Question about Garden
The cord of my 30ss wont go back in after I pulled it to start it, I've taken off the shaft with the handle on it, But, there's a drum on the shaft and it won't come off. How do I get this off of the shaft so I can remove the shroud cover?
  • 279 Answers
That is removed by using a #15 Torx screwdriver into the end. There is a screw in there...Good luck...Lee
Posted on Sep 11, 2009
Trying to pull transmission the cv axles wont come out of ******?????
Put a piece of wood on something next to the transaxle
and try not to pry on transmission
Use a 36" pry bar to get behind the axle & on the wood,
& pop or snap them out
Jul 16, 2012 | 1998 Oldsmobile Intrigue
I have owned my Model 224L Trimmer less than 60 days, last night I tried to use it and the trimmer head would only engage occasionally. It would start to spin then disengage, even when I had all the right...
It sounds like a warranty issue, up at the engine you have a centrifugal clutch bolted to the flywheel, as the engine speeds up the clutch expands and engages with the drum, this in turn rotates ans turns a flexible shaft within the tube, this engages into the gear box and turns the gears that turns the head, so i would say the flexible shaft is either slipping in the drum, or the tube or gearbox has moved out board so is now too short to engage into the drum.
Jun 14, 2011 | Husqvarna Garden
Replace clutch and shaft on model no 325L brush cutter
There are two versions of this, on the early system the shaft threads into the drum, on the later machine the shaft has a square and just pushes into the drum, to acess the drum on both systems, you need to remove the top cover, diss connect the throttle cable from the carb, un hook the coil wires from the top of the end cover, take out the two mushroom headed screws in the grey throttle handle with a 4mm allen key,do not lost the o rings underneath, slacken the two 4mm headed allen screws from the tube clamp, you can acess these through the pre cut holes in the throttle handle,now twist and pull the tube out of the clamp and through the throttle handle, if the shaft is squared it will also pull away, take out the three 4mm allen screws securing the tube clamping cover and pull away, if the shaft was squared and pulled out, then the drum is held into the bearing with an external circlip, if the shaft is threaded onto the drum then you need to clamp the shaft in a vice with soft jaws and turn the drum to undo it right hand thread.
Good Luck
Jun 02, 2011 | Husqvarna Garden
My LG M#WM2277HB wont turn the drum. It started making bearing failure type noises a couple loads ago. I just pulled it out , removed the top/back and started it. the motor rotates cw and ccw but the drum...
Oh s***! If the motor turns but the drum does not, the drive shaft has broken loose from the three arms which attach it to the drum. (the part is called the "spider") To repair, remove bolt on end of shaft at center of motor. You may have to cut it with an angle grinder, but don't worry about that, because the shaft has to be replaced anyway. Remove motor rotor and stator. Remove washer front, drain hose, fill hose, shock absorbers, support springs, all wires attached to outer drum, and eventually the entire outer drum. Remove bolts between front and back halves of outer tub to allow removal of inner drum. Remove 6 bolts holding 3 arms of spider to back of inner drum. Re-assemble with new spider and new bolt for end of shaft. If you can do it in under two hours, give yourself a big pat on the back. This is about a 8.5 on a 1 - 10 difficulty scale for washer repair. Good luck Mike.
Mar 06, 2011 | LG WM-2277HW Front Load Washer
Pulon pro 200e cord is stuck and wont pull. It's stuck Cord seems to be stuck in the recoil positionl I was pulling it and it was retracting, I was pulling pretty fast because it would not start and the...
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers or a good flat-blade screwdriver.
Nov 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Pull cord won't pull
Check the shaft to see if there is something stuck in there. You can pull the wire shaft out to check. It is wire but looks like a small cable. Good luck...Lee
Aug 27, 2009 | Garden
Start Pull cord replacement on John Deere s1400
Take the 4 bolts/screws loose that hold the shaft onto the weed-eater body, You will see the clutch drum, you need a long T20 TORX driver to loosen the screw in the center of the drum shaft. The screw probably won't come all the way out, so just pull the drum off as you loosen it.
Next you will see 3 flat clutch discs.
You may need to remove the spark plug and stuff some starter rope in the combustion chamber to keep the shaft from turning.
Unscrew these one at a time with a pair of large slip joint pliers. Be careful not to bend them and note which way they face. They unscrew clockwise I believe.
Once you have these out of the way, continue taking apart the plastic housing to gain access to the starter rope assembly. There is a spring under the rope reel, so remove the screw holding the reel in place and carefully remove the rope reel and spring.
Replace the rope, put the reel back in place and make sure the sping egages the little tab. Then wind it a few turns until there is moderate tension on the spring.
Feed the rope through the body and tie it to the T-handle. Replace the hold down screw that keeps the rope reel in place.
Test the pull tension before reassembly. It should retract the rope fully without too much tension and should not be loose. Lubricate the rope reel where it rubs against the housing with some light grade oil or lithium grease.
If everything functions, put it back together in reverse order.
Remove the rope from the combustion chamber and make sure there is no debris in it. Install the spark plug. You should be ready to go.
Aug 21, 2009 | Garden
I have a Troy Bilt TBP6040 XP 4 cycle weed eater with the spring assist starting. The pull cord broke and I am trying to replace it but I can't seem to get the cord to go all the way back in. I need help....
I just had this same issue. I found out that you have to take the cord out of the handle then put the spool in. You then rotate the spool back in and align the spool with the spring and fish out the cord which will put a small amout of tension on it. You keep the tension on it and put the handle back on.
Rgds,
Mark J
Apr 16, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
