Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Hi, my tv shows a double image with red outline I pressed the Touch Focus and the red did not have a verticle was straight line, but the horizontal line was not straight, but came back with touch focus error in blurry red color
  • 273 Answers
You have a convergence problem
it will require a couple new ics its best to replace as a pair stk392-110 although i recommed using the stk392-150 as a replacement and also there are some jumpers that should be resolderd on those boards to assure continued operation hope this helps you
Posted on Nov 16, 2009
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
When I run the Touch Focus , it ends Touch Focus Error, and the Red Verticle line does not move , the Horizontal is bent .. now tv is fuzzy?
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 27, 2009 | Toshiba 42H82 42" Rear Projection...
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Touch Focus Error
you need to replace both of the STK392-110 ICs you can get replacements at the following link and they come with free instalation instructions with pictures. Here's the link.
Jun 20, 2008 | Toshiba 53H71 53 in. Rear Projection...
Double outline "red" around images
Hi you have bad convergence ic stk modules ,Cost for repair center to fix is 250.00. call your local repair center ask there prices on convergence ic repair. It is a very common problem every 3 to 5 years .Our service center does a lot of these.
thanks doctor video 1987
Jun 01, 2008 | Toshiba 42H83 42" Rear Projection...
Touch focus error will not correct
If the touch focus isnt working and the picture has a 3D look you will need to change the conversion ICs. This is a straight forward repair just unsolder the old and solder in the new. You will need to replace both. They are located on a large aluminum heatsink and they will have STK numbers stamped on them they are quite large easy to find. The numbers will be something like STK392-110 or simallar. Let me know if you need anymore info.
Mar 23, 2008 | Toshiba 53H71 53 in. Rear Projection...
57H81Toshiba Blue Line not straight
You have a bad convergence output IC in the blue vertical circuit. On the bottom side of the chassis you will see a " V " printed by the heat sink. You will need to unsolder the heat sink and the 20 pins on the IC to remove it. Replace with STK 392-180 (sanyo) if possible or STK 392-150. Looking from the rear the heat sinks are big aluminum finned rectangles. There are 2 heat sinks one marked H and one Marked V. Even though you have a horizontal line your problem is in the vertical IC. Be sure to use a liberal dose of heat sink compound.
Mar 21, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Aging 43H7143
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
163 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
