kenmore Washing Machines
Washer is shaking violently when it is time for the spin cycle
Check to see if all shipping blocks and bolts were removed. Refer to installation and setup instructions for your model.
I once moved into an apartment furnished with washer and dryer. The washer had worn holes in the vinyl flooring and a neighbor said the previous tenant made her son sit on the washer to hold it down. I investigated and found the shipping bolts were still in place. The tub, which is supposed to be able to swing, was rigidly held in place, so the entire machine danced around the room!
Jan 10, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Can't adjust 2004 Ford Expedition headlight
I had a similar problem on my 04 expedition. I just bought it and the headlights were aiming too far down. A rather larger gap was noticeable between the headlight and the hood. The so called adjustment bolt did nothing. I removed the headlights and found 2 issues. On the adjustment bolt there is a washer. Make sure when you re-install the headlight the washer sets on top of the plastic slot and is visible when looking down behind the headlight. Without the washer being in the correct location it will not tighten the headlight in place.
Second I found the adjustment bolt adjusted nothing. It merely tightened the headlight in place. What I had to do was to loosen this bolt and physically move the headlight into place and the re-tighten the bolt. Hence the slot is the adjustment. Turning the bolt CW or CCW did not move the headlight.
I tried several things trying to figure why the lights would not move until I realized I could move the light with my hands and tightened them in place using the adjustment bolt.
This may not be your issue but I found the owners manual instructions to be useless.
Dec 28, 2008 | 2004 Ford Expedition
Moving a Kenmore front loading washer
Hello! if youre not moving the washer a great distance it will be fine.The braces are for shipping,I deliver washers without the shipping pins all the time. Short distance should be fine,the braces keep the tub in place.
Dec 17, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
