Question about Roper RAX7244KQ Top Load Washer
Water will not shut off
The water does not shut off...it appears to be going thru the cycles but the continues to run and eventually over flows.
  • girlrider45 Jan 28, 2008
    Water will not shut off and continues to fill until overflows even if you stop it at the knob. I have to turn it off at the valve to stop the problem for now. I am also having trouble getting the back panel off and need help there as well. Why is there no reset switch on these machines if you need to adjust the water level to the laundry amount? You can only stop it and completely go back around with the knob, unless someone else can tell me how to reset it.
I had to replace the water valve. A friend in the appliance repair business gave me a hands on training to do the repair myself. I came home and had it replaced in less than 15 mins. As for the reset switch, it is still unknown.
Posted on Apr 03, 2008
  • 110 Answers
It sounds like you have a water level switch failure..
also check your water level switch pressure hose that connects to water level, alot of times it is pinched of off the water level switch or tub..
Water is going into the ice tray but once it freezes the cubes dont come out when the assembly rotates. When it cycles again to get more water the water spills into the dispenser & eventually the tray
can b one or two things wrong here
(1) how sure are u that water is not just continuously flowing into tray (at low rate) ??? reason I ask is a leaky solenoid valve is a very common failure on ice makers
(2) is arm that rotates thru ice tray ,not obstructed by anything ? ive seen Frozen pizza's hold a swing arm down and not allow it to raise to shield the ice tray in a dumping cycle (im speaking of "hold" arm ! thin steel arm that raises up in a ice dump cycle )
(3) of course could be a defective ice maker as well ? theres lots of motors and gears and switches inside there that could malfunction and prevent it from working
Jun 29, 2015 | Refrigerators
MY MAYTAG FRONT LOAD AT TIME WILL FILL WHEN WASHER IS NOT ON OR WILL DRAIN AND SPIN ON IT'S OWN
It may be the water inlet valve is not shutting off the flow 100%. If water keeps trickling in, even dripping, it will eventually fill the drum. Some models have a water level sensor that will run unit thru a drain cycle to prevent an overflow situation. Try checking the unit every 6 or 8 hours to see if there is a slow build up of water accumulation. Replace inlet valve if there is.
Dec 26, 2014 | Maytag Washing Machines
My GE 15 cycle heavy duty plus washer the water keep running in the rinse cycle
Hum the water inlet valve may be going out or defective, have u noticed any water in tub at bottom when machine is not in use or after a day or so? check it with multimeter. Another suspect could be a bad timer sticking on rinse cycle, or a bad water pressure switch, which is suppose to shut water off at certain water level then start the agitation? In other words when in rinse and water is draining, the pressure switch continues to read low and opens to keep the water flowing to replace water that is lost? Need a multimeter test on all of them
Sep 26, 2014 | Washing Machines
WASHER DOES NOT AGITATE OR CYCLE AFTER WATER FILL
If your Top Load Washer is Over Flowing Check the Following it is possible that the Water Inlet Valve is faulty.
First check to see if water is entering the machine when it is shut off if it is,replace water inlet valve. If no water enters the machine when it is shut off the water inlet valve is not the problem.
Pressure Switch
The pressure switch controls the level of water in your washing machine. This does this by a small chamber on the side of the tub, this chamber fills with water wich in turns creates pressure in the chamber. There is a hose connected to this chamber that runs up to the switch. When the right amount of pressure is applied to the switch it stops the water flow. If the hose becomes clogged up, gets punctured or cracks and leaks the hose will need to be cleaned or replaced. If the hose looks good and has no holes check the pressure switch by checking it for continuity when blowing on the end of the hose. This will close the switch and simulate pressure. If you have no continuity when the switch is closed replace the pressure switch, this video will walk you thru replacing and testing.
Aug 23, 2012 | Whirlpool Washing Machines
I have a Hoshizaki Model KM500MAE that keeps freezing up. What can I do to stop this problem
several things cause freeze ups.
If you have water filters on the water system, be sure they are not restricting the water flow. water flow pressure should not go below 20 psi.
The bin stat may not be shutting off the unit properly. It should shut off machine within 10 seconds of ice making contact.
Make sure the float switch is not dirty. Be careful when cleaning. Fragile
Make sure water pump runs the entire time it is in the freeze cycle.
Be sure the evaps are clean. Ice cubes will hang on if not clean.
Water solenoid has a screen where the water line screws on to it. Turn off water and check screen to be sure it is clean. This can restrict water flow.
Make sure water valve closes all the way. Turn machine off and see if water is still running. Valve may be leaking water thru.
Dip switches on the board, #1 and #2. Turn them both on and it will change the defrost time to 3 minutes. If both are off, they are set on 1 minute.
Hope this solves your problem. Let me know
Apr 07, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Washer over flows with water and does not go into spin cycle
water level sensor is not working properly
with your solenoids to shut off water
Jun 02, 2009 | Washing Machines
Water keeps flowing does not stop---does not go thru cycles
You probably pinched the water fill hose that comes up from under the tub when you closed the cabinet. Also make sure it is free from trash in the bottom of the tub and that it is tightly connected to the water level switch.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Water won't stop running
It might have a small stone or something similar in the water soleniod valve or it might just be sticking open somewhat. I'd go ahead and change the cold water soleniod valve because it's not closing itself and shutting off the water flow.
Jan 08, 2008 | Maytag Performa PAV2200
Roper RAX7244KQ Top Load Washer Logo
53 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
