Question about Boating
Honda outboard four stroke misfiring?
I have a mid 90's Honda 25 four stroke. I had 3 new carburators installed and adjusted by a vacuum gauge as well a new thermostat, sump oil and gear oil changed. I also had them install a fuel/water filter. They did a compression test and that checked out somewhere above 200? The repair shop said it was good to go. My problem is as soon as the motor warmed up, it started popping and lost power and I could not give it any more power than just above idle speed, it just felt like it was running on fewer cylinders?
    Problem Solver:
  • 14 Answers
I would take it right back to them. It is possible that the fuel lines were not changed or at least flushed before they put the new carbs on. It must have been in bad shape if you had to replace the carbs. Although, sometimes that is cheaper than a carb job.
If is very possible that some debris left in the fuel system or fuel pump that is caught in one or more of your carbs. It only takes one on a 25hp to make it run bad.
This sometimes happens even if the lines were flushed. I see it every once in a while. We try to catch it before it leaves by running it under a load at the water for a while to be sure everything is working right.
Since you put a water separating fuel filter on, it appears that there was a problem with water. Again if lines were not flushed, water could still be in the lines.
Before you take it back, drain each carburator into a glass jar and see what the fuel looks like. If it have water or debris it will settle to the bottom. If you find some, just flush the system until no more water or debris comes out. Then see how it runs.
You should always use some sort of fuel treatment like PRI-G or Sea Foam to keep the fuel fresh and to minimize the effect of the ethenal in the fuel.
Hopefully, the dealer can find the problem fast and at least give you a break on cost. We would normally do it for free if the customer brings it right back and it appears that we missed something.
Posted on Sep 17, 2009
My outboards rev counters or speed/fuel gauges dont work, although they light up.
Did you connect the second needed cable in your new engine? this is a 4-wire cable... Need an adapter 4-6 pins in some cases. This cable is needed to send the data from the engine to the dashboard.
Jul 04, 2017 | Light Boating
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
http://www.cottagetips.com/tips/boat-motor-gas-to-oil-ratios
Apr 15, 2016 | Boating
May I use higher octane unleaded fuel in this engine? (Say, 97 or 98 octane).
Hi Paul
Certainly you can. We use mid-grade or supreme in our Honda 15 outboard all the time. If the higher octane isn't needed, no harm done. After all, with a boat motor, it's working hard all the time and the higher octane certainly can't hurt.
Hope this helps.
-Steve
May 16, 2015 | Clymer Mercury/Mariner 4-90 HP Four Stroke...
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
Rapid popping/crackling noise in xr80
a four stroke will pop and backfire under decelleration when it is lean, or not enough fuel. (Jetting too small in the carburator) But, look at the spark plug for color, white is too lean, black is too rich, and chocolate is just right. Make sure the air filter is good and clean. And lastly... have the valves been adjusted?
Jul 30, 2009 | 2003 Honda XR 125 L
Outboard problem
Check your prop...probably slightly bent and only is noticeable at higher rpms.
May 20, 2009 | 2008 Mercury Mariner
Tune up specs for honda outboard
You have probably already found an answer, but all the specs are in the owners manual. If you do not have one, you can download one for free from honda-marine.com under the owners section. You will only need the serial number for your engine.
Apr 11, 2009 | Jet Inflatable Boat Motorized Scooter
Boating Logo
588 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
