Check this link this will help you.
http://pdftown.com/pdf-ebook/integcivinstall.pdf
Thanks
Smith.
SOURCE: Replacing head gasket on 1995 honda civic, require torque specs and secquence
7.3 ft.lbs Go from middle, to back right, to back left, to front right, to front left. if your standing in fron of your header. 11 or over usually shears the bolt.(if you have stock bolts)
Make sure you dap some rtv on the sharper 4 corners of the gasket where the cam seals are.
James Mac
SOURCE: 1995 Honda Civic 5 speed manual will not shift
It could be that your syncro for the reverse gear is gone. Which would have to be brought to a tranny shop not a do it your self type of job.
SOURCE: I have a 1995 Honda Civic. When driving up hills
Check spark plugs and all related cables, fuel hoses, fuel filter (change if black but make sure lines and fuel tank are clean first), and air filter. If blank spots are experienced when power is lost completely then firing of spark plugs may be the issue. Possibly also related to insufficient fuel reaching combustion chamber. Available for more consulation after you do through the above recommended basic checks.
SOURCE: honda civic vtec 1995 - 1998 engine wiring diagram
Go to your local library and ask the Librarian to get you on-line to the Automotive Repair Reference Center, and then to the EBSCO database...you will find all of your wiring diagrams there.
