Question about Canon PIXMA MX310 All-In-One Printer
Error message says print head not installed BUT it is!!!But also this is with both printers that I have... Canon i350 and Canon Pixma MP 210
I NEVER HAD A CD ROM FOR MY PRINTER PIXMA MP 210 How do I install it on to my Laptop windows 7
You can download the Canon printer drivers from their supportWEB site. Please click on this link and select your model printer to download :-http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Feb 25, 2012 | Canon PIXMA MP210 Photo All-In-One Printer
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
MP 210 printer maintance is in progress code 21140
Try refilling them. If they are empty, there is no way you will be able to print anything (or scan, or copy).
Mar 01, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
ERROR MESSAGE U051
Print head not installed,
or not properly
installed.
[1401] U051 Print head is not installed. Install
the print head.
Install the print head properly.
It may be that print head is defective or main PCB assy
Jan 12, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Error code 6000 on canon pixma mp210 stops me from printing
Error 6000 means - The specified file could not be encrypted.
Solution: reinstall the printer driver.... it's better to install a upgraded version of driver...
Good Luck!!!
Mar 19, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Print head
What is the useful life of the canon pixma 6000D printer 7to 8 Thousand pages?
Sep 06, 2008 | Canon PIXMA MP600 all-In-One InkJet...
I get ERROR 5100 message for my i350 printer...of course it will not print. How is this fixed? Please help.
I had the error code 5100 for my canon pixma ip6220d printer and all it was a pen in the track of the cartridges. I've been looking for that pen for awhile too. So I would say look for something in the way of the cartridges. Hope this helps everyone.
Aug 03, 2008 | Office Equipment & Supplies
Software
ok...www.canon.com has those drivers..by model and operating system.
http://tinyurl.com/6qcpgy
Aug 03, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon Pixma MP 210
it seems like ink is everywhere inside on the right side and the pics that are printed are bad
Mar 21, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
412 people viewed this question
old marine
old marine
