Question about Car Audio & Video
I have a fujitsu ten P3400124 by Mitsubishi Phil. The system locks up after i change the batt and made an error in entering the password. Pls help
  • Car Audio & ... Master
  • 4,869 Answers
To reset LEAVE IT SWITCHED ON ...UNDISTURBED  for as long as it takes to automatically reset itsel (It may take several hours as the waiting time depends on how many wrong codes have been entered)
If you do not have the correct code (password) then POST ANOTHER QUESTION quoting all the details on your radio
Posted on Sep 11, 2009
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
Tip
Reset Mitsubishi WS-55711 VChip Password
Bypass or Reset Mitsubishi WS-55711 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 55711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Bypass Mitsubishi WS-55711 Front Lock
Mitsubishi WS-55711 Manual Download
on May 03, 2010 | Mitsubishi WS-55711 55" Rear Projection...
Tip
Reset Mitsubishi WS-48511 VChip Password
Bypass or Reset Mitsubishi WS-48511 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Bypass Mitsubishi WS-48511 Front Lock
Mitsubishi WS-48511 Manual Download
on May 03, 2010 | Mitsubishi WS48511 48" Rear Projection...
I have a fujitsu laptop/tablet and i forgot my password. how can i fix that???
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. HERE YOU CAN CREATE NEW USERS OR CHANGE YOUR PASSWORD IN START MENU->CONTROL PANEL->USER ACCOUNTS . AND IF YOU WANT THE BOOT UP PASSWORD PLS REPLY OR COMMENT. THANKS
May 20, 2011 | Computers & Internet
Lockedout before user acct. password window entry
so is your password blank?? or have you changed it to something you cant rememeber? did you create a restore disk (no one really does this so will be surprised if you have) you can try a password change boot disk (search online for this) but can't guarantee this method.
May 07, 2010 | Acer Computers & Internet
Tip
Reset Mitsubishi HDTV VChip Password
Bypass or Reset Mitsubishi HDTV V-Chip Password Lock
I hope that helps.
Bypass Mitsubishi HDTV Front Panel Lock
Mitsubishi WS-55511 Manual Download
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Bypass Mitsubishi HDTV VChip Password
I hope that helps.
Mailbox locked error message. when i try to check messages and enter my mailbox # and pw. it says mailbox locked, pls call admin. and then closes
You need to get into voicemail administration and reset the mailbox password. Open the mailbox (F981), enter the default password (0000) and the system will prompt you to enter a new password.
Good Luck!
Sep 08, 2009 | NorStar Compact Ics WithClid Trunk Mod...
Fujitsu Siemens AMILO Pro V2000 PC Notebook what default BIOS password My computer is locked
there is no default bios password
all i know at the some fujitsu laptops if you enter 3 times wrong bios password the computer locks
This is a security issue
Jul 09, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Car Audio & Video Logo
99 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
