Question about Kitchen Appliances - Others
Outdoor motion sensor security light
Our outdoor security light does not come on. We see the red light flashing on it sensing motion but the lights do not come on. If I switch to TEST position they come on ,so bulbs are good and has 120 volt input. This has happened a few other sporatic times seems like after a rain.
Could it be a loose wire nut with the internal cluster of wires from the switches and sensitivity potentiometer which in test mode possibly bypasses everything?
Obviously its not the hot or neutral from the power source.
I cleaned the glass eye shield per say.
sally_ice
  • 10 Answers
SOURCE: "fail: Test ADSL Line Sync" per AT&T Tech Readout
hi,there are a lot of possibilities y ur dsl light wont stop flashing red, 1.could be hardware failure,2.defective lead light for dsl,3.or line issue on the network...i strongly recommend that you contact your isp or att provider so that test would be done by their tech support,...basically you have checkd all inside wirings n as you have said you even tested the nid already...have you tried changing the dsl cable or phone cable? have you tried using another modem? were you using a filter for your dsl? you have to consider also other emi/rfi or electronic interference....but most probably you might try upgrading your modem n see if your gonna get a steady dsl light...the ethernet plugs has no effect on the dsl light...its just the cable connection or line issue or defective modem...i hope this will help, pls feel free to ask if you need further astnce...
Posted on Dec 01, 2007
kermit854
  • 38 Answers
SOURCE: 120 volt folorescent light sign with a photocell
Based on what you've written, it should be black to red, white to white, and green to green. If you still have trouble, post a picture so I can have a better look of this photo-cell.
Hope this helps,
Kermit
Posted on Aug 22, 2008
  • 69 Answers
SOURCE: outdoor motion sensor light wont shut off
Ace hardware
Posted on Dec 24, 2008
  • 384 Answers
SOURCE: 10kw Generac Guardian not cranking, shows rpm sense loss
Sounds like Generator mode switch should be "ON".
Posted on Sep 08, 2009
  • 43 Answers
SOURCE: Bulb comes on, turns off immediately on timer-installed switch
there could be a few reasons for this,
1. the timer could have been damaged during a power surge, = unusable and needs replacement
2. The program set to switch on and off was lost, and needs to be reset, try to operate the reset button, and setting the parameters again., If this is the cace, make sure the backup battery is still ok
Posted on Oct 24, 2009
I have an installed PIR exterior motion sensing light, but no instructions on how to set the controls. Now, if it senses motion, it will stay on for hours.
the sensor has at least 2 knobs maybe 3. one show hands of a clock one show sun. one may show sensitivity. the adjustment is low to hi the wider the adjustment the greater the setting check out this picture on ebay for the icon.
https://www.ebay.com/itm/Outdoor-12M-PIR12V-PIR85-265V-Security-PIR-Infrared-Motion-Sensor-Detector-GF-/292078238929?var=&hash=item4401383cd1:m:mRSg-Rlk4nJMZJH-BiKb2gQ
good luck
Oct 20, 2017 | The Home Security
I have lost the manual for this product and would like to know how to set it up, at this time it stays on when the light switch is on.
If you turn the switch off and on real quick the light should stay on. If you turn the light off for about 5 seconds and then turn it one, then it should sense something that moves and is warm depending on the sensitivity switch setting.
May 10, 2015 | Hampton Bay Outdoor Lighting. Alexandria...
What do I do with the red wire on a Brinks Halogen Motion Sensing outdoor security light
Please perform these connections with the mains power off.
The standard is the Black wire is hot, the White wire is neutral, and the Red wire is switched. For your Sensor connection 120V is connected Black to Black and white to white while the Load is connected White to White and Black to Red (assuming your load is using standard color coding.
Here is a simple diagram for your connection.
Mar 01, 2015 | Electrical Supplies
Why did my motion light stop working and the sensor light is blinking red?
Did you find out why?? I just purchased 2 of these and loved them as they worked for like a week and now both are not working however they are getting power as the red light comes on when there is motion...Please help if you know as I paid 110.00 each for these and I am confused how the bulbs could be blown?
Jun 02, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
My motion security light keeps blowing only the left side bulb.
I assume you mean that the light bulb is failing. This can be caused by a faulty connection at the base of the lamp which causes the bulb to heat at the connection point. Remove the bulb and (with power off!) examine and clean the bulb socket.
Jan 19, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
I have outdoor security lights that run on a timer. Are there some that use a motion detector?
Yes, in fact most people have motion-detector activated lighting so they can know if there is suspicious activity outside of their home. Many security companies also offer systems that allow you to operate the lighting at your home from a smartphone or personal computer, which can help save electricity when it comes to outdoor lighting.
May 09, 2013 | Home Security
Motion sensor outdoor light won't go off
How long has this been going on? Has this light fixture been updated recently? Has the lite switch been changed that operates this fixture?
Feb 23, 2013 | Cooper Lighting regent light BRZ Motion...
Outdoor sensor won't work
Hi, Remove the cover and check for power. If you have power,replace it.No power, look for a tripped breaker. Good Luck,
Shastalaker7
Nov 14, 2009 | Heath Zenith SL-6106-IV Motion Sensing...
Have Cooper lighting outdoor motion detected flood
Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
Jul 18, 2009 | Desa International 240 Deg. White Twin 150...
Kitchen Appliances - Others Logo
206 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
