Question about Nextar X3-03 Car GPS Receiver
How to repair intellinav.exe error on nextar x3-03 can't use the navigation
SOURCE: intellinav.exe application error
I HAVE THE SAME PROBLEM. FROM WHAT I CAN TELL THE UNIT HAS TO BE SENT IN TO BE FIXED. FUTURE SOLUTION TO THIS PROBLEM IS NEVER EVER BUY SOMETHING WITH THE NAME NEXTAR ON IT............
Posted on Jan 13, 2008
Did you try the switch on the back of the GPS? Turn off on the front, turn the switch on the back off, then on. This has worked for me numerous times.
Posted on Jul 02, 2008
rockitman187
  • 2559 Answers
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviors are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation
(such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with Safe SEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offense, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur.
WHY are you using IE6 still??? Upgrade to IE 7 today!
...and that should have now resolved the 0xC0000005 error for you!
Please rate this fixya
Posted on Jan 29, 2009
  • 3 Answers
SOURCE: I have Nextar item#x3-03 and need map update
I have this gps also, There are no map updates...sorry :(
Posted on Mar 28, 2009
  • 16 Answers
SOURCE: Are there any map updates for the nextar
Check the Nextar website. They did recenlty release a 2009 map update, but if your GPS is not listed as compatible, it's not going to work.
Posted on Oct 09, 2009
APPLICATION INTELLNAV.EXE HAS PERFORMED AN ILLEGAL
Was the SD map card specifically designed for your GPS model number?
You'll want to double check since map cards are not universal. Even if you load updated IntelliNav maps onto an SD card, it usually just crashes.
Sep 23, 2009 | Nextar X3-03 Car GPS Receiver
Map or firmware updates for Nextar X3-T GPS ???
You should probably just buy a Garmin.
If you did want to update the maps you need to find the software company that makes the map (usually IntelliNav or Odyssey) and then buy it from them and PRAY it works by loading the new map data directly on your SD card.
From experience, this makes your GPS crash a lot and make sure you back up your SD card before you even attempt this.
Sep 15, 2009 | Nextar X3 GPS Receiver
Where can I download the intellinav.exe for my nextar X3-08? Nextar wants me to ship it to them and pay shipping both ways.
in the user settings there is an option to reset to default/factory settings. follow those procedures and all will be good.
Aug 04, 2009 | GPS
Nextar GPS will not get past loading stage
Nextar will not assist in helping "fix" anything. Their solution is for you to send in the unit and they pitch it, send you one off the assembly line. I was able to get this unit working again in just GPS mode (what it was intended for), so using this workaround, you will lose the ability to use it as a tiny digital photo frame, MP3 player, etc.
I take no responsibility if you try this and "brick" your unit (render it unusable except as a $100 paper weight). BACK UP!!
1) Download and install ActiveSync from the Micro$oft website.
2) Connect the M3-04 unit to your computer
3) Turn it on
4) Red bar should fill and the M3-04 will "hang" in that screen, BUT viola it still connects to ActiveSync
5) Using Explorer from ActiveSync, navigate to ResidentFlash
6) Copy autorun.inf to your PC Desktop, make backup by renaming it to autorun.bak
7) Open autorun.bak with Notepad
8) Change the line to read without the quotes: "\ResidentFlash\Netropa Intellinav\IntelliNav.exe"
9) Save As to your desktop autorun.inf
10) Copy back to your ResidentFlash directory on the M3-04
11) Disconnect from PC and hit the reset button on back....BOOYA! Your GPS is functioning again.
Mar 19, 2009 | Nextar M3 Car GPS Receiver
Nextar S3 Application error in Navigate
You need the contents of the \ResidentFlash directory. You'll need to rename the MobileNavigator folder and the four gpspara files (0,1,2 and 3) then load the new folder and files from a device that is working. You will then copy your old \ResidentFlash\MobileNavigator\UserData folder from your backup to the new folder to regain any favorites you might have created. You should then be good to go. I use ActiveSync to talk to the S3. I'm not sure how else you might attach to it.
I have the ResidentFlash files but I have no place to post them. The files zip to about 5.3 MB.
Feb 27, 2009 | Nextar S3 Car GPS Receiver
Intellinav.exe application error
Jan 06, 2008 | Nextar Q3 GPS Receiver
Nextar w3g-01
How do I update maps in my nextar w3g-01
Dec 11, 2007 | Nextar Q3 GPS Receiver
HELP!! I keep getting Fatal Application Error. Application entellinav.exe has performed an illegal operation and will be shut down. If this problem persists, contact the program vendor. Program: Intellinav.exe
Exception: OxC0000005
Address: 00125D64
Oct 11, 2007 | Nextar Q3 GPS Receiver
Initial GM-501
its a software issue....it turnes out initial is out of bussiness...they sold their technical support to a third party company real *** holes...its a manufacrurer error....they told me is i wanted to fix it they will have to charge me $150.00 to reset the software....thats rediculous i shoped around and the initial units are runing around $120.00....well good lood and never buy an Initial product
Oct 01, 2007 | Fine Digital FineDrive 400 GPS Receiver
Nextar X3-03 Car GPS Receiver Logo
328 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
