Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
I have a belkin wireless router and have forgotten the password. I want to set up a new connection.
    Scholar:
  • 86 Answers
Use the instructions here:
http://en-us-support.belkin.com/app/answers/detail/a_id/48/q/routers
This will reset to the factory default and use admin for the user and the password will be blank.
Posted on Sep 11, 2009
    President:
  • 1,187 Answers
The "default" user & password:
Username: admin
Password: (doesn't have a password - leave it blank)
If you changed the password at some point, the above may give you a clue...
If not, then:
You can reset the router but you will lose the configuration.
If that is ok, then:
1. straighhten a paperclip to make a pointy stylus.
2. locate the reset "hole" on the router
3. with the router powered ON, insert the stylus into the reset hole
4. continue pressing for 15 seconds or until the router lights start flashing to indicate that it is reset to factory specs.
5. Wait for it to power up completely (1 minute).
6. Use "admin" as the username and there is no password...
Hope this hleps!
    Genius:
  • 1,341 Answers
There is normally a reset switch on them which when pressed brings the whole router to factory default.Then from there you can log into the router settings and create an encryption and a new password.
SOURCE: Belkin N1 Wireless Modem Router I cannot connect to Tiscali HELP
I had this with Bt Internet and this exact same router, you have to phone Belkin up and they give you a complete set of new settings that you manually have to put in during setup. If i remember rightly its a free phone number and the operator who answered spoke semi-english so not all bad, hope this helps.
Chris E
Posted on May 17, 2009
  • 7 Answers
SOURCE: belkin wireless router reset password problems
You have to connect(wired) through one of the ports on the back of belkin to a laptop(or PC) physically.And this laptop(orPC) should have the software that came in the CD as part of the router packaging.
Then you open the web browser and and type http://192.168.1.1 on the address bar.This should let you access the router from where you can configure your settings..Network name,password,password for the router itself etc.
HTH
Posted on Aug 12, 2009
  • 38 Answers
SOURCE: setting up a belkin n wireless router. How do I
You have to go into the setup for the router. Most default to the 192.168.1.1 IP address. You would type that address into your internet browser and hit enter. Then you will be asked for a name and password. If you have your belkin manual it will tell you the default name and password. Once in the settings you can change the password. You can also turn off SSID broadcasting, enable the highest level of security that your particular router supports in conjunction with your computer and enable MAC authentication. If you enable MAC authentication you have to type in the MAC address for each device you wish to have access to the router.
Posted on Nov 07, 2009
garethmt
  • 116 Answers
SOURCE: New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
Posted on Nov 13, 2009
  • 8404 Answers
SOURCE: I have a ZyXEL prestige 600RU-T1 connected to a
Hi confused girl.
May I recommend you use Network Magic to unravel your delima. Free to download and evaluate, NM will assist you with connectivity issues, security and device sharing.
If you still have trouble because of the password, you can do a hard reset. Find the little hole on the device and insert a paper clip. Gently depress and hold the button for 30 seconds or more. No hole? Well there has to be a way to hard reset the device. Check here: http://www.zyxel.com/ select your country and select support for your device.
Thanks for posting at FixYa.com
please vote
thanks
Posted on Dec 13, 2009
My belkin G+ wireless router model: F5D9231-4 v2 security is lock and i cant log into my laptop
If you have forgotten the password, reset the Belkin by pushing and holding the reset button for 30 seconds or so and release, this will reset to default settings. Connect and reconfigure the SSID and Security Key. You may want to write down the password and store for future use. Belkin Support: http://www.belkin.com/us/support-article?rnId=6939
Dec 27, 2012 | Belkin (F5D7231-4) Wireless Router
Need passwword for belkin wireless router
By default, Belkin routers do not have a password,just click on Submit to log in..But you should check check your Belkin router setup documents.
If you forgotten or lost router password cannot be recovered. It can only be reset by hard resetting the router.
Sep 11, 2012 | Belkin (F5D7230-4) Router (587009)
I would like to WIFI my phone but have forgotten the password on my Belkin how do I find it or reset it.
Connect a LAN cable from Belkin to yourlaptop/computer's LAN port, open a browser on your laptop/computer and enterthe Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jun 27, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I do not know the Belkin passphrass? I moved recently and have never had to use the password therefore i have forgotten it. How to I get it back
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Click on wireless then wireless security Enable WEP then enter new password save settings and restart router .Then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa
Nov 25, 2010 | Belkin F5D7234-4 Router
I am trying to connect my ipad to my wireless network and have forgotten my password. HELP. To connect to wi-fi I need a password and can not remember the password as this router was set up years ago
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Click on wireless then wireless security Enable WEP then enter new password save settings and restart router .Then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Nov 18, 2010 | Belkin (F5D8231-4) Wireless Router...
My belkin wireless router is locked. How do I unlock it?
If you have forgotten the login password you can RESET the Belkin back to the factory defaults and configure it again.
THEN
Power up the Belkin and press the RESET button for 7 secs.
The default login password is blank.
Please let me know if you have any further questions or concerns.
Thanks.
Apr 23, 2010 | Belkin (F5D7230-4) Router (587009)
I secured my wireless network but have forgotten the password
hey what you can do is you can reset the entire router... by using the reset button on your belkin router... Or else you can also access the router by using the following IP address in the internet exlorer...
try 192.168.1.1 or 192.168.1.0 & then go to the wep settings & reset the router or change the password for the router...
Jan 17, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
We have purchased a new notebook{higrade brand vista OS} to replace a packard bell using XP the XP laptop connected no problem the newone finds the belkin router but won't connect to the internet are...
Do you have a wireless security protocol enabled, and if so, what? Install a wired connection to the router (use an ehternet cable to connect your laptop's RJ-45--looks like a wide phone plug--into one of the Belkin router's network jacks). Go to the router's management page using your web browser (probably http://192.168.2.1). If you have not previously set the password in your router, simply leave the password field blank and CLICK "Submit". If you have previously password protected your Belkin router, use the known password. If you have forgotten your password... you'll need to reset your router.
Reest Router: there is usually a small hole into whiuch a pin or paper clip can be inserted for this purpose or a small button to press. Most Belkins--IIRC--have the button.
Once you are on the Belkin router's management page, look for the wireless link and set your security protocol to match what your wireless card is capable of, set the password, save and exit. Use the sasme password in configuring wireless networking in Windows.
Jul 17, 2008 | Belkin Computers & Internet
Yeah hey...belkin wireless router password reset
What is the brand of the router your using? This information will be from the router that you have. Use a wired connection from the router,check your default gateway (ipconfig) and type that numbers in your address bar. You will be able to access your set-up page, look for wireless tab and look for wireless security. You will see there your WEP key.
Jun 26, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Forgotten pass word
If you are meaning the password to connect wirelessly then just reset the router by pressing small reset button. Then us the password/key on router to connect.
If you are meaning ur password to get router to go online you will need to contact your ips for that.
Dec 26, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
111 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
