Question about Garden
My rider stopped in high grass, would not start.
My riding mower stopped in high grass, (low well watered and grows thick and fast) would not start. Next morning started. Tried the high grass again stalled and would not start. Unfortunately, I left they key on and battery was dead next day. Charged it and started, 15 min later, had to get off to clean up some debris, stopped again, will not start. Not even a sound, no sputtering, grunts or nothing. Yes, I had it in neutral and all those things. Appears to happen when it is hot. Been using the same mower for 7 years. I am a senior woman on a small budget!! Thanks
    President:
  • 986 Answers
Your not going to like my solution. your engine is just getting hot and trys to seiz up and when cools its free again,I bet you can hear the oil boiling in the crankcase when this happens you engine is just getting a little tired,I hope this helps you, and thank you
Posted on Sep 11, 2009
Testimonial: "Thanks much!I think U R right.I noted a slipping & clunk sound when I go over high grass too. I want to move 2 a condo in 6 mo. Trying to make it:-)"
  • 3 Answers
First must by the connection bettw.battery and starter.second mesure short cut of the starter .try cu see if you have the seal battery or not.in this case try to see if there is mixture water + acid(enough) on it.other solution -you have broken battery charger relly.
Testimonial: "I have not tried your possible solution yet. Still wonder why it starts next morning. Stranger helping is wonderful! "
John deere instructions
Your mower doesn't have enough power to handle very thick grass at high speed. You need to go slower across the lawn. That's easy to do if this is a push mower (just don't walk so fast) or if it's a self-propelled model with a speed control. But if it's a single-speed model you'll have to mow the lawn in fits and starts: squeeze the lever to move it forward; release it when you hear it bogging down; wait for the motor to reach full speed; squeeze the lever to move it forward again; repeat. Also, is the grass very high? If so, try setting the cutting height higher on the first pass, then lower it for a second pass. Finally, make sure the blade is sharp.
Aug 06, 2014 | Briggs & Stratton 190cc 875 Series OHV...
Tractor moves 5 feet then stops belt starts to smoke
There is something in a wad! You cranked it up to warm up. You drove it to the crime scene. You first engaged the blade which was OK?
Then released clutch to drive which, smokes the belt.
Most interesting and perhaps you tried to cut some super thick grass at high driving speed with a low/dull blade and the belt just can't tolerate that combination.
Sep 10, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Craftsman riding lawnmower won't bag grass
A very common problem since mowers were made noise compliant, to collect grass you need draught, this is produced by putting a large wing on the ends of the blades and having a high engine speed, unfortunatly large wings and high engine speeds mean high noise, so today the wings are very small and the engine revs low, this leads to low draught and grass blockage, you need to keep the under side of the deck clean and free from old grass clippings, make sure the machine is fitted with collection blades, not mulch blades, i cannot tell you to increase the engine revs, however if for some unknow reason the engine were to start reving higher it would help.
Oct 13, 2012 | Craftsman Garden
Wierd grass catcher problem
There are a couple of causes for this. Is the blade height the same on the new mower? Higher blade height could cause a lot of the grass to be blown out from under the deck, and not into the catcher chute.
On the trailing edge of the mower blades is a small 'wing' for lack of a better term. There are two types of blades, mulching blades that have a lower 'wing', while catcher blades that have a slightly higher 'wing' but it makes a difference.
If the season has been hot lately, the grass may not be growing as fast, hence less clippings, and less dense grass could also cause this.
Jun 16, 2012 | Mtd Garden
While mowing the grass the engine stalls and then catches back and stalls and catches back contuniually. the Murry select riding mower model number 405000x8c.
bad fuel filter, maybe cutting to fast, or grass is to high for what ever setting your at.
example. if grass is more then 10'' high, its not recommended to try and cut it to 3'' in one shot. start with the highest setting, and work it down. hope this helps.......
Sep 22, 2010 | Garden
Blade slows down when grass gets thick
The reason the blade slows down when the grass gets thick is simply because the mechanism operating the blade is weak and cannot move fast when on thick grass.
I suggest you troubleshoot the mower. After that, the blade should work fine when the grass gets thick.
Also, some mowers normally gets slow when grass gets thick, so after troubleshooting, if the mower does the same, then you already know it has to be slow when trying to cut thick grasses.
Take care
Sep 09, 2010 | Toro Personal Pace CARB Walk Power Mower
Bog when trying to mow
you are cutting to much grass & it isn't kicking it out fast enough out of deck which will bog it down it might help if you clean out the bottom of the deck & also dont cut really low if grass is really tall also cutting wet grass will aslo cause the bogging if i can further help e-mail me wade at wadembly@aol.com
Jun 26, 2009 | Garden
Mower won't start
13 to 15 amps electric or battery operated mower may runs slow when cutting thick grass. also recommended not to cut grass when it's wet & need very sharp blade to do the lawn. may overloading it, cutting grass too thick also draws too much power. check house breaker first.
Jun 11, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
