Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
I need the correct description on how to install the brake cable
It seems that my cord is too long or it's just not installed correctly by the person I bought the mower from. Does anyone have a photo that I can go from showing how to install on the engine and the handle? Thanks.
    New Friend:
  • 93 Answers
Seems like the previous owner disconnected it from the push handle and now of course it is to long. Remone pull grip thread through eye bolt on the top side of your mower handle, replace pull grip...........You should be good to go. If the eye bolt is missing, you should see a hole in the mower handle toward the top where it used to be !
Posted on Sep 17, 2009
HP T1100 post script getting 08:11 error, which means communication with front panel, but have read it could be all sorts of different problems. Does anyone have experience with this? Before this error I...
This comes straight from the service manual:
System Error: 08:YZ
Problem Description: Problem with the Front Panel.
Corrective Action: Try the following:
1 Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
2 Check that the Front Panel interface cable is not damaged and is correctly connected between the Main PCA and the Front Panel. (they can easily become partially disconnected)
3 Check that the memory module in the Formatter is installed correctly.
4 Check that the connections between the Formatter are not damaged and are correctly connected.
5 Check that the Printer has the latest Firmware version. If not, update the Firmware to the latest version.
1st If the System Error continues, replace the Main PCA
2nd If the System Error continues, replace the Formatter
3rd If the System Error continues, replace the Front Panel
Sep 13, 2013 | HP Designjet T610 InkJet Printer
How to install a power supply
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Unplug all electronic cords connected to the computer. At no time during the installation should any cords be connected to the computer. Remove the screws holding the computer cover case, and remove the cover case. Locate the computer power supply box, which looks like a large box out of which a bundle of wires run and connects to the power cord jack on the outside of the computer case. Unplug the power cables from the internal devices connected to it. Be careful not to damage any of the sensitive control boards or devices inside the computer, and be certain to remember--write it down if you need to--what devices will need reconnecting to the new power supply when you finish the installation. Unscrew the power supply from the inside of the computer case and remove it. Check the original power supply's red voltage switch for the correct setting. It should read 120 or 240 if you live within the United States. Confirm this setting as the correct voltage setting for your power outlets. Make sure your new power supply gets set to the correct voltage setting before you install it. If it cannot be set to the correct voltage, do not proceed with the installation or you may damage your computer. Return the new power supply and buy one that is compatible with the voltage requirements. Install the new power supply, reattach the screws that will hold it in the proper place inside the computer. Reattach the power cables that come from the new power supply to the devices that were connected to the old power supply. Make sure all of these connections are firmly in place before you turn the computer back on. Reattach the computer power cables and all the cords connected to the computer during normal operation, but do not close the computer case yet. Keep your hands clear of the inside of the computer case as you attach power cords and peripheral devices. Turn the computer on and observe the performance of the computer without touching anything inside. Do all the computer fans function normally? Does the computer operate as well as or better than before? If you feel that the computer behaves normally and you do not encounter any problems, turn the computer off, remove all the power cords and peripheral cables once more, and close the computer case. Then reattach the power cords and peripheral cables and begin using the computer. Check for errors if you encountered any problems starting the computer or if it would not start at all, unplug all the power cords and computer cables connected to the computer and look inside. Make sure that you connected all the correct power cables inside the computer securely and did not miss any. If you have confirmed this and the computer still doesn't start or operate normally, call your computer manufacturer or a professional computer repair shop for assistance completing the installation http://www.youtube.com/watch?v=xvClS_M-09o&feature=watch_response_rev watch video http://www.youtube.com/watch?v=s0udZ0Ky4Pk Hope this helps.
Jan 03, 2013 | Computers & Internet
Can't install power supply
Be careful not to damage any of the sensitive control boards or devices inside the computer, and be certain to remember write it down if you need to what devices will need reconnecting to the new power supply when you finish the installation.
If you have confirmed this and the computer still doesn't start or operate normally, call your computer manufacturer or a professional computer repair shop for assistance completing the installation.
Most power supply units will fit
Like everything else in our high-tech world, power supplies come in myriad sizes and shapes
you should check all the electrical connections before you make a decision and make sure they are the same as the ones that you will need to run your computer also
Check the measurements inside the frame to make absolutely sure it will fit,
http://www.youtube.com/watch?v=mKw0bij8CDs
Hope this helps
Nov 13, 2012 | Insignia D400a PC Desktop
No sound from System Samsung Model HTZ420t/XAA Checked all the cords, Checked all the wiring. Still no sound.Digital Audio Cable appears to be loose. Tried to re install. Red light comes on. But still...
So a couple of things are going on here:
1) No sound. Have you opened the manual and run the setup to test the basic speaker functions? The only wiring that would matter would be some of the speakers connected correctly.
2) Loose digital cable. That'sa physical problem that needs a real person to look at it.
Aug 26, 2011 | Samsung Audio Players & Recorders
08:11 error in hp designjet t1100
System Error: 08:YZ
  • Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
  • Check that the Front Panel interface cable is not damaged and is correctly connected between the Main PCA and the Front Panel.
  • Check that the memory module in the Formatter is installed correctly.
  • Check that the connections between the Formatter, the Formatter and the Formatter are not damaged and are correctly connected.
  • Check that the Printer has the latest Firmware version. If not, update the Firmware to the latest version.
  • If the System Error continues, replace the Main PCA
  • If the System Error continues, replace the Formatter
  • If the System Error continues, replace the Front Panel
Jul 27, 2011 | HP Designjet T1100ps Printer
Hi how toresolve error code 08:11 from HP designjet T610
I hope this will help its taken from the HP book the YZ are not relevant
good luck
Yours Ian
System Error: 08:YZ
Problem
Description:
Mar 08, 2011 | Office Equipment & Supplies
On my 2000 Mazda 626 2.0L, the timing belt was
First look at this and make sure the plug wires are connected correctly. 3e7c3d3.png
If the plug wires are correct then it is obvious that the cam belt was installed incorrectly of a sensor was damaged during the installation. Take it back to the person who replace the belt and nicely demand they fix it.
Jun 12, 2010 | 2000 Mazda 626
Trying to identify the correct wires
Parking brake wire can be grounded. If you need to turn the barking brake on and off, install a toggle switch in line with the ground.
May 31, 2009 | Dual XDVD8181 Car Video Player
J'ai instaler des freins intégra 93-94 pas de abs les calipers plaquette neuf master neuf hydrovac ben correct pis le proportining valve intégra pis la les break colle je slake les seingneux pis...
You need to bleed the brakes every time you change the brake pads. In order to do this correctly, you need 1 more person with you to press on the brake pedal while you bleed the system, getting rid of the air in the lines is a top priority after a change. And yes, it's a DOT-3 brake fluid.
Aug 21, 2008 | Honda Civic Cars & Trucks
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
195 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
