Question about Maytag Neptune MAH5500B Front Load Washer
I have a neptune front load washer for about 3 yrs. When it gets to about 15 min left it goes on pause and reads out code Lr.I've been reading that it may be the motor. Could please let me know what I should do about this. Thanks, Cindy
    Brigadier General:
  • 8,619 Answers
Hi Cindy,
Thanks for using FixYa. The error Lr means locked rotor. The error is its motor. You need to replace your motor and motor control board sold as one unit these are 3 phase’s motors and one of the phases is bad. Also after you have replaced the motor don’t forget to put a surge protector on these machines because a little power surge can damage the boards. I have heard that Maytag just figured this out because they are sending one with the new machines now. You can also order the motor conversion kit 12002039. Your problems will be solved. Instructions are in the kit, and it includes a new motor and board.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 11, 2009
Yes I just want to know I it's worth fixing this prob. I have a maytag Neptune tl washer model fav6800aww it's starts fine but after 3 minutes it stops on wash cycle an after 5 minutes Lr shows on...
Lr error code is locked rotor. Could be a couple different issues.
Google this phrase and read thru the post ""[FIXED] Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin""
Post in that forum if you want to DIY I do not offer DIY help here any more.
Jul 12, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Washer wont finish cycle and display reads "LR"
Hello todd.... This is a common problem with the neptune. It means that the machine needs a new motor and a new motor control board kit. If you are under warranty do a repair. If not, get an estimate before you go ahead and repair it. Joe
Thanks for choosing Fixya!
Feb 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune Top load washer that is displaying an LR code. I unplugged the washer and plugged it back in after about an hour. I was hoping that this would reboot the unit. Of course it did not....
Don,
See if this post will get you started; http://www.fixya.com/support/t2419091-maytag_neptune_top_load_fav6800aww_tub
The LR "Locked Rotor" error code could be related to a failed Control Board, Motor Controller, Motor or I feel the drive system is seized up.
Read thru the post and see if will get you started.
D*ick
Aug 06, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
What does the code Lr mean at the end of the cycle and door remains locked
According to the manual Lr means 'Motor not running properly' and it says you should call for service.
You may be able to open the door by pressing the start/pause button and waiting for a minute or so.
Mar 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Lr shows during spin cycle and pauses washer
you need to replace the motor and the motor control board,it comes in a kit,call your parts store give them the model number and the first two on the serial.common problem with the neptune,the wire harness that plugs into the motor is strait down,moisture runs down the harness and gets into the connectors,it's around 200 bucks for the kit
Feb 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune reads "LR" when its supposed to spin but doesn't spin what doe this mean
HI, the (lr) represent a Motor malfunction. this is commonly caused by a faulty Motor Control Board. you can confirm by inspecting the wiring harness that connects the MCB to the main control. if the harness is in good condition, replace the MCB.
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load has Lr on Time display
Im having the same problem what is the lr code and how do you get rid of it?
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG NEPTUNE LR CODE
LR usually means that the the signal from the board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first.
May 13, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
12 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
