Question about Hotpoint Aquarius WMA56 Front Load Washer
Washing machine not spiining
Machine goes through washing cycle ok but when it gets to rinse and spin and final spin, machine just stops, but will do it if i manually set to rinse and spin.
  • Anonymous Mar 16, 2014
    My Hoover Spin Scrub 60 floor shampooer will not spray on the wash setting but will spray on the rinse setting, what is the problem?
  • 183 Answers
Sump hose filter blocked, running out of draining time, when you put it on again it allows more time to drain, remove sump hose and clean out internal filter.
Posted on Dec 25, 2007
Brand new Bravos. Why doesn't it do the final spin?
NO ITS NOT UR DOOR SWITCH IF IT WAS IT WOULDNT SPIN ON ANY CYCLE. I SUSPECT U HAVE A TIMER THAT IS STICKING AND THE POINTS HAVE BURNED OR SEIZED
May 26, 2015 | Maytag Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
We have a Hoover select 1500 washing machine. It still washes and rinses ok, but doesn't then move onto the spin cycle. But I can manually set the dial to spin and restart it. It then spins fine. I assume...
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Nov 11, 2009 | Washing Machines
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washing machine isn't spinning to drain water
suggest that the drive belt is worn and slipping under exess load solution replace belt regards billnkaym
Apr 02, 2009 | Whirlpool LSQ8543J
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Hotpoint Aquarius WMA56 Front Load Washer Logo
405 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
