Question about Cuisinart CPT-180 Metal Classic 4-Slice Toaster
Cuisinart Metal Classic 4 Slice Toaster CPT 180 - right side arm will not stay down. Any suggestions? The lights will turn on for Bagel, Defrost, and Reheat, however, the arm will not stay down. I can stand there and hold the arm down and it will toast, but who wants to do that!
  • 50 Answers
The spring arrangement responsible for this operation must be broken or dislocated fix it.
Posted on Sep 23, 2009
    New Friend:
  • 5 Answers
Even though the time of the orginal help request is long past, this posting may still be useful to someone:
1- Crumbs or part wearout may be keeping the plastic latch from engaging. If you have the toaster apart, you can compare the arm latching action of the good side with the bad side--maybe there is an obvious difference in the travel of the arm that keep it from engaging.---leaving the travel short even 1/8" can keep the latch from engaging.
2- If there is nothing obviously mechanically wrong, then it may be a control board malfunction. Make sure the 3-pin control board connector is plugged into the transformer/solenoid board. Since you are getting lights, this should be OK. You have at least one good board (the side that works) so you could plug that board into the other side to see if the arm stays down. For fun, you can plug the bad board into the other side to see if the other side now malfunctions. If the problem follows the board, then you have your answer.
If you know someone that understands electronics, they may be able to repair the board--have them look at electrolytic capacitor C1 and make sure it is good. If that part is bad, it can be replaced for about $1 by going to Fry's and purchasing a replacement capacitor. After a couple of years of use, a defective C1 may "dry out" and cause control board problems.
Hope someone finds this useful...........
Posted on Nov 25, 2013
  • Dale Anderson
    Dale Anderson Jun 24, 2014
    I repaired the same symtom that happend to one of the sides of my CPT-180 toaster. The magnets wouldn't engage due to a bad C1 capacitor on the circuit board that controlled that side of the toaster--the capacitor was bulged out on the bottom and turned out to be bad. I've attached some photos showing C1 bulged out compared to C1 on the good board.
    C1 is the main power supply capacitor and if it goes bad, the circuit board power supply won't function correctly. This can lead to a broad spectrum of problems like the lever not staying down due to the magnets not engaging or the toasting control/timing circuits malfunctioning. If you replace the capacitor, it is best in most cases to replace with the same value as the orginal (220uf on my toaster)---you can usually get a replacement capacitor at Fry's Electronics. Replacing with a higher capacitance may be acceptable, but you should understand the impact to the rest of the circuit before you substitute a higher capacitance value. The voltage rating and temperature rating of the replacement capacitor should be the same or greater or the capacitor will fail quickly. Note the max temperature rating of capacitor C1 is +105C---toasters get hot (duh!) and the temperature around the circuit board of this model gets quite warm, so the temperature rating of the capacitor is critical. Finally, make sure the substitute capacitor fits when installed (requires soldering) and does not interfere with surrounding circuitry or other toaster mechanics when the circuit board is put back in place.
    Pictures:
    C1_location (next to screw)
    Comparing_good_C1_with_bad_C1--note bulge on bottom of right C1
    Right_orginal_C1_and_left_replacement_C1
    Bad_C1 showing capacitance, voltage and max temperature ratings
Magnets will not ingage
Pictures:
5487aa4b-7e7d-4e6f-9542-cf9ff618008c.jpg2d853c87-48b6-4735-99f4-fdd5dbc60ffe.jpge1a82299-a243-46e1-b11b-4c20e0d9b304.jpg5543b7e5-8108-4b1d-bed3-90eee4600722.jpg
Mar 28, 2014 | Cuisinart CPT-180 Metal Classic 4-Slice...
My Cuisinart Toaster's left side lights up
I repaired a problem with one of the sides of my CPT-180 toaster that was fixed by replacing C1. This may be the same component that Stan was referring to, as the C1 capacitor on the circuit board I was having problems with was bulging. I've attached some photos showing C1 bulged out compared to C1 on the good board.
C1 is the main power supply capacitor and if it goes bad, the circuit board power supply won't function correctly. This can lead to a broad spectrum of problems like the lever not staying down or the toasting control/timing circuits malfunctioning. If you replace the capacitor, it is best in most cases to replace with the same value as the orginal (220uf on my toaster)---you can usually get a replacement capacitor at Fry's Electronics. Replacing with a higher capacitance may be acceptable, but you should understand the impact to the rest of the circuit before you substitute a higher capacitance value. The voltage rating and temperature rating of the replacement capacitor should be the same or greater or the capacitor will fail quickly. Note the max temperature rating of capacitor C1 is +105C---toasters get hot (duh!) and the temperature around the circuit board of this model gets quite warm, so the temperature rating of the capacitor is critical. Finally, make sure the substitute capacitor fits when installed (requires soldering) and does not interfere with surrounding circuitry or other toaster mechanics when the circuit board is put back in place.
Pictures:
May 14, 2013 | Cuisinart CPT-180 Metal Classic 4-Slice...
How do i Opened my cuisinart toaster cpt180
The Instruction Booklet for the Cuisinart CPT-180C Classic Metal 4-Slice Toaster can be found at the following link:
http://www.cuisinart.ca/pdf/ibs/en/CPT-180C_en.pdf
Not sure what you are trying to open. There is a slide out catch tray for cleaning crumbs. There is no information in the booklet that suggests a need or a way to open the toaster.
Perhpas reviewing the booklet will answer your question.
Jun 28, 2012 | Cuisinart CPT-180 Metal Classic 4-Slice...
Toaster latch does not stay down on Cusinart CPT-120 compact two slice toaster
for Cuisinart cpt160: If the latch will not stay down it is because the electromagnet at the base of the toaster, which is supposed to activate when you push the handle down, is burnt out. I pulled my toaster apart and did a test of that mechanism and found that the solenoid was fried (open circuit). There are no replacement parts.
Jan 09, 2011 | Cuisinart CPT-160 Metal Classic 2-Slice...
Problem with the CUISINART RBT-450BKPC costco toaster
We had exact the same problem. Our problem was within the circuit board controlling the release relay, on the left side. 3 parts was dead:
1) rectifier diode 200V 1amp
2) Electrolytic capacitor 220uF 25V
3 Zener diode 12V 1W
These components supplies 12VDC to the rest of the circuits from the mains, 127 VAC.
Apr 25, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
When I depress the carriage control levers they do
my toaster did this once, i suggest that you get a new toaster from a different company, because if you've only had the toaster a month
and its doing this already that's a crappy toaster
Apr 20, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
The toaster arms will not stay down on either side , have power to the toaster and can see the elements light when arm is held down but won't stay down.
First, turn it to the darkest setting. It may be set too light to stay down. Also, try cleaning it out. Take it outside and turn it upside down and shake it. Also, open the crumb door on the bottom. Hope this helps. Good Luck.
Feb 10, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
Toaster arms will not stay down
Arms stay down by the mean of an electromagnet, controlled by a chip. If the wall outlet is functional, you should be able to turn on light by pressing the "defrost" or "bagel" button while the arm is held down. No light? the toaster is good for garbage!!
Mar 15, 2009 | Cuisinart CPT-180 Metal Classic 4-Slice...
4 slice toaster
open the unit. look for disconnected wires from sloppy factory
May 20, 2007 | Cuisinart CPT-140 Cool Touch 4-Slice...
Cuisinart CPT-180 Metal Classic 4-Slice Toaster Logo
967 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
