Question about Toshiba Satellite M35X-S111 Notebook
Power on but no screen oor hard disk motion
Toshiba Satellite M35x-s11 power on, hard disk light flash on/off but no screen the cpu fan turns on then off. The power on light stays on.
  • Toshiba Master
  • 3,051 Answers
Hello there:
i would suggest using a spare monitor and connect the cord that would normally go into a computer and connect it to the laptop and then plug in the power cord for the monitor and turn on the computer if this works and everything is ok then you know that the laptop screen may be faulty or there may be a loose connection somewhere ok?
best regards michael
Posted on Sep 11, 2009
Toshiba Satellite black screen driver error
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sep 23, 2012 | Toshiba Satellite M35X-S111 Notebook
I have a Toshiba satellite m35x s11 and the screen stays black the blue led the i hear the hard disk go then stop it doesnt
Were you able to get the toshiba bios screen? Well, if you're able to get the toshiba splash screen it means that your laptop is okay, Your problem is connected to windows.
Dec 30, 2010 | Toshiba Satellite M35X-S111 Notebook
I have Toshiba satellite M35X-S163 when press power cpu fan start and hdd run for 2-3 seconds then gose off nothing on the screen internal or external ; in addition no battary charging . battary and the...
in the pic that is not m35x that is m30 ... if u have m35x ...and no display open the laptop near the power jack there is maxiam ic ... jsut heat that ic.. hope that will work .. if not let me know thanks
Oct 08, 2010 | Toshiba Satellite M35X-S163 Notebook
My toshiba m35x-s161laptop has issues
may be the procesor unit(cpu) is too bot because a dust.....
Mar 06, 2010 | Toshiba Satellite M35X-S161 Notebook
Toshiba satellite m35x-s114 boots to the toshiba screen then doesn't do anything else. Even with the f2 or f12 option nothing happens. I hear the fan (I think it is the fan) then no sound at all. I have to...
Try getting to the bios screen, if you can get to the bios screen then I would imagine the hard drive has failed. If it is hanging up at the toshiba splash screen and not allowing BIOS access, then I would lean toward a motherboard failure. Are you attempting a boot from the windows disc?, is that why you are trying F12? I have seen my share of these Toshiba M35's just give the Toshiba splash screen when there has been a motherboard issue. Changing out the main board will fix this particular problem. I had not found another solution for it.
Nov 27, 2009 | Toshiba Satellite M35X-S114 Notebook
Black screen with flashing cursor
It may be because of your hard disk damage or OS problem. Try to install a fresh copy of XP from a cd. boot from XP cd and install .
Apr 06, 2009 | Toshiba Satellite M35X-S311 Notebook
Need to replace toshiba satellite m35x-s163 fan
Unless you are really comfortable with opening laptops to upgrade parts, I won't recommend doing this. Rather get a notebook cooler. It does the job of cooling the notebook pretty well.
Nov 05, 2008 | Toshiba Satellite M35X-S349 Notebook
No power up on Satellite M35X-s111
Heres the fix:
This requires access to the cpu and heatsink, remove the keyboard and palmrest to access the motherboard, I think you have to remove the screen too. Remove the heatsink and cpu. Reseat the cpu, heres the kicker, press firmly on the center of the cpu while turning the locking screw. Pressing the cpu hard, allows the locking mechinism to get a good bite. Turn the locking screw hard into the end of the turn. Hook up the heatsink and set it back on top of the cpu. Press down on the heatsink over the cpu, fairly strong pressure.
Now test the motherboard, use just cpu, heatsink, memory, power button board and cable and external monitor, you can use your screen instead by just hooking up the cable to motherboard, leave the screen laying flat on the table. Now push the power button with one hand and the other is still applying pressure to the heatsink, no you dont need to screw it down yet. Keep reseating the cpu with varying degrees of pressure if you dont get it go the first time.
The trick will be to get it all assembled with the same results.
There seems to be a problem with the cpu seating correctly, it must come loose and the laptops exhibit the symtoms of no video. It might even be neccessary to insert a wafer thin piece of copper or something in between the cpu and heatsink if the heatsink doesnt apply enough pressure to cpu to keep it seated deep enough to run the computer.
Jun 29, 2008 | Toshiba Satellite M35X-S111 Notebook
PROBLEM WITH MY SATELLITE M35X-S111
Check to see if your Display is bad or Video is bad..
To Do This....
Plug an External Monitor into the laptop serial port..Boot the laptop and use the function key plus F5 to boot to external screen... If you see your PC running on the external screen it is a Video card/chip problem.....
Do your lights run ..the Power Light/Battery light/ hard drive light??? Do you hear the hard drive spinning??
May 19, 2008 | Toshiba Satellite M35X-S111 Notebook
Toshiba Satellite M35X-S111 Notebook Logo
359 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
