Question about American Standard Cadet/Ravenna Round Front Toilet Bowl, Linen
Toilet keeps filling tank every 10 minutes doesnt sound like its leaking no water around toilet or on floor still flushes and opertes..just water trickles on every 10 minutes or so to top up
    President:
  • 2,600 Answers
If there is no water on the floor then the water is leaking down the main tank drain. Take off the tank lid, turn off the water supply to the toilet. Fllush as much water out as you can. Look at the main drain, sometimes if the flapper valve is connected with a chain, the chain can get caught between the flapper valve and the drain hole, the flapper valve is pliable so it tries to seal around the obstruction but can't always do it. Make sure there is obstruction, that the flapper valve is not out of shape or old and non-pliable and that it lines up with the drain hole and doesn't get "hung up" on anything.
Posted on Sep 11, 2009
Re. Duravit Happy D toilet (tank No. 0929100005)
Remove and clean the flush valve and the flush valve seat(it is the flap that opens up to allow water to flush the toilet). Once the edges of the valve and the seat are cleaned, possibly with "0000" grit bulldog steel wool, it should not leak anymore. To make sure it is not leaking, once tank has refilled completely, put some food die in the tank. If, after 10-15 minutes, the water in the toilet bowl is colored, you have a leak from the flush valve. Replacing the flush valve is very easy - just bring the old one with you to the hardware/plumbing store and ask for a replacement. Blessings and good luck!!
Sep 23, 2017 | Duravit Home
Water leaking onto the floor after flushing
check around where the tank meets the bowl and see if water appears when you flush and if so you need a new tank gasket. If it's coming from where the toilet meets the floor you will have to change the wax seal underneath. That happens when the toilet rocks and ruins the wax gasket.
Oct 08, 2014 | Home
Kohler one piece toilet. it is leaking around the bottom of the toilet but if I put the water in the back of the tank myself, it doesn't leak
if its leaking from bottom of toilet on the floor. its the wax ring that may be bad, if it does this when flushing it is either cracked or the wax ring under toilet is bad.
Mar 26, 2012 | Kohler Home
My toilet keeps leaking water and then fill ups on its own. Where could the leak be how do I fix it? Also I have to hold down the flush lever awhile for the toilet to completely flush. Can this be fixed ?...
If you are not getting puddles on the floor then it is probably the 'FLAP" that holds the water in the tank. It is the rubber part that is connected to your handle. Any hardware store will carry that part since it is an item that will fail, especially in hard water. It is probably the cause of both problems.
Jul 25, 2011 | Eljer & Titan Elongated Toilet Bowl
I have a problem with the water in the tank leaks past something, maybe the flush valve assembly and the tank has to refill about every 25 min. I got a new flush valve assembly and changed it and put...
Hi keithn60...
I had the same problem one time with my toilet tank, the answer is to put some silicone on the seal washer between the take and bowl assembly and to use a level on the tank to tighten it just enough to be level and not leak.
Please take time to rate me
Jun 27, 2011 | American Standard 4021 White Cadet 3...
Toilet fill runs periodically works well but wastes water
Sounds like your flapper is leaking causing the water in the tank to lower until it triggers the fill valve. Replace the flapper (they're cheap and wear out easily).
Jul 03, 2009 | Kohler Toilet - One Piece with Ingenium...
Toilet Question
Yes, it will run up your bill! Sounds like the float is hanging up. Take tank lid off and flush, watch the float and if your tank fills quickly but does not stop, bend the float arm to angle the float down further, this should allow your water to stop coming in much quicker. The other possibility could be if the plug at the bottom does not seal correctly after flushing, if so, the water will leak until the plug sits down all the way.
Apr 11, 2009 | Kohler K-4709-96 C3-200 elongated toilet...
Toilet sounds like it is flushed or water filling up in the tank.
if the toilet has a 'flapper' is there slack in the chain connecting it to the flush arm? The flapper life is usually around 4 years or so - replace it if older.
Mar 13, 2009 | American Standard Prairie Field Single...
American Standard Cadet/Ravenna Round Front Toilet Bowl, Linen Logo
1,499 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
