Question about Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control
Battery good....remote light comes on....
Can't get light off or turn fan on...is it possible to unprogram the fan remote? My 2 yr old was playing with it and just pressed the buttons in...not sure what to do.
    Sergeant:
  • 217 Answers
Most Fan Remotes have to have the Battery compartment opened and the tiny rocker switches changed as well as the FAN receiver,could your child do that?.Try changing the Batteries.Good Luck.
Posted on Sep 11, 2009
Fan and light come on when door closed!
Door ailment may be a issue or the brackets that hold the switches maybe old and moving. Or wrong switch in wrong spot..
Nov 10, 2015 | General Electric PVM1870 Microwave Oven
Remote required to turn on light but fan turns on with light switch
Before you conclude the fan was wired incorrectly, try this:
1. Shut off power to the fan (at the circuit breaker)
2. Remove batteries from the remote and press all the buttons to eliminate the possibility of a stuck button. Reinstall batteries
3. Turn on power to the fan and try operation
Jan 23, 2013 | Hunter 28096 Westminster 52" Ceiling Fan...
Need manual for harbor breeze fan model # LP8063
The remote went bad, this is very common. These are great fans with poor design and cheap remotes. Go to Lowe's buy the new kit ( model: RCE-103LW) $30 bat included. Put battery in and turn off light switch. Have a bic pen ready with the battery cover off. Turn on light switch and press "learn" red button with the pen . You will have to hold it down for about 5 secs. The fan will the turn on medium if it took to learning the new remote. All buttons should now work normal. Return old remote to store for exchange they have a 1year return to to store warenty per the company rep. Anyother problems call 1 800 527 1292. They have good cust. Service.
Jul 21, 2012 | Dryers
We purchased a house that is more than 10 years old. The ceiling fan w/light does not turn on with the wireless remote that is attached to the wall and there is not other switch but this one to turn it on....
You need to know if there is power to the fixture. If there is , then you might need to replace the receiver. It should be under the canopy where the power is connected for the fan.
Sep 01, 2011 | Hunter Ceiling Fan Light Remote Control
I can still control the Fan function with remote, but can no longer turn the light on. I installed a new bulb and even new battery in the remote. The light still doesn't turn on. Also cleaned remote as...
Howdy,
Is it possible this fan also has a pull chain switch for control of the light? If not, it sounds like the light board in the receiver has burned out, which is a fairly common issue. If the above does not work, call Hunter at 1-901-745-9222, a direct line to tech support. Be sure to have your fan model # ready as they will need it to get your correct receiver. If it's under a year old they should give you a replacement provided you can provide proof of purchase.
Sep 22, 2010 | Hunter 52" Ceiling Fan With Light And...
My 2 yr old Ixus 70 keps turning itself off.
How old is your battery? Keep in mind rechargeable Li-Ion batteries aren't meant to last more than a couple years, regardless of whether they've been used or not. If yours is as old as your camera, I think you know the answer. The good news is there are many inexpensive generic alternatives available these days. Some are very good, and vice versa. Research the buyer reviews before considering purchasing.
Nov 10, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
I have a rcr3273 universal remote. my tv is rca. i had the remote programmed before and somehow it became unprogrammed. i dont have the instructions anymore and i cant get it working
hold down tv button and power button together until the lcd light turns on. then press the play button every 5 seconds until your tv turns off. press reverse every 2 seconds until it turns back on. press stop to save the programming code.
Nov 09, 2009 | RCA Universal Remote Control
Remote control will not turn on/off fan or light. Has good battery. Where is the transmitter located on the ceiling fan?
The transmitter is the remote. The receiver is located inside the fan mounting bracket next to the ceiling. If you replace it make sure to set the dip settings on the new receiver exactly as they are on the old one. Wire the new receiver exactly as the old one is wired if it was working before.
Nov 07, 2009 | Hunter 52" Ceiling Fan With Light And...
Television does not turn on
please check the ac plug at the wall and also behind the tv. most newer tv's have a cord like a computer that plugs in the back and they sometimes come loose. are the rest of your electronic components working ? if the ac cord is plugged in, your power supply inside the tv has gone bad. you cannot blame your 2 year old if this power supply has gone bad, this was "NOT" caused by playing with the remote control.
Jan 18, 2009 | Televison & Video
Huntington Bay Ceiling Fan W/lights & Remote operated. # HD 361054
I had a similar issue with my fans. The fix I came up with was my remote was faulty. An easy fix because I had 2 fans with the same remote.
Jun 29, 2008 | Dryers
Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
268 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
