Question about Maytag Performa PAV2200
SMELLS LIKE A BELT BURNING AFTER i WASHED A RUG
Washed a RUG AND THE WASHING MACHINE STARTED SMELLING LIKE A BELT WAS BURNING. nOW THE MIDDLE SECTION WILL NOT TURN AT THE SPIN OR WASH CYCLES. DID THE BELT BURN OUT AND IF SO, WHERE IS THE BELT?
KatieD,
If it won't spin or drain water, you are right to look for a drive belt related problem. The belt is underneath the bottom floor pan.
Here's what I did:
1) leaned the washer back a bit and propped something firm and secure under the front edge.
2) after seeing the belt was intact, I pulled it off, it is seven years old, and not too stiff.
3) After making sure no limbs were under or inside the machine, I had my wife start the machine in the spin cycle and watched as one of the 2 smaller pulley's in the corners spun very quickly. This was the motor pulley. Had my wife turn if off.
4) Attempted to turn each of the 3 pulleys that the belt had been wrapped around. The large plastic transmission pulley in the center turned with a little effort. The small metal pulley for the motor turned with very little effort. The remaining metal pulley in another corner would barely turn at all, and it should have been the easiest to turn. This pulley was for the drain pump and was nearly seized up.
I'm sure this is my problem as it is a fairly common point of failure and one of the most inexpensive repairs for the FIY'r. New drain pump should be about $70-$90.
Hope this helps you with your problem!
Bowfan
Posted on Sep 13, 2009
Tub not spinning
tub will not spin, smells like it is burning
Aug 16, 2012 | Speed Queen AWN412 Top Load Washer
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
Nov 07, 2010 | EuroTech Washing Machines
I have a Whirlpool thin twin and the agitator is not spinning and makes a humming noise. I washed a small bathroom rug that created an uneven load and this is when the problem started. We removed the top...
I don't have a solution to this but I have almost the exact same problem - washed a runner bathroom rug last night, today it drains but won't spin and I'm having trouble diagnosing further or disassembling... <!-- from fixya rte -->
May 13, 2010 | Washing Machines
Burning smell and not picking up dirt
You probably need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Jul 02, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
SMELLS LIKE SOMETHING IS BURNING WONT AGITATE OR DRAIN
Sounds like a belt has gone bad. Tip the waher toward the wall. You might see two belts. If you do not, get me you model # and I will see exactly what nodel you have.
Please let me know if I can assist you further
Thanks
Vic
May 16, 2009 | Washing Machines
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Washer smells like something is burning and it won't work at all
i would check the motor, and also the coupler that mates the motor to the tranny
Nov 26, 2008 | Whirlpool LSR5132PQ Top Load Washer
Smells coming from machine, leaving washed item's smelly
Get whirlpools new affresh washer tablets. They clean the inside off the machine and kills mold ect. and if used regularly it keeps your washer smelling fresh. They are designed for front load machines but work great in top loaders too. They are available on line at any parts store and are around 8 bucks.
Nov 21, 2008 | Hotpoint Washing Machines
Washing machine started making noise in spin cycle and then there were fumes
The belt is loose and slipping. They were probably, black and smell like burning tires!
Just in case it was a wire burning!!
Call service this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 09, 2008 | Maytag Performa PAV2200
Washing Machines Logo
208 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
