Question about True 23 cu. ft. / 651 liter Commercial Freezer GDM-23F
True Freezer- The 5 amp circuit breaker trips when the light on
I have a TRUW GDM-23F frezer
The 5 amp circuit breaker trips when the light on the door is on. The upper light works with no problems. I've checke the bukb an looked for a short but nothing hsa helped.
  • Dennis Boxerman May 11, 2010
    Check the switch that operates the light.
TRUE MODEL T23F.(FREEZER)
BRAKER TRIPS OFF WHEN THE TAB OF THE DEFROST TIMER IS SUPPOSED TO GO OFF. DO I NEED TO HAVE IT REPLECED OR SOMETHING ELSE GOING ON?
THANKS, VERNON.
Posted on Mar 04, 2013
  • 122 Answers
I believe that breaker is actually for door frame heaters. Most true freezers have a resettable breaker for the door perimeter heaters only.
Posted on Sep 22, 2009
T-23f true freezer compressor makes rattling noise then starts sometimes i believe it is the over temp compressor relay
replace the current relay and overload and start capacitor.
look for any looe or damaged wiring as well.
Apr 06, 2013 | True T-23F 23 Cu. Ft. 1 Door Freezer
Regarding replacing the temperature control on the True t-23f freezer, I can't find it.
As soon as you open the freezer door the temp control is at the upper right of the freezer.
Mar 20, 2011 | True 23 cu. ft. / 651 liter Commercial...
The fan on my true t 23f does not run. i check it is not getting power is there a fuzz or capacitor for this thanks
Are you talking about the fan inside the freezer? If yes, check the following items. The door has a switch that turns the lights off when the door closes, it also turns the fan off when you open the door. If it isn't working right the fan won't come on. There is also a round temperature senser on the coil inside the freezer called a "clickson" that keeps the fan from coming on until the coils are below 20 degrees, it may be bad. If you are low on freon, your coils may not be getting cold enough to trip the clickson. Feel of the small copper line going from the compressor to the coils on the outside of the freezer. It should be almost hot enough to burn your skin if you have enough freon. One other thing to check is the defrost timer. It is a box about 4 inches wide and 8 inches tall with a door on the front of it. Check the connections inside to be sure you are getting power through to the fan. Let me know how it turns out.
Oct 04, 2010 | True 23 cu. ft. / 651 liter Commercial...
Light removal
get a screw driver and loose the light holder and replace it a new one bought .
May 03, 2010 | True 23 cu. ft. / 651 liter Commercial...
Freezer begun tripping our 20 amp breaker for some reason
ok hi there i viewed the specs for this freezer
http://www.truemfg.com/catalog/servlet/com.apsiva.servlet.HomeServlet
this unit must be plugged into a 120v outlet with a 15amp circuit breaker dedicated (nothing else should on this circuit) so all by itself. you have to check the voltage outlet where you plug in. you must have at least 115v or better (125v the most) if you have less then 115v it will cause damage. ok you went and checked all this out and everything is 15amp with 115v or better and it still trips breaker.
ok the running amps is 6.8 amps so to blow the circuit you need 15 amp which is too high.
i suggest you call a refrigeration guy because he will be able to determine if the problem is the compressor (which has a 4 year warranty with truemfg.com only in the USA) or something else. Usually but not 100% what would make a freezer like yours to blow the fuse is the compressor. if it overheats it will do this, if there is a sudden high pressure within the system it will do it, if you have a condenser fan that is not running at proper speed it will do this...
the problem cannot be pin pointed understand please... you have to babysit it, watch for changes in the refrigeration system and the running compressor amps, voltage drops ( this will cause high amps) etc...
Refrigeration is not easy and alot of tech stay away... so those who stick it out make money cause you have 2 choices: buy another one and pay big bucks to get it fixed. at least see if you can find someone to come over (for like $40 - $60) and tell you exactly whats wrong with it... whew... hope this was helpful and not confusing...sorry
Apr 03, 2010 | True 19 cu. ft. / 538 liter Commercial...
I need to know how a true GDM-23F freezer should function were can i get a owners manual i just want to know what should com on and when example evap fan is not on but the evap is below freezing should...
http://www.truemfg.com/pdf/InstallManuals/GDM/gdm_english.pdf
This should take you to the site for the owners manual. You may be looking for a technical manual inwhich True doesn't do that. I will be more than happy to answer any questions should this manual not have what you're looking for.
Good Luck.
Jul 23, 2009 | True 23 cu. ft. Commercial Freezer...
Lights wont come on in the cooler
underneath the unit in the metal box there is a ballast for the lights check it to see if it is getting power and or producing power to the bulbs
Jun 15, 2009 | True 23 cu. ft. / 651 liter Commercial...
Kenmore commercial upright freezer not sealing well - thawing
If the door seal does not seal completely, replace it. This is very important for freezers.
Contact Rick at Restaurant Parts and More.
\1-888-814-1110. He can most likely get what you need. Just have model and serial numbers and he'll do the rest.
Home Depot and Lowes is a definite no.
Apr 04, 2009 | True 23 cu. ft. / 651 liter Commercial...
True 23 cu. ft. / 651 liter Commercial Freezer GDM-23F Logo
324 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
