Question about Goldstar MV-1501 Microwave Oven
The mircowave has no power, outlet works, just mirco strop workin
Microwave was not running, but made a pop sound and now nothing works on it.But there is power to the outlet..
  • 6,784 Answers
HI, the popping sound that you herd was the result of a failed HV capacitor. This failure will render the unit inoperable, as you has witnessed at this time. Replacing this failed HV capacitor, will correct this issue. I would also advise to check the cut-off fuse and in-line AC fuse as well. There may be some issues concerning the integrity of these fuses as well.
Posted on Sep 11, 2009
When running the noise sounds like the fan is not working correctly.
when microwave is running the fan sounds like it is grinding
Feb 03, 2013 | GE JVM3670 Microwave Oven
I have a GE household microwave (model JEM318A002) manufactured 7/1999. It is built into our cabinetry. Periodically it will freeze (nothing showing on the display...no response to keys; sometimes have...
Hello
sometimes you can find a small hole on the bottom or the back of the mircowave.. like the watches you stick a pen in to reset;; this is a reset for the mircowave you need a pin and do it just like the watches,
Also There bis a fuse on the inside panel or back panel after removing it.. the fuse or wires can be croded causing temporay memory loss ,if you clean it up it should hold memory how ever they do not recomend you open or remove the panel rom miorcowave only a experanced person should do this,it is up to you how to handle that
I gave you the information I know but also the safty about it if you do not feel good about opening it I just wouldn't do it
Good Luck
Apr 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
In the middle of running it just stopped. no power. No digital read, nothing. did not pop circuit breaker--other appliances, including toaster, work in that outlet.Tried m-wave in other outlets doesn't...
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 08, 2010 | General Electric Microwave Oven
Lg micorwave, lam1180st refridgerator and microwave were plugged into the same outlet. i heard a loud pop. circuit breaker popped. i reset and the frige works fine. Microwave does not have power. the...
It is possible that the interconnection link(s) between the two sockets in the duplex outlet have blown apart. Turn off power at the electrical panel for this circuit, remove the outlet from it's box, and check the interlink on both sides. If obviously burned, replace the socket. A better option is to run another duplex cable from the breaker box to the outlet from a new breaker, cut the interconnections on the new socket, and wire the new cable to the isolated part of the socket. This supplies full power to each half and allows both units to run at the same time.
Oct 19, 2009 | LG 1.2 Cu. Ft. Mid-Size Microwave -...
Sharp Carousel Microwave has no power
I too believe that a "protection fuse" was possibly blown. It would need to be found and get replaced. Hopefully it is just a fuse and nothing else because the way it sounds to me, the microwave may be damaged.
Good Luck!
Jun 11, 2009 | Sharp R-1870 Convection/Microwave Oven
Crackeling and popping then NOTHING!! No Power
Sorry to tell you that your microwave is done for. What they don't tell you when you purchase any over the range model is that sitting over the range, getting bombarded with steam and grease is not a good thing and it shortens the life span of the microwave.
Jun 11, 2009 | Microwave Ovens
Sharp Carousel Microwave R-1460A no power, door switch went first
You will want to replace the fuse and door switches. You will not be able to run it without replacing door switches. You do not need a new microwave. Door switches go bad, it has nothing to do with radiation.
Feb 19, 2009 | Sharp R-1460 Microwave Oven
Hood range microwave not heating up
We had one that did the same thing. my brother got so mad at it he put a wrench in it and turned it on. It didn't do anything to it. No power surge nothing. It acted as if I put a plate of food. Lighted up turned and even beeped when done. The wrench wasn't even hot. Now I do recommend this myself. But we went and got antoher one.
There is something in there that magnifys the power inside the mircowave and it sounds like its out.
Dec 12, 2008 | Emerson MW8778 Microwave Oven
Goldstar MV-1501 Microwave Oven Logo
132 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
