Hi Could I please get some technical support
Hi Could I please get some technical support regarding a Toshiba split system airconditioning unit (indoor model number RAS-26NKHP-A2). I can turn the indoor unit on in about 5 minutes of the indoor running it starts flashing between the green and yellow lights on the inoor head unit and the compressor will not come on. I checked the interconnecting wiring between the indoor and outdoor units and it` s OK.
Thank you
Joe
Airworx
  • Dennis Boxerman May 11, 2010
    I've worked on similar systems but not this exact one. On the ones I've handled, it has been diagnosed as a bad compressor. This is where I would start.
Speed boy
  • 76 Answers
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
SOURCE: DeLonghi Planus quick connect split heat pump.
I was told by a delonghi technician that it does this to defrost the unit.
Hope this helps.
Posted on Apr 22, 2009
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
  • 10 Answers
SOURCE: Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
Posted on May 31, 2009
  • 4090 Answers
SOURCE: LG split (3 indoor) LMU360CE
02 Indoor In-Piping Error 2 times OFF
There is a complete guikde to problems on page 66 of users manual. If you dont have one get back to me with your email.
Posted on Aug 02, 2009
Need a wiring diagram for split system heat pump model number ch5536vkc2
need more information to help you.
1) is it single or 3 phase?
2) what power does it have? (example 30000 btus )
3) is it for the indoor unit or for the outdoor unit,? or both?
4) does it has an electronic circuit board in the indoor unit?
5) do you need only the field wiring diagram from indoor to outdoor unit?
Post me back with some details and I may help you out
Best regards,
Silvio
Dec 08, 2014 | Heating & Cooling
Red blinking and ac not working
If the power "flickers" and unit fails but will restart once the breaker is reset, this sounds absolutley normal. It is a safety device that keeps the unit from burning up things due to improper power being supplied. As long as resetting puts it back into service with no issues, don't worry about it.
May 12, 2010 | Hitachi RAS-09UH Air Conditioner
Manual for a Toshiba Heatpump model RAS-16 NKV-A2
You can download your manual from this Toshiba Website. It's approximately halfway down the page. :-)
Mar 28, 2010 | Heating & Cooling
Three month old R410A Daikin a/c not cooling?
Hi; dont worry unit is still under some kind of a warranty, either from installer or manufacturer. Please find out before You or a friend try to fix. This can void Your warranty...
Jan 20, 2010 | Cfm Daikin R410a Split System Air...
Hi. I have a failed indoor controler on a hitachi ducted aircon. mod ras-5hz. inverter. can I replace it with other type. Unit 15 yrs old and parts not available. What is the control voltage between indoor...
Hi, the control voltage to both indoor and outdoor will always be 24 volts AC. If this is a heat-pump unit, the high voltage to the indoor and outdoor will be the same, 208/ 230/ 240/ 277. If it is a split unit with a gas fired unit, the outdoor will be 208 or higher and the indoor will be 120volts AC. I'm sorry, you have the inducer motor, so it is gas! My mistake. Yes, always the gas furnace will be 120 volts AC and the remote condenser will always be 208 and higher. As far as replacing the inducer motor with a different kind, it will have to be the same voltage, 120, and amps, R.P.M's, 60hz, and made to pressurize and be able to vent Hot gases also. It must fit and operate like the old one. They should make a replacement universal motor to fit? Check with some of the wholesale houses on this and they can locate a motor to fit. Keep me updated on this please Don.
Shastalaker7
Dec 18, 2009 | Hitachi Heating & Cooling
I NEED A USER MANUAL FOR A HITACHI SPLIT SYSTEM AIR CONDITIONER, WALL MOUNTED, MODEL NUMBER RAS-52CNHA. WHERE CAN I GET ONE ?
http://www.hitachiaircon.com/argws/listDOCS.do?pageName=Technical+Manuals&range_id=1&page=PAGE&button=Submit&categoryID=-1&action=getListTechManuals&d-49653-p=14
Jun 10, 2009 | Hitachi Heating & Cooling
Split unit, I get heat but no cold
I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
May 16, 2009 | Fujitsu 24R1 Air Conditioner
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
