Question about Sharp Aquos LC-45GD4U 45 in. LCD HDTV
I have sharp 37 inch LC-37D44U MY PS3 is not working with it it green lights keep blinking power light and OPC. BUT THE HDMi ports work beacause i checked it with other devices. so i dont know why its not picking up my ps3 signal
    Problem Solver:
  • 7 Answers
Does this happen when you input certain signals to the HDMIi have sharp 37 inch LC-37D44U - 2_bing.gif ports? Or all signals (e.g. 1080i, 720p, 1080p, etc.)? And which ports are affected - side HDMI, rear component, etc.?
I had this issue and Sharp sent out a local repair tech to install a new main circuit board, then two weeks later, a new side board (where the side inputs connect into the system)... their first visit allowed my TV to accept signals in the rear HDMI ports (all signals worked well), but then I couldn't get a signal processed via the side HDMI port. At first, just 1080p would not display (caused the OPC/power green light blinking), and after a few days, any signal hitting that port would cause the error lights to come on. But as I said, eventually, a new side board resolved that issue.
Posted on Mar 04, 2010
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
I have a Sharp LC-46E77UN TV. Remote will start TV green light on. No picture, just stays black. PVR is on and connected to TV via HDMI cable. Cannot turn off green light. Must use power button on TV and...
THe problem is in the set top box. Or common called the tuner box. IT looses the 5 volts to the main display and thus the monitor will go into a shut down state. THESE boxes are factory repair only and must be sent off to repair.
Feb 20, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I have a lcd 37 inch lc-37d44u the green power light keeps falshing
It may be in the safety shutdown due to shorts circuits in the power supply or in the backlight inverter board. You will have to open it up and check.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Oct 16, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
Green lights flasghing, no picture
Tries unplug,replug tries on/off for awhile might work,not than the backlight board it dead.
Sep 22, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Blinking power and OPC lights
If you have tried to reset the TV by unplugging it for 2 minutes and still have the same issue then it is time to bring the set to a repair shop.
Jan 04, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Power light blinking green,nopicture lc-32sb24u lc-37sb24u
This same thing happened to me, but not until I fiddled with all of my remotes, trying to see if it was an input issue, battery issue, etc. I finally unplugged the tv from the wall and plugged it back in. Nothing. Then I went to take 5 minute ****. When I finished, the Power & OPC lights were blinking, and out of sync. I pressed the power button at the top of my TV and got a picture.
Word.
Dec 31, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp LC-37D4U, the monitor doesn't turn on
It is hard to say without first looking at it.
Jun 28, 2017 | Sharp Aquos LC-32D40U Television
Lc-46d64u
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
There isnt really anything you can do to fix it yourself, youd have to call Sharp to locate a local service center.
Mar 23, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sharp Aquos LC-45GD4U 45 in. LCD HDTV Logo
787 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
