Question about Pride Celebrity X 4-Wheel Electric Scooter
Celebrity Pride SC440 scooter makes continuous clicking sound
After my husband has been riding on his Celebrity scooter for a while, it will suddenly start making a continuous clicking sound while moving (that you can actually feel) that is timed with the wheel revolutions. It appears to be coming from the rear right wheel.
  • Anonymous Mar 24, 2014
    clicking sound when driving sounds like something is hitting a rear wheel still rides good
  • 29 Answers
The motor break assembly is going bad, if not replaced soon it will quickly draw down your batteries. smithrm70@hotmail.com
Posted on Sep 19, 2009
HUSBAND FLIPPED HIS PRIDE CELEBRITY X SCOOTER STOOD IT STRAIT UP IN THE AIR.NOW NOT WORKING.5 FLASHES
Five beeps? Maybe it's not the same as my Celebrity XL8 but my instruction manual talks of a 1+4 beep warning meaning low battery charge. It also suggests checking that the wiring harness connectors are all fully connected - that would include the battery terminals of course. If your hubby managed to do a wheelie this sounds a strong possibility if the batteries were dislodged. Anyway, I attach the page from my Celebrity XL8 manual, you can find other Celebrity manuals online. My congratulations to your husband, I've yet to master wheelies!
Jun 13, 2017 | Pride Health & Beauty
I have a celebrity pride 3 wheel scooter and when i move lever to forward or reverse all it does is click but no movement
Have you checked the speed pot is not turned down too low?
No flash / beep codes.
I would check motor connector on drive unit, motor brushes.
May 24, 2014 | Pride Mobility Products Pride Celebrity XL...
Scooter will not go. Fully charged. Making beeping sound.
Hi,is the bleeping continuous or is there a pause , if so how many bleeps are there before it starts again??..
Regards
Rob
www.gewizrepairs.co.uk
Jan 11, 2014 | Pride Mobility Products Celebrity XL
Lost key to Pride Celebrity Scooter. Have an extra key for another Celebrity scooter. Are keys interchangeable? Thanks, DJ
DJ should work try it if all else fails call Pride @ 1-800-800-8586 ask for tech Support and ask to get a set of keys or You can replace the keyed switch with a on/off toggle switch Hope this helps
May 05, 2011 | Pride Mobility Products Pride Mobility...
2000 pride celebrity sc440. has had pc board replaced 2 times. intermitten times it just dies. i clean all connections, and then it works for a while. it just died again. i found a broken resister,...
Hi donmorrill
Dosen't sound like the board at all. Sounds like you have a connection problem front to rear harness. I have worked on many celebrity 2000's and have found a bad connection with symtoms like yours. In the rear you will find where all the connections are plugged in. Check each one for continuity. Clean all connections, also make sure the little metal connectors are intact in the anderson connectors. But you do have a harness problem.
Good Luck
mimobility wizard_s.gif Wiz
May 02, 2011 | Pride Celebrity X 4-Wheel Electric Scooter...
I turn key on celebrity scooter. everything looks normal. all lights on, but does not run.
Are the lights flashing or steady? If they are steady and indicate that the battery is charged, make sure that the freewheel/manual brake release lever is in the drive position. If the lights are blinking, then you can visit this site to locate the type of controller on your scooter to try and determine what the problem may be: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
If you continue to have problems, please contact Pride Mobility Technical Support for assistance.
Dec 22, 2010 | Pride Mobility Products Pride Mobility...
I have a celebrity scooter that powers up great and every thing seems to operate properly except it will not go forward or backward. It makes no sound when engaging thumb switch.
Make sure the drive lever/freewheel brake is engaged. Usually it is on the lower back bottom of the scooter or check your owner's manual.
Oct 29, 2010 | Pride Mobility Products Pride Celebrity XL...
My Pride Celebrity 3 wheel scooter, keeps suddenly jolts to a stop for no reason when I am going along, and will then go forwards again. Any Ideas please
Hi. Sounds like a loose connection, either on the battery terminals, or on the battery lead connectors.
When your machine suddenly stops, does the battery gauge also turn off?
Can also be caused by a worn or stuck motor brush.
If none of these ideas help, can you give us a better description of what goes wrong?
Good luck. Neil.
Jun 26, 2010 | Pride Mobility Products Celebrity X...
Need manual for celebrity x mobilty scooter
Go to cheapest-scooters.co.uk Then click on photo of celebrity x sport mobility scooter.Then scroll down page and click link to download owners manual. Hope this was helpful?
Sep 24, 2009 | Pride Mobility Products Celebrity X - 3...
Problems with Pride Celebrity X 4-Wheel Electric ScooterFree tech support for Pride Celebrity X 4-Wheel Electric Scooter and help with Pride ... the scooter suddenly stops. it is an intermittent problem....
It is often a damaged accelerator (Potentiometer). Sometimes the shaft on the wigwag breaks the contacts in the accelerator from being moved too vigorously when going over a bump too fast. A technician would need to repair this for you. Happy scooting. Regards Chris… info@mymobility.co.nz
Jun 20, 2009 | Pride Celebrity X 4-Wheel Electric Scooter...
Pride Celebrity X 4-Wheel Electric Scooter  Logo
603 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
