Question about HP Officejet Pro L7680 All-In-One Printer
Me too! my cyan and yellow won't print on my l7680!
  • 84 Answers
SOURCE: HP all-in-one not printing cyan color
Place a soft clean tissue paper over the cartridge print head and leave for about eight minutes. You can secure it with the aid of a rubber band. It should be held firm ok. If the tissue paper is not dampened by ink then the cartridge would have gone bad or the ink dried. You also know that they have expiry date and could go bad while yet in the packaging b/c it has expired. Good luck
Posted on Jun 02, 2009
cyber07x
  • 18 Answers
SOURCE: Printing problems
try to clean the noozle of you catridge..... then try again...... or try to shake it
Posted on Sep 01, 2009
  • 12 Answers
SOURCE: CYAN AND YELLOW CARTRIDGES ARE NEW OEM BUT WILL
Clean everything w/ slightly alcohol dampened q-tips. Run Cleaning program on printer. Align cartridges.
Posted on Oct 01, 2009
  • 24 Answers
SOURCE: My out of warranty l7680 will not print or
The error states that you are using non-HP cartridges for all colours. If black prints fine then you should replace the colour cartridges with genuine HP colour carts. You should be able to get a refund on the refills since they clearly do not work as intended.
Posted on May 25, 2010
  • 1218 Answers
SOURCE: Loaded print brand new black/yellow and
This issues looking printer head problem. check the following Steps for cleaning printer head :
  • Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
  • Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
  • Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
  • Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
  • Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
  • Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Posted on Oct 12, 2010
Why wont cyan and yellow print at all?
Use your machines built in programme to clean the ink jet heads
Feb 17, 2016 | HP Officejet Pro L7680 All-In-One Printer
Does not print black text. cleaning heads 8-10 times, prints red and yellow, no cyan or black. Cartridge levels are okay. Any help here?
check if you use a genuine cartridges
if no, you have to replace the head (if exist) and the all the cartridges
Sep 26, 2015 | HP Officejet Pro L7680 All-In-One Printer
Alignment failed when run
If Printer heads health condition is not good, alignment wont completes..
Four individual cartridges & Two print heads, each print head prints two colors.. Black& Yellow, Cyan & Magenta.. Verify which color is not printing properly(Color missing Or white bands)..
Perform 2 or 3 times print head cleaning through printer menu..Try for alignment.. If success end.. if no, replace the print head which is not printing properly.. Before replacing the printer head ensure that cartridge ink should be above 30%...
Oct 07, 2012 | HP Officejet Pro L7680 All-In-One Printer
My out of warranty l7680 will not print or photocopy in colour. Printhead status says Refilled supply Detected in printhead Black No/Yellow Yes Magenta Yes/Cyan Yes Detected in Printer Black No/Yellow Yes...
May 25, 2010 | HP Officejet Pro L7680 All-In-One Printer
My HP OfficeJet L7680 just stopped printing ANYTHING black. I change the black cartridge twice.I cleaned the printer heads, aligned it and still it will no longer print anyhting in black. When I do a test...
It sounds like your printer setup has changed to generating black by MIXING the color inks... if you run out of the cyan and yellow it will do red in spite of how many changes you make of the black cartridge.
Investigate the setup for the printer to make sure it is set for black from the black cartridge.
Apr 15, 2010 | HP Officejet Pro L7680 All-In-One Printer
CYAN AND YELLOW CARTRIDGES ARE NEW OEM BUT WILL NOT PRINT, I GET BLACK AND MAGENTA BUT NOT CYAN OR YELLOW
Oct 01, 2009 | HP Officejet Pro L7680 All-In-One Printer
Jun 02, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printing yellow for black
Hi Jan,
Can you confirm that you are using a CIS or non-HP cartridges with this printer?
It sounds a lot like the printhead has reached a clogging point where sediment has built up in the black portion and loosens enough to printer a few lines before it re-asserts itself again.
Based on my experience of this printer, if you're using a non-HP delivery system for ink then you should consider replacing the black ink with a dyebase alternative instead of pigment.. Replacing the Black/Yellow printhead and running a number of test prints to purge the pigment ink in the printhead should then result in a clean and more reliable printout in future.
One other vector for problems is the cleaning area and I've found that this can become soiled with excess ink causing cross contamination within the inks of one printhead. As yet I've not found a reliable solution to counter this sort of issue.
Hope this gives some clues and hopefully some ideas of a fix.
Martin
May 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
