I am assuming the page is over your set and not an overhead speaker. The setting is in the configuration programming of your system. Recieve page must be set to 'n' in the programming for your set. If you don't have someone within your company that has access to this programming you may have to call an outside party.
You should complete programming on a T7316, T7316E, M7310, M7324 phone.
1. Feature **23646
2. Password: 266344
>>>Your password may have been changed by your phone company. Contact them for the password.
3. Select General Admin
4. Select Date and Time
5. Select Time
6. Adjust the Hour, Minute, and AM/PM
7. Press Rls when done
When you call an internal extension and the extension is either busy or ringing, you can invoke the Ring Again (Call Back) feature. If Ring Again is activated when the dialed extension is ringing, you will be notified when there is activity on the phone and the phone becomes idle. You cannot use this feature on outside lines, and while your phone is idle.
This is a Toll Fraud issue that is being access through an individual mailbox that has Outbound Transfer turned on in the COS. Someone will need to access the voice mail through the LAN interface and access the VMS GUI to manipulate the COS to turn off the Outbound Transfer in COS 1. This is a known issue on the Norstar related VMS\'s.
The lines are probably hung up in the system. A reboot of the Norstar system should resolve the probably. Just unplug the phone system from the UPS to reboot the system.
Look in the System coordinator guide 5.0 for HandFree
Select type of handfree
You must set the Handsfree at: auto
Its in the deep programming
Your going to need Business Series Terminals programming overlay to put over the phone.
Press Function **266344
Than enter system coordinator pass word
Press SHOW once and enter your phone extension number
You may need to change your Ring Volume. Here are some instructions on how to do so. To Change your Ring Type: 1. Press the Feature button, then * 6 2. Press the number keys 1 – 4 to hear the different ring types 3. Press the OK softkey when you hear your desired ring To Change the Ring Volume: 1. Press the Feature button, then * 80 2. Press the volume key up or down 3. Press the release key1 to exit and save the volume level
