Question about Kenmore 24 in. 16019 Built-in Dishwasher
It doesn't fill with water
Ok, last week the clean light sensor would flash constantly and the thing would not even start. We were given a code, a series of buttons to push on the front of the dishwasher to reset it, that worked great. But now the water isn't filling. When its turned on I can hear it starting and a few moments later there's maybe an inch of water in the bottom but it never gets more than that, and there is a lot of steam, so its definetly getting hot. I tried turning the breaker of and waiting to turn it back on but that didn't work either. Any other suggestions?
  • 413 Answers
Replace the water inlet valve
Posted on Jun 06, 2008
Was getting a "IE" error during the wash cycle and the machine would shut off. Replaced both inlet valves and now I am getting a "FE" error as the machine is constantly filling with water.
Hello. I need the make/model number to help you accurately. If you have a Samsung washing machine, the IE error code pertains to a defective water level sensor. The "pressure switch" tells the computer how much water is in the tub at any given moment. It will have a tube (plastic or rubber) connecting it to the bottom of the tub. As water collects in the bottom of the tub, air is pushed into this tube and against the sensor. The sensor can fail in 2 directions. Your washer will not fill with water at all because it thinks there is already water in the tub(the tube is clogged)--or disastrously, keep filling until it overflows and floods your house because it constantly thinks there is not enough water. This can happen when the hose is loose on the sensor, a pinhole has developed in the hose and proper pressure won't build up which will give the sensor inaccurate information, or the sensor is just defective.
The FE error code refers to a "frequency error"--something is wrong with the incoming AC power supply--If this is an LG machine, then the error code is the pressure switch again--Sorry for the ambiguity but different makes have different meanings for the error codes--anytime an overfill condition exists, I first suspect the pressure switch, then I check the wiring harness connections, lastly, I suspect the main control board. I hope this helps you!
Nov 07, 2015 | Washing Machines
Ariston AQXXF 129 Error code F 05 - What is this?
see this causes and fix it. God bless you
F05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.
Sep 30, 2012 | Ariston Technologies Washing Machines
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
Keurig Mini Plus constantly overflowing
It's possible that it needs a cleaning... there may be a residue in the lines somewhere or a buildup... look in your manual to see how often they recommended cleaning it... it's also possible that the pump may be going if it is an older model... I would start with cleaning it according to your manual's instructions and then go from there. As a last resort, maybe you could contact the manufacturer if a cleaning doesn't help.
Feb 17, 2012 | Keurig B30 Mini Coffee Maker
I have a paloma tankless water heater, ptg-42pvn. It was flashing, C4, 13 and now it only flashes -0, 13 and will not even turn on. Tried to reset it by unplugging it and it only flashes -0, 13 even...
Multiple error codes can mean different things, including bad PC board.
C2 13 might be the oxygen sensor. -0 and no operation indicates bad board, but other things might be notched into same problem like loose connections.
Error codes are starting point for troubleshooting.
Before calling service technician, open following link for Rheem-Paloma troubleshoot resources including Rheem chat.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
The cleaning button keeps flashing after cleaning. I have cleaned this with water & vinegar several times, but can only make one or two pots of coffee before the cleaning button begins to flash again....
We have this problem as well. We simply clean it as directed once or twice with the vinegar and water mix and then unplug for an hour. This resets our machine for several weeks. Based on the number of comments I've seen on this issue, it seems that the "off" sensor doesn't work.
Oct 10, 2009 | Cuisinart DCC-1200 Coffee Maker
Kenmore Elite washing machine won't complete a full cycle
its a error code for not enough water fast enoght or no water. check fill bibs are on and screens inside fill valve are clean if ok . make sure you do not have steel branded flow retrickers fill hoses it if so replace hoses. washer has to get a amount of water fast or it will code out
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Emerson IM90 Portale Ice Maker
My friend bought this item last week at Target for the $99 sale price. The reviews were all horrible about the red light (add water) indicator going on after the first or several first ice cube runs and never going out. About 40 out of 60 reviewers had this problem. We experienced it right after the first run when the ice cube full light went on. We emptied it and the add water red light was on. I looked all over the web for a solution and only found one that suggested tilting the unit backwards for 45 degrees and that would magically reset the light. It did not after several angles, light taps and basic shaking. Since there was no alternative and everyone who returned it also got the exact same problem with the new replaced model - we decided to open it up and investigate.
The electronics diagram is on the back of the machine and tell you where the water indicator is. We took it out (an inch long black tube along the water pump and backflow valve) and dried it completely. The cycle still had the red light. We submerged it completely in water and the red light still went on saying that the unit needs water. We determined that this is the bad part and the water indicator is faulty. We cut it out and joined the two wires. IT ALL WORKS NOW FLAWLESSLY. You only have to shut the unit off when you leave since it will ocntinue to run if out of water. If you're looking for a quick mechanical fix and have a unit that works when you need it and you are around - this isthe fix.
Aug 23, 2008 | Ice Cream Makers
Kenmore 24 in. 16019 Built-in Dishwasher Logo
146 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
